8 messages2012-04-17 15:02 UTCthrough 2012-04-21 20:05 UTC
Re: [Cal_Boats] Opening on Deck of Cal 30
Rodney G. Johnson2012-04-17 15:02 UTC
A replacement cap should be available from the maker of the deck fill
fitting. However.....if that deck fill was original to the boat..... the
make may not be around anymore, or may not produce the fitting anymore.
I'd start by trying to find the maker of the fitting (should be marked on
fitting?), then if that ends up being a dead end, try marine
consignment/surplus shops. Best thing would be the remove the fitting and
glass over the hole.
In the meantime, get a cork and plug the opening, If that is the fuel
fill, and there is any residue in the tank, it will eventually float up
and out of the fitting if you accidently end up filling the tank, also,
if the tank is metal.... that water may lead to corrosion of the tank and
then the mess will be in the bilge.
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II
former co-owner of "NODROG"
1970 CAL 21
On Tue, 17 Apr 2012 09:23:37 -0000 "gaineyphil"
<cu… [at] hawaii.rr.com> writes:
Along the port side of my Cal 30 (towards the aft) there is an opening
for filling up either the fuel or water tank. The cap was missing when I
bought the boat. Like a dummy, I never bothered to replace the cap. So
when I hose down the port side of the deck water goes down that opening
and into either the fuel or water tank. Incidently, neither tank is being
used (have outboard).
Is that for filling water tank, or fuel? Where can get a cap to replace
it?
Thanks
Get Free Email with Video Mail & Video Chat!
http://www.juno.com/freeemail?refcd=JUTAGOUT1FREM0210
Replacement Port for Cal 27 Mark III (1983)
David Field2012-04-17 16:15 UTC
The lens on one of my opening ports has a broken hinge and needs to be replaced. Anyone know what kind of port it is and/or where I might find a replacement? Photo attached.
David
Re: Opening on Deck of Cal 30
gaineyphil2012-04-18 03:24
Thanks.
> 1979 O'DAY DS II
> 1970 CAL 21
> <cullent001@...> writes:
> it?
> Thanks
> ____________________________________________________________
Re: [Cal_Boats] Replacement Port for Cal 27 Mark III (1983) [1 Attachment]
Helen Horn2012-04-18 23:21 UTC
Looks like the original like we are removing from our 36, which are bigger and have 3 hinges not 2. Ours are size 1's if you were buying lewmars, yours might be size 0. Other brands use different size labels. Try measuring the glass size, then the exterior outer edge of the frame. Then go on Google, then look at the right dimensions as you look. also amazon. there are various ones for sale all over the country. be sure to check the shape carefully. As for ours, they are so brittle (1967) that only 3 of 6 still have all the hinges intact, let alone the dogs that lock them.we are going to aluminum frames now. Helen
Sent: Tuesday, April 17, 2012 9:15 AM
Subject: [Cal_Boats] Replacement Port for Cal 27 Mark III (1983) [1 Attachment]
[Attachment(s) from David Field included below]
David
Les Hester2012-04-19 03:36 UTC
David:this looks like a Beckson port. Had two on my 29 and there are two on my current T34c. They sell all of the replacement parts. They are very helpful when you call.
Les Hester
T34C#198
Sable
Rock Hall, Md
> David
RE: [Cal_Boats] Replacement Port for Cal 27 Mark III (1983) [1 Attachment]
john raxter2012-04-21 15:13 UTC
You have had several guesses on the replacement windows. Perhaps this is
the Grey Port available from Pompanette company.
Very similar to the one used on the later 87 version as my Cal 33. The new
ports have incorporated a "rain drain" feature that may require additional
cutout for the cabin.
http://www.pompanette.com/pompweb.nsf/731d6514ff5a8481852567be000745b2/0b6a3
7db4eafbf05852567c400837f28?OpenDocument
happy shopping
John
Of David Field
Sent: Tuesday, April 17, 2012 12:16 PM
Attachment]
David
Bert Pesak2012-04-21 19:25 UTC
I looked at the picture of the port you need . It comes from Beckson
Marine. I was at their Store yesterday. Normally closed on Friday but one
of their employees took care of me.
http://beckson.com/
You can purchase from West Marine or Defender. Possibly direct. I happen
to live in their neighborhood.
Bert Pesak
> the Grey Port available from Pompanette company.****
> new ports have incorporated a “rain drain” feature that may require
> additional cutout for the cabin.****
> http://www.pompanette.com/pompweb.nsf/731d6514ff5a8481852567be000745b2/0b6a37db4eafbf05852567c400837f28?OpenDocument
> happy shopping****
> John****
> Behalf Of *David Field
> *Sent:* Tuesday, April 17, 2012 12:16 PM
> *Subject:* [Cal_Boats] Replacement Port for Cal 27 Mark III (1983) [1
> Attachment]****
> *[Attachment(s) <#136d57791be347bb_TopText> from David Field included
> below]* ****
> replacement? Photo attached.****
> David****
David Field2012-04-21 20:05 UTC
Thanks Bert and John. I've confirmed that they are Beckson Ports and am replacing them. My hatch cover is split and my next move is to see if that, too, isn't a Beckson product. I'm thinking if Cal used Beckson Ports on the boat, they might also have used their hatch covers on the Cal 27 Mark III.
David
Sent: Saturday, April 21, 2012 3:25 PM
Subject: Re: [Cal_Boats] Replacement Port for Cal 27 Mark III (1983)
I looked at the picture of the port you need . It comes from Beckson Marine. I was at their Store yesterday. Normally closed on Friday but one of their employees took care of me.
http://beckson.com/
You can purchase from West Marine or Defender. Possibly direct. I happen to live in their neighborhood.
Bert Pesak
>You have had several guesses on the replacement windows. Perhaps this is the Grey Port available from Pompanette company.
>Very similar to the one used on the later 87 version as my Cal 33. The new ports have incorporated a “rain drain” feature that may require additional cutout for the cabin.
>happy shopping
>John
>From:Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of David Field
>David
