2 messages2012-03-08 14:01 UTCthrough 2012-03-08 17:44 UTC
Re: Battery Technology
Alfred Poor2012-03-08 14:01 UTC
Charlie, a couple points:
First, the standard silicon-crystal solar cells do need to be pointed at the
sun to work best, and they are expensive. The next generation of
photovoltaics includes technologies that can actually be "painted" onto a
surface. One approach uses "dye-sensitized cells" whose main ingredient is
the same stuff we use in toothpaste (so it's really cheap). One of the
largest metal building manufacturers already has pilot production for
coating panels with this stuff, and the cool thing is that while it is less
efficient than silicon cells when aimed right at the sun, they continue to
generate power even under low-light conditions. So even a north-facing wall
can be used to generate useful power on a cloudy day. Imagine if your deck
and cabin were painted with this stuff!
The other point is about energy storage. I think that using chemistry to
store large amounts of energy in a small, lightweight device is the actual
definition of "a bomb". I'm just sayin'.
Alfred Poor
RE: [Cal_Boats] Re: Battery Technology
Husar, Charlie [USA] (ASE)2012-03-08 17:44 UTC
Great point, Alfred. I am going to research amatol-based storage methods for my boat. I'll get back to you (if I'm still around).
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Alfred Poor
Sent: Thursday, March 08, 2012 9:01 AM
Subject: [Cal_Boats] Re: Battery Technology
First, the standard silicon-crystal solar cells do need to be pointed at the sun to work best, and they are expensive. The next generation of photovoltaics includes technologies that can actually be "painted" onto a surface. One approach uses "dye-sensitized cells" whose main ingredient is the same stuff we use in toothpaste (so it's really cheap). One of the largest metal building manufacturers already has pilot production for coating panels with this stuff, and the cool thing is that while it is less efficient than silicon cells when aimed right at the sun, they continue to generate power even under low-light conditions. So even a north-facing wall can be used to generate useful power on a cloudy day. Imagine if your deck and cabin were painted with this stuff!
The other point is about energy storage. I think that using chemistry to store large amounts of energy in a small, lightweight device is the actual definition of "a bomb". I'm just sayin'...
Alfred Poor
