3 messages2012-04-20 02:32 UTCthrough 2012-04-20 14:19 UTC
Refinishing Mahogany
david dobbs2012-04-20 02:32 UTC
I am in the process of refinishing the interior of my 29 and I have most of the wood sanded, and it appears to be pretty smooth. I've never heard of "filler stain". I was thinking of just a clear finish, the wood will darken after the finish dries. Now I know why the trim pieces look different, they are teak. Anyway, I've refinished a lot of oak, but that's close grained. Mahogany grain seems to be more open, so a sealer-stain might be in order? On the other hand it's a boat, not a piece of fine furniture, and I want to sail it sometime this year!
Suggestions?
David Dobbs CAL29 411
Re: [Cal_Boats] Refinishing Mahogany
Mark Alan Stahnke (MAS Consulting)2012-04-20 03:14 UTC
My Cal 2-29 Hull 918 has an all Teak interior and the 29 that I raced on has a mahogany interior, not sure about its trim. Was Teak used in the all the 2-29?
For interior wood finish you can use I believe its a paste on bees wax sealer I forget the name but have some on the boat, and sand it into the finish with lighter and lighter wet and dry sand paper depending on the surface condition. To maintain occasionally wipe another coat on. its simple can be used on finished wood or unfinished. It will give a furniture quality finish.
Mark
San Pedro
Sent: Thursday, April 19, 2012 7:32 PM
Subject: [Cal_Boats] Refinishing Mahogany
Suggestions?
__________ Information from ESET NOD32 Antivirus, version of virus signature database 7070 (20120419) __________
http://www.eset.com
http://www.eset.com
Chris Campbell2012-04-20 14:19 UTC
The purpose of the filler stain is to fill the open grain--the little
valleys in the wood. If you varnish without filling, then you have to
apply a lot of coats with sanding between to level out the surface.
Mahogany is fairly opened-grained, which is why the marine stains are
filler-stains. They have a lot of stuff in them, and they come very
thick. You remove some from the can and thin it (don't thin it in the
can--the stuff will no longer stay in suspension if you do). Apply the
filler stain, let it sit as directed, then rub it off cross-grain to
work the filler into the grain.
If you want the mahogany to darken, use the washing soda method before
you apply the filler stain.
