Re: [Cal_Boats] Bronze
2 messages2012-07-09 15:33 UTCthrough 2012-07-09 16:05 UTC
Rodney G. Johnson2012-07-09 15:33 UTC
Chris, you are in freshwater, so steel should not be as much problem as for salties like me. Bronze would be great and was used to make centerboards for many K/CB designs in the 1950s and 60's, possible well into the 1970's. However, Bronze will be heavier. I believe (not a real problem) but will also be big $$s, the price of a Bronze CB may come close to the total value of the boat, maybe even more. I agree with those that say the original lasted 51 years, why change (that is, it is better to make a new CB from steel, not Bronze)? One other possibility, is using a sheet of fiberglass, like some have used as backing plates, I think the commercial material is called "G-10". Still may be pricey, but won't rust! Rod Johnson, "SUNBIRD" 1979 O'DAY DS II former co-owner of "NODROG" 1970 CAL 21 On Mon, 09 Jul 2012 11:22:25 -0400 Chris Campbell <cc… [at] lsnm.org> writes: On 7/9/2012 11:01 AM, Joe DeMers wrote: Make it from steel, any metal fabricator can do so. With today's specialized coatings, steel will last a very long time. Steel will also be MUCH MUCH less $ than bronze. Problem with coated steel is that it operates in a tough environment. The board runs in a trunk of iron (the ballast keel), which rusts (less than steel, luckily) and is not smooth. Also we've got the invasive mussels, zebra and quagga, with very sharp shells. And of course, I have been known to find the bottom with my centerboard--bump, bang, oh shit!!! Chris Campbell SoundMarineDiesel.com phone & fax (860) 666-2184 On 7/9/2012 10:40 AM, John Boyce wrote: Question The steel board lasted 51 years and you want to replace it with a better material, how long do you intend to keep this boat? From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Adam Thorp Sent: Monday, July 09, 2012 10:26 AM To: Ca… [at] yahoogroups.com Subject: Re: [Cal_Boats] Bronze I machined new chain plates out of a bronze alloyed with aluminum- C954 from onlinemetals.com after being advised on a forum or two. Would not recommend..... they are rusting up, and I will have to redo the work at some point with silicon bronze plate instead. Bummer. On Mon, Jul 9, 2012 at 6:58 AM, Chris <cc… [at] lsnm.org> wrote: Listmates: My other boat has a steel centerboard and after 51 years of close association with copper-bearing bottom paint, it's getting a bit ragged. My notion is to replace it with bronze. So my question for you metallurgists is what alloy to choose, and for you folks with specialized knowledge, where to buy bronze plate. As to the alloy, a centerboard needs to be stiff but not brittle, and durable in a slightly corrosive environment. The 'board will be housed in a cast iron ballast keel and lifted with a stainless steel pendant/pennant (never have quite figured those terms out). Thanks, Chris Campbell No virus found in this message. Checked by AVG - www.avg.com Version: 2012.0.2195 / Virus Database: 2437/5121 - Release Date: 07/09/12 -- Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.com phone & fax (860) 666-2184 NetZero now offers 4G mobile broadband. Sign up now. http://www.netzero.net/?refcd=NZINTISP0512T4GOUT1
Chris Campbell2012-07-09 16:05 UTC
On 7/9/2012 11:33 AM, Rodney G. Johnson wrote: > > > Chris, you are in freshwater, so steel should not be as much problem > as for salties like me. Bronze would be great and was used to make > centerboards for many K/CB designs in the 1950s and 60's, possible > well into the 1970's. However, Bronze will be heavier. A plus, in a shoal-draft boat with iron instead of lead keel. > I believe (not a real problem) but will also be big $$s, the price of > a Bronze CB may come close to the total value of the boat, maybe even > more. Hard to say without a price quote, but also, if we measured sailing by economic criteria, none of us would own boats.... Chris Campbell > > >>> I machined new chain plates out of a bronze alloyed with >>> aluminum- C954 from onlinemetals.com <http://onlinemetals.com> >>> after being advised on a forum or two. >>> >>> Would not recommend..... they are rusting up, and I will have to >>> redo the work at some point with silicon bronze plate instead. >>> Bummer. >>> >>> On Mon, Jul 9, 2012 at 6:58 AM, Chris <cc… [at] lsnm.org >>> <mailto:cc… [at] lsnm.org>> wrote: >>> >>> Listmates: >>> >>> My other boat has a steel centerboard and after 51 years of >>> close association with copper-bearing bottom paint, it's getting >>> a bit ragged. >>> >>> My notion is to replace it with bronze. So my question for you >>> metallurgists is _what alloy_ to choose, and for you folks with >>> specialized knowledge, _where to buy bronze plate_. >>> >>> As to the alloy, a centerboard needs to be stiff but not >>> brittle, and durable in a slightly corrosive environment. The >>> 'board will be housed in a cast iron ballast keel and lifted >>> with a stainless steel pendant/pennant (never have quite figured >>> those terms out). >>> >>> Thanks, >>> Chris Campbell >>> >>> No virus found in this message. >>> Checked by AVG - www.avg.com <http://www.avg.com> >>> Version: 2012.0.2195 / Virus Database: 2437/5121 - Release Date: >>> 07/09/12 >>> >> >> -- >> >> *Joe DeMers - owner* >> >> Sound Marine Diesel LLC >> >> SoundMarineDiesel.com <http://www.soundmarinediesel.com/> >> >> *phone & fax (860) 666-2184* >> > > > > > > ____________________________________________________________ > NetZero now offers 4G mobile broadband. Sign up now. > <http://www.netzero.net/?refcd=NZINTISP0512T4GOUT1> >
