4 messages2012-02-27 05:43 UTCthrough 2012-02-27 06:32 UTC
RE: [Cal_Boats] Dehumidifiers!
Husar, Charlie [USA] (ASE)2012-02-27 05:43 UTC
Yes, John, I also had one that did not shut down when it froze up. It would then overheat from the ice obstruction. I was afraid to leave it on. There was this handy dumpster… :- ]
As far as longevity goes, one would think that a dehumidifier is meant for a humid environment. Right? However, I think the environment they build for is more like a basement than a boat. I’m sure someone will sell a marine dehumidifier for five times as much money, if not ten.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of John Courter
Sent: Sunday, February 26, 2012 11:53 PM
Subject: Re: [Cal_Boats] dehumidifiers?
My home dehumidifier would turn off the cooling and run the fan until the ice melted off of the coils then resume. It stopped doing that and now runs nonstop with frozen coils. I've stopped using it and haven't gotten rid of it due to the cheapest recycling payment of $25 to get rid of it is 20 miles away. The closer one wants $75.
John
Sent: Sunday, February 26, 2012 3:04 PM
On 2/26/2012 5:39 PM, ai… [at] aol.com<mailto:ai… [at] aol.com> wrote:
I have never experienced my dehumidifier shutting down below 65 degrees.
Dehumidifiers are basically little refrigerators. They use a compressor to cool a coil of tubing, and moisture condenses on the coil. When the ambient temperature drops too much, the moisture freezes on the cooled coil. When too much ice builds up, the device stops working. They have some sort of sensor to shut off when the thing freezes up.
Re: [Cal_Boats] Dehumidifiers!
Allen Edwards2012-02-27 06:12 UTC
> money, if not ten.****
This one is only 2x5 times as much. Does that make it half price?
http://www.defender.com/product.jsp?path=-1|6880|48359|328481&id=183451
I see that one has its performance specified -- at 80 degrees F @ 60%
relative humidity
I am beginning to think the market for these things is Florida in the
summer, not San Francisco in the winter.
Maybe I will go back to the ventilation theory. That theory says that the
best you can do is to keep the boat at the same humidity as outside by
moving air around and if you close it up, it will go to 100%. Those little
heaters with fans are not trying to heat the air, they are trying to create
convection currents to move the air around.
Back to the drawing board. Great discussion, btw.
Husar, Charlie [USA] (ASE)2012-02-27 06:19 UTC
Allen, the nominal on that part is 300 cubic feet. Even the inside of a CAL 20 is bigger than that?
Sent: Monday, February 27, 2012 1:12 AM
Subject: Re: [Cal_Boats] Dehumidifiers!
I'm sure someone will sell a marine dehumidifier for five times as much money, if not ten.
http://www.defender.com/product.jsp?path=-1|6880|48359|328481&id=183451<http://www.defender.com/product.jsp?path=-1%7C6880%7C48359%7C328481&id=183451>
I see that one has its performance specified -- at 80 degrees F @ 60% relative humidity
I am beginning to think the market for these things is Florida in the summer, not San Francisco in the winter.
Maybe I will go back to the ventilation theory. That theory says that the best you can do is to keep the boat at the same humidity as outside by moving air around and if you close it up, it will go to 100%. Those little heaters with fans are not trying to heat the air, they are trying to create convection currents to move the air around.
Allen Edwards2012-02-27 06:32 UTC
I think that is probably close to what mine is. But doesn't matter, I am
not spending $500 on one that might freeze up.
Back to the vent idea.
On Sun, Feb 26, 2012 at 10:19 PM, Husar, Charlie [USA] (ASE) <
> CAL 20 is bigger than that?****
> Cheers****
> Charlie****
> Behalf Of *Allen Edwards
> *Sent:* Monday, February 27, 2012 1:12 AM
> *Subject:* Re: [Cal_Boats] Dehumidifiers!****
> much money, if not ten.****
> This one is only 2x5 times as much. Does that make it half price?****
> http://www.defender.com/product.jsp?path=-1|6880|48359|328481&id=183451***
> relative humidity ****
> summer, not San Francisco in the winter.****
> convection currents to move the air around.****
> Back to the drawing board. Great discussion, btw.****
> Allen****
