9 messages2012-04-03 20:01 UTCthrough 2012-04-04 01:24 UTC
Re: [Cal_Boats] Cutlass bearing and prop installation
Rodney G. Johnson2012-04-03 20:01 UTC
I sincerely doubt that your shaft is BRASS, it might be Monel, it may be
Bronze, it may be Stainless Steel, but I doubt that it would be Brass.
Brass is an alloy of Copper and Zinc, and would not seem strong enough to
serve as a prop shaft on a full-size (as opposed to scale model) boat. I
would expect it to be too soft. The zinc would (I expect) leach out of
the Brass leaving just copper (and quite porous copper at that!) with any
stray electrolytic currents.
Bronze is an alloy of Copper and Tin.
My memory of older boats recalls hearing of shafts made from Monel, and
Stainless, and perhaps some Bronze. Perhaps Joe DeMers could chime in
here?
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II #10201
former co-owner of "NODROG"
1970 CAL 21 #285
On Tue, 3 Apr 2012 11:20:17 -0700 "Mark Alan Stahnke \(MAS Consulting\)"
<ma… [at] cox.net> writes:
You can confirm the alloy differences in the ASTM American Society of
Testing Materials Non Ferrous Metals book. But as I recall generally
speaking, bronzes will have significantly more copper base metal or
cathode material and the brass will have less copper and much more zinc
and lead and other trace components which contribute to its anodic or
sacrificial qualities. Example: When designing a multiple component
pressure vessel such as a bronze valve, the internal working mechanism
would be designed to fail prior to the body. The anodic and cathode value
in the stem is inherently less noble than that of the body. A valve that
will not close is usually safer than a body separation.
With that said, I would think the shaft should be more noble alloy than
the propeller.
Mark
Cal 2-29
Sent: Tuesday, April 03, 2012 4:53 AM
Subject: RE: [Cal_Boats] Cutless bearing and prop installation
I guess I still don't know what to do, it's now back on dry, but that can
easily be changed. Does anyone's thoughts change if it is a bronze prop
on a brass shaft?
Thanks
Bob
Behalf Of mike farrell
Sent: Tuesday, April 03, 2012 6:10 AM
Subject: Re: [Cal_Boats] Cutless bearing and prop installation
Hi Joe,
Would Lanicote be a better choice? How would a lube improve the
conductivity of a bare SS shaft and a bare bronze prop?
My Best, Mike Farrell
Sent: Monday, April 2, 2012 7:51 PM
It would be nice if they were not electrically connected to each other so
a dielectric grease like Super Lube might be a good choice. If you could
keep them completely electrically insulated, you would not need a zinc.
But you can't. But putting a conductive grease between them is certainly
just a way to increase electrolysis.
On Mon, Apr 2, 2012 at 7:17 PM, Joe DeMers <je… [at] mindspring.com>
wrote:
Hi Mike -
I checked with the booklet "prop and shaft installation guide" published
by prop and shaft makers. I stand corrected.
They say it is permissible to use a thin layer of waterproof grease on
the shaft taper. It does not say this grease is mandatory.
I suggest that anything containing graphite [ electrically conductive ]
or anti seize compounds [ contain metal particles that may also be
conductive, and / or may act as grit ] should not be used.
Joe DeMers
On 4/2/2012 7:52 PM, mike farrell wrote:
For 50 years I have used Never Sieze or another lube on SS shafts and
props. I will continue to do so. To install a bronze prop with no lube
is irresponsible. You are wrong Joe! Stationary Engineer with 50 years
experience.
Sent: Monday, April 2, 2012 6:53 AM
ALWAYS install a prop dry. Any lubricant, burrs, or grit on the shaft
taper will defeat the purpose of the shaft / prop fit.
The taper of the shaft and bore of the prop must make at least 75% even
contact, or you risk the prop rattling on the shaft taper, and / or the
shaft and prop not rotating concentrically.
Remember, the correct fit of the prop on the shaft is primary, the shaft
key is there as a backup only. DO NOT rely on the shaft key as the
primary means of securing the prop to the shaft, as eventually, the key
will wear, and the prop will be hammering itself off the shaft.
Joe DeMers - owner
Sound Marine Diesel LLC
SoundMarineDiesel.com
phone & fax (860) 666-2184
On 4/1/2012 11:10 PM, Bob Ellison wrote:
I replaced the cutless bearing this afternoon. I made a tool similar to
the "strut pro" tool. I posted some photos in a folder called 1980 Cal
2-27 Après Ski. The actual bearing replacement went very smoothly, and
the tool worked excellent. I watched a couple people fight with their
bearings a few years ago. There are no set screws on this strut, so it
is a tight fit. The bearing replacement took an hour and 10 minutes and
that was with me taking a couple breaks to stand up, one being about 15
minutes talking to the other crazy couple working on their boat. It was
about 40 degrees and raining in central New York today, but the yard
wants me in this week. If I had a second person so that we could tighten
each side at the same time it would have been really quick. It is for a
1" shaft with a 1.25" OD bearing. The slot is just enough to fit over
the shaft, the hole at the end was made with a 1" hole saw with a hand
drill so it is slightly larger than 1" diameter. The hole at the other
end was done the same way with a 3/8" hole saw. The black plastic piece
was just to hold it in place knowing I would be working by myself. The
part that pushes the bearing out was a piece of 1" electrical conduit cut
in half and lined with Velcro to shim it and make sure it stayed off the
shaft. A 1" dia. washer pushed the bearing back in. The only thing I
needed to do was slip the new bearing on the end of the shaft to align
the hole when I put the tool on. The L4 x 4 x 3/8 is overkill but the
price was right. A small fraction of the cost of the commercial tool,
and it was fun to make.
Getting to that point was a different story. I fought the prop more than
I thought I would and broke a harbor freight gear puller yesterday in the
process. It is going back on with some anti-seize.
Bob Ellison
Joe DeMers - owner
Joe DeMers - owner
__________ Information from ESET NOD32 Antivirus, version of virus
signature database 7021 (20120402) __________
http://www.eset.com
http://www.eset.com
57 Year Old Looks 27
Local Woman Reveals Wrinkle Secret That Has Doctors Angry.
http://thirdpartyoffers.juno.com/TGL3141/4f7b5767d2b3e3347719st06duc
Michael D2012-04-03 20:09 UTC
Magic, our 1979 Cal 2-27 had a 1" bronze propeller shaft. I replaced it with a SS shaft when we repowered her in early 2004. At that time there was nothing wrong with the shaft, except it was not long enough for the new engine/transmission configuration.
Sent: Tuesday, April 3, 2012 4:01 PM
Subject: Re: [Cal_Boats] Cutlass bearing and prop installation
serve as a prop shaft on a full-size (as opposed to scale model) boat. I would
expect it to be too soft. The zinc would (I expect) leach out of the Brass
leaving just copper (and quite porous copper at that!) with any stray
here?
1970 CAL 21 #285
>You can confirm the alloy differences in the ASTM American Society of Testing Materials Non Ferrous Metals book. But as I recall generally speaking, bronzes will have significantly more copper base metal or cathode material and the brass will have less copper and much more zinc and lead and other trace components which contribute to its anodic or sacrificial qualities. Example: When designing a multiple component pressure vessel such as a bronze valve, the internal working mechanism would be designed to fail prior to the body. The anodic and cathode value in the stem is inherently less noble than that of the body. A valve that will not close is usually safer than a body separation.
>With that said, I would think the shaft should be more noble alloy than the propeller.
>Mark
>Cal 2-29
>----- Original Message -----
>>From: Bob Ellison
>>I guess I still don't know what to do, it's now back on dry, but that can easily be changed. Does anyone's thoughts change if it is a bronze prop on a brass shaft?
>>Thanks
>>Bob
>>________________________________
>> From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of mike farrell
>> Hi Joe,
>> Would Lanicote be a better choice? How would a lube improve the conductivity of a bare SS shaft and a bare bronze prop?
>>From: Allen Edwards <al… [at] gmail.com>
each other so a dielectric grease like Super Lube might be a good choice.
If you could keep them completely electrically insulated, you would
not need a zinc. But you can't. But putting a conductive grease
between them is certainly just a way to increase electrolysis.
>>Allen
>>On Mon, Apr 2, 2012 at 7:17 PM, Joe DeMers <je… [at] mindspring.com> wrote:
>>>Hi Mike -
installation guide" published by prop and shaft makers. I stand corrected.
grease on the shaft taper. It does not say this grease is mandatory.
conductive ] or anti seize compounds [ contain metal particles that may
also be conductive, and / or may act as grit ] should not be used.
>>>Joe DeMers
>>>> For 50 years I have used Never Sieze or another lube on SS shafts and props. I will continue to do so. To install a bronze prop with no lube is irresponsible. You are wrong Joe! Stationary Engineer with 50 years experience.
>>>>From: Joe DeMers <je… [at] mindspring.com>
grit on the shaft taper will defeat the purpose of the shaft /
prop fit.
at least 75% even contact, or you risk the prop rattling on the shaft
taper, and / or the shaft and prop not rotating concentrically.
the shaft key is there as a backup only. DO NOT rely on the shaft key as
the primary means of securing the prop to the shaft, as eventually, the
key will wear, and the prop will be hammering itself off the shaft.
>>>>Joe DeMers - owner
>>>>Sound Marine Diesel LLC SoundMarineDiesel.com
>>>>I replaced the cutless bearing this afternoon. I made a tool similar to the "strut pro" tool. I posted some photos in a folder called 1980 Cal 2-27 Après Ski. The actual bearing replacement went very smoothly, and the tool worked excellent. I watched a couple people fight with their bearings a few years ago. There are no set screws on this strut, so it is a tight fit. The bearing replacement took an hour and 10 minutes and that was with me taking a couple breaks to stand up, one being about 15 minutes talking to the other crazy couple working on their boat. It was about 40 degrees and raining in central New York today, but the yard wants me in this week. If I had a second person so that we could tighten each side at the same time it would have been really quick. It is for a 1" shaft with a 1.25" OD bearing. The slot is just enough to fit over the shaft, the hole at the end was made with a 1" hole saw with a
hand drill so it is slightly larger than 1" diameter. The hole at the other end was done the same way with a 3/8" hole saw. The black plastic piece was just to hold it in place knowing I would be working by myself. The part that pushes the bearing out was a piece of 1" electrical conduit cut in half and lined with Velcro to shim it and make sure it stayed off the shaft. A 1" dia. washer pushed the bearing back in. The only thing I needed to do was slip the new bearing on the end of the shaft to align the hole when I put the tool on. The L4 x 4 x 3/8 is overkill but the price was right. A small fraction of the cost of the commercial tool, and it was fun to make.
>>>>>Getting to that point was a different story. I fought the prop more than I thought I would and broke a harbor freight gear puller yesterday in the process. It is going back on with some anti-seize.
>>>>>Bob Ellison
>>>>Joe DeMers - owner
>>>Joe DeMers - owner
>>>Sound Marine Diesel LLCSoundMarineDiesel.com
version of virus signature database 7021 (20120402) __________
>>The
>>http://www.eset.com
>__________
Information from ESET NOD32 Antivirus, version of virus signature database
Antivirus.
>http://www.eset.com
TheSmartStyleLiving.com
Allen Edwards2012-04-03 20:59 UTC
Monel is copper and nickel but looks more like stainless than bronze. It
is a very nice material but is electrically much like stainless.
> would expect it to be too soft. The zinc would (I expect) leach out of the
> Brass leaving just copper (and quite porous copper at that!) with any stray
> Stainless, and perhaps some Bronze. Perhaps Joe DeMers could chime in here?
> 1970 CAL 21 #285
> On Tue, 3 Apr 2012 11:20:17 -0700 "Mark Alan Stahnke \(MAS Consulting\)" <
> the propeller.
> Mark
> Cal 2-29
> *From:* Bob Ellison <bo… [at] adelphia.net>
> *Sent:* Tuesday, April 03, 2012 4:53 AM
> *Subject:* RE: [Cal_Boats] Cutless bearing and prop installation
> a brass shaft?
> Thanks
> Bob
> Behalf Of *mike farrell
> *Sent:* Tuesday, April 03, 2012 6:10 AM
> *Subject:* Re: [Cal_Boats] Cutless bearing and prop installation
> Hi Joe,
> *Sent:* Monday, April 2, 2012 7:51 PM
> Allen
> **Hi Mike -
> They say it is permissible to use a thin layer of waterproof grease on the
> I suggest that anything containing graphite [ electrically conductive ] or
> anti seize compounds [ contain metal particles that may also be conductive,
> Joe DeMers
> years experience.
> *From:* Joe DeMers <je… [at] mindspring.com> <je… [at] mindspring.com>
> *Sent:* Monday, April 2, 2012 6:53 AM
> key is there as a backup only. DO NOT rely on the shaft key as the primary
> means of securing the prop to the shaft, as eventually, the key will wear,
> *Joe DeMers - owner *
> SoundMarineDiesel.com <http://www.soundmarinediesel.com/>
> *phone & fax (860) 666-2184 *
> end was made with a 1" hole saw with a hand drill so it is slightly larger
> Bob Ellison
> *Joe DeMers - owner*
> *phone & fax (860) 666-2184*
> http://www.eset.com
> http://www.eset.com
> ____________________________________________________________
> *57 Year Old Looks 27*
> <http://thirdpartyoffers.juno.com/TGL3142/4f7b5767d2b3e3347719st06duc>
> TheSmartStyleLiving.com<http://thirdpartyoffers.juno.com/TGL3142/4f7b5767d2b3e3347719st06duc>
Chris Campbell2012-04-03 21:06 UTC
> It is a very nice material but is electrically much like stainless.
And about the same price as gold, as I recall.
Re: [Cal_Boats] Martec folding prop
Mark Alan Stahnke (MAS Consulting)2012-04-03 22:04 UTC
I found a used Martec folding prop and it appears to be the size for my cal 2-29. How do I inspect to verify it is in good working order? and correct size for the A30 Farymann..I believe it is a 12" prop not sure if there are different pitch options for the basic prop?
Appreciate any feed back.
Mark
Sent: Tuesday, April 03, 2012 2:06 PM
Monel is copper and nickel but looks more like stainless than bronze. It is a very nice material but is electrically much like stainless.
__________ Information from ESET NOD32 Antivirus, version of virus signature database 7024 (20120403) __________
http://www.eset.com
http://www.eset.com
Somebody selling new Cal 25 Genny for cheap
Gerald Sobel2012-04-03 22:10 UTC
kt… [at] sale.craigslist.org
Wow, such a deal. Used once. Why don't anyone have such a sail for me?
I know, keep lookin'
Allen Edwards2012-04-03 23:15 UTC
I just bought a new Martec prop so will have the old one to sell. Please
keep me informed about what you find about the used prop market. Mine is
probably a 14RH7 but I won't know for sure until next week. My new one is
a 14RH10.
Thanks
On Tue, Apr 3, 2012 at 3:04 PM, Mark Alan Stahnke (MAS Consulting) <
> Mark
> *From:* Chris Campbell <cc… [at] lsnm.org>
> *Sent:* Tuesday, April 03, 2012 2:06 PM
> *Subject:* Re: [Cal_Boats] Cutlass bearing and prop installation
> Chris Campbell
> http://www.eset.com
> http://www.eset.com
Mark Alan Stahnke (MAS Consulting)2012-04-04 00:02 UTC
Not sure if a used propeller purchase is worth it since for martec to rebuild is ala cart and could run the cost up significantly ...must say the low initial cost is tempting.
Mark
Sent: Tuesday, April 03, 2012 4:15 PM
Subject: Re: [Cal_Boats] Martec folding prop
I just bought a new Martec prop so will have the old one to sell. Please keep me informed about what you find about the used prop market. Mine is probably a 14RH7 but I won't know for sure until next week. My new one is a 14RH10.
Thanks
On Tue, Apr 3, 2012 at 3:04 PM, Mark Alan Stahnke (MAS Consulting) <ma… [at] cox.net> wrote:
Mark
http://www.eset.com
http://www.eset.com
http://www.eset.com
http://www.eset.com
Helen Horn2012-04-04 01:24 UTC
ours was a pink colored shaft (Cal 29) who knows bronze, monel we went with stainless (used) off speedboat
'the prop shop' picked the best one and kept the taper end and cut down to fit...we 1st went with indeigo 3 blade
then when with max prop still working great 6 seasons latter edward
Sent: Tuesday, April 3, 2012 1:01 PM
here?
1970 CAL 21 #285
>Mark
>Cal 2-29
>>From: Bob Ellison
>>Thanks
>>Bob
>> Hi Joe,
>>Allen
>>>Hi Mike -
>>>Joe DeMers
prop fit.
>>>>Joe DeMers - owner
>>>>>Bob Ellison
>>>>Joe DeMers - owner
>>>Joe DeMers - owner
>>The
>>http://www.eset.com
>__________
Antivirus.
>http://www.eset.com
