7 messages2012-04-12 17:17 UTCthrough 2012-04-15 13:46 UTC
Cleaning your bilge... (that last bit)
Dylan Crouch2012-04-12 17:17 UTC
I am always surprised how many people leave a bit of
water in the bottom of the bilge. It gets gross down there. Maybe I am being
uptight about it, but I use a trick I thought I would share in case anyone can
use this.
As we all know a typical bilge pumps leave a
bit of water, they can’t get it all out.
I keep a wet/dry vac on the boat or on the
locker next to it & use it whenever I get a bit of water down there I vacuum
it out. Getting down there is the trick. I have a length of PVC pipe which
reaches down to the bottom of the bilge which is pretty close to the diameter
of the end of vacuum hose. I just break out the vacuum and slide it over the
end of the PVC sealing it with my hand around the end. Or you can wrap a strip
of tape holding the PVC into the hose.
Using this method also gives you a “wand” that
you can point into the corners & get where you want.
I usually just leave the PVC pipe down there
too for convenience. It does not get in the way or flop around. Been a good place
to keep it. You want to wash your bilge, throw a bucket of soapy water down
there & vacuum it out.
When I am wet-vacing, I always used a strip of
tape to hole the PVC in which also makes an airtight seal. I got lazy and attached
a PVC fitting onto the end of my hose. Now I just slide on the PVC pipe length
into the end & it stays.
A last thought, fiberglass absorbs water. I was
lucky enough to have a PO put (or maybe Jenson did this at the factory) a thick
coat of gray paint covering most of my deeper bilge area. Really helps. I have a
squeaky clean bilge with next to zero work.
Cheers –
Dyer
CAUTION [ was Cleaning your bilge... (that last bit)
Joe DeMers2012-04-12 17:48 UTC
Be VERY CAREFUL when using any non ignition proofed devise on a boat
that has gasoline or propane aboard. The US Coast guard approves
ignition protected marine devises, such as electrical switches, bilge
pumps, electric motors, etc. These approved devises carry the USCG
certification.
Wet Vacs are NOT USCG approved, and will ignite gas fumes. The
resultant explosion will be deafening. [ at the very least ]
I can live with a bit of residual water in my bilge.
Joe DeMers
On 4/12/2012 1:17 PM, Dylan Crouch wrote:
> I am always surprised how many people leave a bit of water in the
> anyone can use this.
> As we all know a typical bilge pumps leave a bit of water, they can’t
> get it all out.
> I keep a wet/dry vac on the boat or on the locker next to it & use it
> whenever I get a bit of water down there I vacuum it out. Getting down
> there is the trick. I have a length of PVC pipe which reaches down to
> the bottom of the bilge which is pretty close to the diameter of the
> a strip of tape holding the PVC into the hose.
> Using this method also gives you a “wand” that you can point into the
> I usually just leave the PVC pipe down there too for convenience. It
> does not get in the way or flop around. Been a good place to keep it.
> You want to wash your bilge, throw a bucket of soapy water down there
> & vacuum it out.
> When I am wet-vacing, I always used a strip of tape to hole the PVC in
> which also makes an airtight seal. I got lazy and attached a PVC
> length into the end & it stays.
> A last thought, fiberglass absorbs water. I was lucky enough to have a
> PO put (or maybe Jenson did this at the factory) a thick coat of gray
> Cheers –
> Dyer
*Joe DeMers - owner*
Sound Marine Diesel LLC
*phone & fax (860) 666-2184*
Re: [Cal_Boats] CAUTION [ was Cleaning your bilge... (that last bit)
Allen Edwards2012-04-12 20:08 UTC
Everyone with a gas boat should make sure they know what gas smells like.
Toss a thimble full in the street and make sure you stop doing everything
you are doing and find the source if you ever smell that on your boat. Run
the blower and smell the exhaust before starting the engine. If it smells
like gas, see above. Also, make sure that the blower is actually blowing
air. I have had my intake for the blower completely under water and no air
flowing.
That said, I had never considered what Joe was saying as I run my vac all
the time on Papoose. But she has never leaked gas since I replaced the
tank 20 years ago. I am replacing it once again in about a week.
On Thu, Apr 12, 2012 at 10:48 AM, Joe DeMers <je… [at] mindspring.com> wrote:
> ** Be VERY CAREFUL when using any non ignition proofed devise on a boat
> that has gasoline or propane aboard. The US Coast guard approves ignition
> protected marine devises, such as electrical switches, bilge pumps,
> electric motors, etc. These approved devises carry the USCG certification.
> Wet Vacs are NOT USCG approved, and will ignite gas fumes. The resultant
> Joe DeMers
> bottom of the bilge. It gets gross down there. Maybe I am being uptight
> about it, but I use a trick I thought I would share in case anyone can use
> this.
> As we all know a typical bilge pumps leave a bit of water, they can’t get
> it all out.
> there is the trick. I have a length of PVC pipe which reaches down to the
> bottom of the bilge which is pretty close to the diameter of the end of
> vacuum hose. I just break out the vacuum and slide it over the end of the
> PVC sealing it with my hand around the end. Or you can wrap a strip of tape
> I usually just leave the PVC pipe down there too for convenience. It does
> not get in the way or flop around. Been a good place to keep it. You want
> to wash your bilge, throw a bucket of soapy water down there & vacuum it
> out.
> which also makes an airtight seal. I got lazy and attached a PVC fitting
> onto the end of my hose. Now I just slide on the PVC pipe length into the
> end & it stays.
> A last thought, fiberglass absorbs water. I was lucky enough to have a PO
> put (or maybe Jenson did this at the factory) a thick coat of gray paint
> covering most of my deeper bilge area. Really helps. I have a squeaky clean
> Cheers –
> Dyer
mike farrell2012-04-12 21:32 UTC
How about a sponge!
Sent: Thursday, April 12, 2012 10:48 AM
Subject: [Cal_Boats] CAUTION [ was Cleaning your bilge... (that last bit)
Be VERY CAREFUL when using any non ignition proofed devise on a boat that has gasoline or propane aboard. The US Coast guard approves ignition protected marine devises, such as electrical switches, bilge pumps, electric motors, etc. These approved devises carry the USCG certification.
Wet Vacs are NOT USCG approved, and will ignite gas fumes. The resultant explosion will be deafening. [ at the very least ]
Joe DeMers
I am always surprised how many people leave a bit of water in the bottom of the bilge. It gets gross down there. Maybe I am being uptight about it, but I use a trick I thought I would share in case anyone can use this.
>As we all know a typical bilge pumps leave a bit of water, they can’t get it all out.
>I keep a wet/dry vac on the boat or on the locker next to it & use it whenever I get a bit of water down there I vacuum it out. Getting down there is the trick. I have a length of PVC pipe which reaches down to the bottom of the bilge which is pretty close to the diameter of the end of vacuum hose. I just break out the vacuum and slide it over the end of the PVC sealing it with my hand around the end. Or you can wrap a strip of tape holding the PVC into the hose.
>Using this method also gives you a “wand” that you can point into the corners & get where you want.
>I usually just leave the PVC pipe down there too for convenience. It does not get in the way or flop around. Been a good place to keep it. You want to wash your bilge, throw a bucket of soapy water down there & vacuum it out.
>When I am wet-vacing, I always used a strip of tape to hole the PVC in which also makes an airtight seal. I got lazy and attached a PVC fitting onto the end of my hose. Now I just slide on the PVC pipe length into the end & it stays.
>A last thought, fiberglass absorbs water. I was lucky enough to have a PO put (or maybe Jenson did this at the factory) a thick coat of gray paint covering most of my deeper bilge area. Really helps. I have a squeaky clean bilge with next to zero work.
>Cheers –
> Dyer
Joe DeMers - owner
Sound Marine Diesel LLCSoundMarineDiesel.com
Mark Alan Stahnke (MAS Consulting)2012-04-13 02:15 UTC
I have found that a couple gallons of white vinegar dumped into a rancid smelling bilge for a few days then add a few gallons of salt water and pump it all out. However, if you have fuel or oil in the bilge you may want to pump into containers and dispose of properly. I usually chase that concoction with some orange de solv to freshen up and remove any vinegar odors. This seems to work well in the deep bilge of the Cal 29.
Mark
Cal 2-29
Joe DeMers
Cheers –
Dyer
Joe DeMers - owner
__________ Information from ESET NOD32 Antivirus, version of virus signature database 7049 (20120412) __________
http://www.eset.com
http://www.eset.com
Sv… [at] optonline.net2012-04-15 12:19 UTC
Without a doubt be careful when dealing with gas and propane..... Always be aware. Any devise including our cell phones and laptops (that are probably not coast guard approved) will cause a bang...... I also use a small portable wet vac to clean the bilge. I have sponges for the minor water around the stuffing box but when I clean it, the vac comes out.
Greg
Date: Thursday, April 12, 2012 10:16 pm
Subject: Re: [Cal_Boats] CAUTION [ was Cleaning your bilge... (that last bit)
> Mark
> Cal 2-29
> From: Joe DeMers
> (that last bit)
> Joe DeMers
> work.
> Cheers –
> Dyer
> Joe DeMers - owner
> http://www.eset.com
> http://www.eset.com
John Courter2012-04-15 13:46 UTC
I'm not going to worry much about cell phones.
http://www.snopes.com/autos/hazards/gasvapor.asp
From: "Sv… [at] optonline.net" <Sv… [at] optonline.net>
Sent: Sunday, April 15, 2012 5:19 AM
Greg
> Mark
> Cal 2-29
> From: Joe DeMers
> (that last bit)
> Joe DeMers
> work.
> Cheers –
> Dyer
> Joe DeMers - owner
> http://www.eset.com
> http://www.eset.com
