6 messages2006-09-19 22:17 UTCthrough 2012-05-06 04:29
Re: Cal-28 question (Richard Fuller) was steel bilge-beam!
Richard Fuller2006-09-19 22:17 UTC
On my boat the PO cut a inspection port in the glass
pan beam on the head side. The block is glassed in and
on my boat is solid. It is not at the bottom of the
bilge but on the hull just in front of where the keel
starts.
As for removing the pan. I would think you would have
to remove the deck first as the pan goes from aft of
the rudder post to the beginning of the V berth.
Richard Fuller
65 Cal 28 - Old Flat top
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
RE: [Cal_Boats] Re: Cal-28 question (Richard Fuller) was steel bilge-beam!
Bruce Stirling2006-09-19 23:54 UTC
Thanks for the update, Richard. You are an invaluable resource for the Cal
28 fans out here! I tried looking through the bilge once and saw only glass
and no beam.
One additional question, please. You tore your boat apart and have a good
feel for what everything looks like bare. I am interested in trying to
expand the quarter berth areas on both sides of the boat. I have no inboard
motor. I look at the space where it was and wonder about moving the head
aft and having nothing but a huge v-berth cabin. Since I have no holding
tank yet and must soon pay someone to install it, I thought about moving it.
The layout of the newer Cal 28, I believe, shows the head in the stern of
the boat. They claim there is more headroom aft. I am jealous of the
roomier (sp?) quarter berths on the larger boats, and at 6'2", it is a bit
tight getting to the v-berth via the head with my 5'11" clearance. Looks
like the Cal 28 used a bit much of the stern for the cockpit. I do love
that the cockpit, though.
What say you? Have you in any way otherwise modified the original layout of
your boat?
Thanks for your thoughts.
Bruce Stirling
Gangfurd
65 Cal 28 - Hull 82
Of Richard Fuller
Sent: Tuesday, September 19, 2006 3:18 PM
Subject: [Cal_Boats] Re: Cal-28 question (Richard Fuller) was steel
bilge-beam!
starts.
Richard Fuller
Do You Yahoo!?
Richard Fuller2006-09-20 21:40
Hi Bruce
I had thought of major modifications such as re arranging the interior before I started re
coring the deck. After much though I decided that there are some main areas that can't
really be touched. Structurally the main bulkhead is pretty well fixed. Moving either the
head or the galley aft wouldn't really fit without taking space away from the cockpit and
adding it to the cabin, major structural change not to mention balance. Yes the cockpit on
the 28's is huge, but that goes with the 28's intended use as an in shore club racer.
I think Lapworth was more concerned with sail performance and topside comfort than the
interior. He has said in interviews that his designs where often compromises. Trading off
features in one area to improve another. The flat top design of both the 25 and 28 reflect
that. Their hulls have low freeboard and the low decks help with reducing windage and
make deck work more comfortable. Both compromises to interior space that makes for
better sailing comfort and ability.
The off center set up of the interior also makes it difficult to but the head on the galley
side and on either side at the back of the cabin you would be blocking of the quarter berth
which if anything is a huge storage space. We keep our extra sails in the starboard quarter
berth, and use the sail bin/hanging locker forward as a hanging locker only; the stove
alcohol tank is there too. When underway the head in it's current location is closer to the
middle of the boat, which reduces movement. Theoretical consideration maybe but it was
considered in the design I'm sure.
Bottom line was I felt the change would be a lot of work for marginal gain, and possibly
ruining the integrity of the entire boat. I would buy a different boat before going that far I
think.
Richard Fuller
65 Cal - 28 Old Flat Top
> and no beam.
> your boat?
> Bruce Stirling
> Gangfurd
> 65 Cal 28 - Hull 82
> -----Original Message-----
> Of Richard Fuller
> bilge-beam!
> starts.
> Richard Fuller
> __________________________________________________
> Do You Yahoo!?
Re: [Cal_Boats] Re: Cal-28 question (Richard Fuller) was steel bilge-beam!
Sail Away2006-09-21 00:37 UTC
Richard,
What are you planning on recoring your boat with? I just completed a complete deck recore job on my new P36-2.....a ton of fun and to top it off, I now have a new deck!! I cut the top glass off, removed all balsa and used Nidacore instead of wood and reglassed in new non skid. I wanted the boat to have the original non skid and it turned out very nice..
Good luck!
Greg
1977 Cal 34 III-for sale
1986 Pearson P36-2
Sent: Wednesday, September 20, 2006 5:40 PM
Subject: [Cal_Boats] Re: Cal-28 question (Richard Fuller) was steel bilge-beam!
Hi Bruce
think.
Richard Fuller
> and no beam.
> your boat?
> Bruce Stirling
> Gangfurd
> 65 Cal 28 - Hull 82
> Of Richard Fuller
> bilge-beam!
> starts.
> Richard Fuller
> Do You Yahoo!?
Gerald Sobel2006-09-21 03:38 UTC
Regarding meager head room in Cal 28. First time I was in one, years ago when I started boat shopping I was annoyed that I couldn't stand up straight in the cabin, as I'm 6'4" (or at least before my hang gliding accident!) Anyway, on the Cal 24, I joked for years that I have full standing head room...if you don't get off your knees.
But, just for fun I tried it, and hit may head anyway! I noticed, however, can do if I'm in the passage way. Maybe that's how they got the genius idea for the pop tops!
Re: Cal-28 question (Hanging Locker)
geobarlow2012-05-06 04:29
Cal 28'ers
I am restoring/repairing "Knackered", Hull No 155. I have cut away most of the bulkhead into the V-berth area, leaving a 2 inch margin on sides and overhead which will probably be assisted by a beam before finishing it. Going to porta-potty for head. It will nest under port side extended V-berth.
I will extend both the port and starboard V-berths to the main bulkhead which bears the chain plates. Hanging locker will be sent to live under bridge deck. Engine compartment is gone, which opens up the space between the quarter berths.
My question: What is the molded piece in the floor of the hanging locker meant for? It looks like it might have been a drain for a floor that is no longer there on "K". I am considering it as a strong point for a new battery box.
I will post some pictures some time so you can watch progress.
George Barlow
Knackered, Cal 28 No. 155
Eagle Mountain Lake, Texas
--- In Ca… [at] yahoogroups.com, Sail Away <Svadas4@...> wrote:
> Richard,
> Good luck!
> Greg
> 1986 Pearson P36-2
> From: Richard Fuller
> Hi Bruce
> think.
> Richard Fuller
> > and no beam.
> > your boat?
> > Bruce Stirling
> > Gangfurd
> > 65 Cal 28 - Hull 82
> > Of Richard Fuller
> > bilge-beam!
> > starts.
> > Richard Fuller
> > Do You Yahoo!?
