7 messages2012-02-15 15:47 UTCthrough 2012-02-15 20:28 UTC
Re: [Cal_Boats] single lever shifter/fuel control
pw… [at] aol.com2012-02-15 15:47 UTC
Yeah, you can't make anything idiot proof as they are always coming out
with better idiots.
Paul
In a message dated 2/15/2012 10:45:09 A.M. Eastern Standard Time,
ti… [at] ch2m.com writes:
A common mistake that people make when trying to design something
completely idiot proof was to underestimate the ingenuity of complete idiots.
Cheers,
Timm Lessley
503.863.4019 Cell to cell calls
Behalf Of John Courter
Sent: Tuesday, February 14, 2012 10:30 PM
Subject: Re: [Cal_Boats] single lever shifter/fuel control
I have the Spinlock. Works fine, I like it. Hasn't stopped inexperienced
crew from shifting at high rpms. You can move it from full forward to full
reverse before the engine has hardly begun to slow down.
John
To: ca… [at] yahoogroups.com
Sent: Tuesday, February 14, 2012 1:29 PM
Subject: [Cal_Boats] single lever shifter/fuel control
I am looking for a single lever combined shift and fuel control to use at
the steering pedestal of my sailboat. Edson builds one, but if I use it I
canot use the steering brake on my old non-edson pedestal (and a new Edson
control is quite pricey).
Why do I want one, you ask? To avoid having high RPM shifts from forward
to reverse or the opposite. Inexperienced crew, and sometimes over-reved
experienced crew, sometimes forget to reduce fuel before shifting, thereby
having the potential to cause much drivetrain damage.
there are others out there, some no longer made, I'm sure. Any ideas?
chris1232012-02-15 16:02 UTC
This spinlocks are great but darn expensive. as you need two components.
The mechanism and the plate.
I bought a morse controller off the Bayfield list for 50 bucks. If you
search craiglist (best is craiggers.com) or ebay they do show up.
Rodney G. Johnson2012-02-15 16:14 UTC
1) "Nothing is foolproof to a sufficiently talented fool"
2) "Design a system that even a fool can use, and only a fool will use
it!"
To me that means that most people will prove the validity of #1!
If I had a dollar for every time I've seen that proven...... I'd
be sailing a
CAL 46 instead of a Day Sailer II.
I'll add one more....
"It is easy to design something to be "Fool-Proof", but
impossible to make it "Damn Fool-Proof!"
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II #10201
former co-owner of "NODROG"
1970 CAL 21 #285
On Wed, 15 Feb 2012 15:45:04 +0000 <ti… [at] ch2m.com> writes:
Two of my favorite phrases....
idiots.
Cheers,
Timm Lessley
inexperienced crew from shifting at high rpms. You can move it from full
forward to full reverse before the engine has hardly begun to slow down.
John
I canot use the steering brake on my old non-edson pedestal (and a new
Edson control is quite pricey).
thereby having the potential to cause much drivetrain damage.
53 Year Old Mom Looks 33
The Stunning Results of Her Wrinkle Trick Has Botox Doctors Worried
http://thirdpartyoffers.juno.com/TGL3141/4f3bda3758ff5146b617st06duc
RE: [Cal_Boats] single lever shifter/fuel control
ti… [at] ch2m.com2012-02-15 16:22 UTC
I agree the Spinlock has a good cost, (which is about ½ the cost of one of my high-tech halyards) - for me it provides a fantastic value.
I suggested the device in an attempt to minimize high speed shifts between forward and reverse, the added feature of being physically invisible in the cockpit.
I purchased my unit for California Girl in Canada, after a race up the coast. An "invisible" crew member had had stepped on and broke off the "normal" shifter. Invisible in the sense no one admitted to causing the damage.
After guiding the boat into harbor at night with a man on the engine running the throttle / transmission via hand, I started looking for a modern shifter with a removable shift handle. (Cal 40's originally came with an excellent shifter using a shift handle). The unit is flawless to date, and on longer cruises we just remove the handle so the accidental "Aw SHZT" moment does not happen from someone accidentally kicking the lever.
The old Morse control was also a thought, and I have one on Freewind, But Only a skilled and concerned operator (read owner) can normally make this set up work safely.
[cid:image002.png@01CCEBC3.647CC3B0]
Cheers,
[cid:image005.png@01CBF93B.85770E70]
Timm Lessley
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of chris123
Sent: Wednesday, February 15, 2012 9:02 AM
This spinlocks are great but darn expensive. as you need two components. The mechanism and the plate.
I bought a morse controller off the Bayfield list for 50 bucks. If you search craiglist (best is craiggers.com<http://craiggers.com>) or ebay they do show up.
dn… [at] comcast.net2012-02-15 18:25 UTC
Concur to both of you!!
Kind of why I like sailboats over motorboats -- it actually takes learning a skill to get the best out of a sailboat.
PS I am tired of media being "dumbed down" to the market. Print intelligent articles and make the rabble learn how to read it!
Sent: Wednesday, February 15, 2012 8:14:39 AM
2) "Design a system that even a fool can use, and only a fool will use it!"
If I had a dollar for every time I've seen that proven...... I'd be sailing a
"It is easy to design something to be "Fool-Proof", but impossible to make it "Damn Fool-Proof!"
1970 CAL 21 #285
On Wed, 15 Feb 2012 15:45:04 +0000 < ti… [at] ch2m.com > writes:
A common mistake that people make when trying to design something completely idiot proof was to underestimate the ingenuity of complete idiots.
Cheers,
Timm Lessley
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of John Courter
I have the Spinlock. Works fine, I like it. Hasn't stopped inexperienced crew from shifting at high rpms. You can move it from full forward to full reverse before the engine has hardly begun to slow down.
John
I am looking for a single lever combined shift and fuel control to use at the steering pedestal of my sailboat. Edson builds one, but if I use it I canot use the steering brake on my old non-edson pedestal (and a new Edson control is quite pricey).
Why do I want one, you ask? To avoid having high RPM shifts from forward to reverse or the opposite. Inexperienced crew, and sometimes over-reved experienced crew, sometimes forget to reduce fuel before shifting, thereby having the potential to cause much drivetrain damage.
consumerproducts.com
chris1232012-02-15 18:26 UTC
I hear ya....but...ya know there has to be a butt..:)
Yanmar specs a single lever controller for several engines like the 2QM15
and others to ensure proper engine handling on the one and two cylinder
engines. The one I purchase a while back was a two lever unit and you can
setup the detante in combination with the cable to get it working properly,
forward, neutral, reverse. Just rev down the engine to the recommended rpm
(the face plate unit still needs a tac) and shift.
Having had an A-4 with old cables and doing and emergency repair in the
winter of 2009 by moving the throttle control off the binnacle, the stock
29 binnacle is a bear to work on, to the lazaratte side and putting in a
new morse high end cable, smooth as butter. When the engine went on me in
Cape May, rebuilding here on the water, the trani got all screwed up by the
addition of Marvel Mystery fluid, saved the engine but too slippery for the
A-4 trani. Six oil changes later, after six to get the water out, including
sucking out the trani each time, and two days later, the proper detante was
achived on a rusty old cable to engage forward neutral and reverse. Bitch
of an experience, but learned soooo much. Its a bear to remove the trani
cable on a 29 binnacle so went with a used morse.
I agree with you Tim, in a race boat where things get harry the Spinlock
system is ideal. For a cost concious cuiser that is not on a schedule nor
rushed outside of an emergency, a morse single lever controller will comply
with the manufactures spec and will be of little trouble. Just my 2
pennies.
Best regards
On Wed, Feb 15, 2012 at 11:22 AM, <ti… [at] ch2m.com> wrote:
RE: [Cal_Boats] single lever shifter/fuel control (Chris H)
ti… [at] ch2m.com2012-02-15 20:28 UTC
Now we all know why there is more than one color at the paint store....
Cheers,
Timm Lessley
Sent: Wednesday, February 15, 2012 11:27 AM
