Re: '70 Cal 34 sail dilemma
3 messages2012-03-19 15:01 UTCthrough 2012-03-20 12:44
Alfred Poor2012-03-19 15:01 UTC
DISCLAIMER: I have a financial interest in Reef Rite products. Thanks for mentioning the Kiwi Slides, John. I took over the role as the North American importer for them from the late Brian Cleverly a number of years ago. The website is www.reefrite-na.com, and I'll be happy to answer any questions off-list. We used Kiwi Slides on our Cal 29, "Pentaquod". The thing that I loved about the slides (long before I took over importing them) is that you have all the control of a hanked-on sail, but with the convenience of roller furling when you want it. Let me also point out that the slides come in different sizes, and can work with other furlers. You do not need to have a Reef Rite furler to use the Kiwi Slides. Alfred Poor 1973 Tartan 34C #288 "Jambalaya" ap… [at] verizon.net Reef rite makes neat system called Kiwi slides these can be sewn onto the sail at the hank locations and then the sail can be used on a roller furling bolt rope slot. The reef rite downloader system allows for quick change of sails. Check out their website. I like their design on the reefing system. John Raxter Venture Construction 336-210-8073 (m)
Re: [Cal_Boats] Re: '70 Cal 34 sail dilemma
John Courter2012-03-19 17:50 UTC
I looked at the reefrite site and am trying to figure out the slide capture. Is it just a gate that can open and close so the slides stay on when lowered, then you open the gate and pull the slides out when you're ready to stow the sail? I thought I saw a system where there was a removable section of track that you left the slides on. You had a track section dedicated to each sail and you just clipped on the track and raised the sail. John From: Alfred Poor <ap… [at] verizon.net> To: Ca… [at] yahoogroups.com Sent: Monday, March 19, 2012 8:01 AM Subject: [Cal_Boats] Re: '70 Cal 34 sail dilemma DISCLAIMER: I have a financial interest in Reef Rite products. Thanks for mentioning the Kiwi Slides, John. I took over the role as the North American importer for them from the late Brian Cleverly a number of years ago. The website is www.reefrite-na.com, and I’ll be happy to answer any questions off-list. We used Kiwi Slides on our Cal 29, “Pentaquod”. The thing that I loved about the slides (long before I took over importing them) is that you have all the control of a hanked-on sail, but with the convenience of roller furling when you want it. Let me also point out that the slides come in different sizes, and can work with other furlers. You do not need to have a Reef Rite furler to use the Kiwi Slides. Alfred Poor 1973 Tartan 34C #288 “Jambalaya” ap… [at] verizon.net Reef rite makes neat system called Kiwi slides these can be sewn onto the sail at the hank locations and then the sail can be used on a roller furling bolt rope slot. The reef rite downloader system allows for quick change of sails. Check out their website. I like their design on the reefing system. John Raxter Venture Construction 336-210-8073 (m)
aepoor2012-03-20 12:44
The "Downloader" is specific to Reef Rite furlers, and it creates a gate by rotating an opening to provice access to the foil slots to load or remove a sail (either luff tape or Kiwi Slides), and then rotates around to create a continuous foil slot so that the sail cannot be removed. Other furlers have other designs, such as a removable tapered opening that makes it easier to feed a luff tape into the foil slots. Alfred --- In Ca… [at] yahoogroups.com, John Courter <cal40john@...> wrote: > > I looked at the reefrite site and am trying to figure out the slide capture.  Is it just a gate that can open and close so the slides stay on when lowered, then you open the gate and pull the slides out when you're ready to stow the sail? > > I thought I saw a system where there was a removable section of track that you left the slides on.  You had a track section dedicated to each sail and you just clipped on the track and raised the  sail. > > > John > > > ________________________________ > From: Alfred Poor <apoor@...> > To: Ca… [at] yahoogroups.com > Sent: Monday, March 19, 2012 8:01 AM > Subject: [Cal_Boats] Re: '70 Cal 34 sail dilemma > > >  > DISCLAIMER: I have a financial interest in Reef Rite products. >  > Thanks for mentioning the Kiwi Slides, John. I took over the role as the North American importer for them from the late Brian Cleverly a number of years ago. The website is www.reefrite-na.com, and I’ll be happy to answer any questions off-list. >  > We used Kiwi Slides on our Cal 29, “Pentaquod”. The thing that I loved about the slides (long before I took over importing them) is that you have all the control of a hanked-on sail, but with the convenience of roller furling when you want it. Let me also point out that the slides come in different sizes, and can work with other furlers. You do not need to have a Reef Rite furler to use the Kiwi Slides. >  > Alfred Poor > 1973 Tartan 34C #288 “Jambalaya” > apoor@... >  >  > ------ Original Message ------ >  > Reef rite makes neat system called Kiwi slides these can be sewn onto the sail at the hank locations and then the sail can be used on a roller furling bolt rope slot. The reef rite downloader system allows for quick change of sails. > > Check out their website. I like their design on the reefing system. > > John Raxter > Venture Construction > 336-210-8073 (m) >
