6 messages2012-08-18 16:34 UTCthrough 2012-08-21 03:24 UTC
mooring bridle-- 3/4" x 20 feet
Ira Reba2012-08-18 16:34 UTC
Hello Group,
I'm hoping someone might have a 3/4" x 15 or 20' mooring bridle not needed and/or taking up space. I'd be happy to pay a bit + shipping. Would anyone have one just sitting around in okay condition waiting to hold my 30' sloop?
In advance, thanks.
Ira C.Reba
Re: [Cal_Boats] mooring bridle-- 3/4" x 20 feet
Joe DeMers2012-08-20 12:57 UTC
I have a mooring ball, unused, with about 200 pounds of buoyancy, does
that help? Also have swizzle stick [ mooring pickup buoy with fiberglass
stick ] unused.
*Joe DeMers - owner*
Sound Marine Diesel LLC
*phone & fax (860) 666-2184*
On 8/18/2012 12:34 PM, Ira Reba wrote:
> Hello Group,
> In advance, thanks.
> Ira C.Reba
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 2012.0.2197 / Virus Database: 2437/5204 - Release Date: 08/16/12
Paint Options?
Robert Libbert2012-08-20 15:47 UTC
My T/2 has peeling paint in the cabin and it's on my list to fix this Friday. I'm going to scrape/wire-brush then sand the old stuff. My question is what should I repaint with? Would like to reproduce the textured/swirly pattern that was stock if possible. Any suggestions around product or technique would be appreciated.
Rob
Re: [Cal_Boats] Paint Options?(Rob)
david dobbs2012-08-20 22:18 UTC
Rob,
I just finished a similar job on my 29, in the main cabin. It was easier to remove the old paint with a heat gun. If you don't remove all the old paint it will probably look nasty. I used Pettit EZ CabinCoat, stark white, took 3 coats, no swirls just clean, white finish. The disclaimer is that I had the ports out, made the job easier. Next project is the quarterberths, this winter. Year 3 will be the forward head compartment and V berth.
\David Dobbs CAL 29 411
Sent: Monday, August 20, 2012 10:47 AM
Subject: [Cal_Boats] Paint Options?
Rob
Helen Horn2012-08-21 01:36 UTC
we used stripper sanding rustoleum marine LPU primer paint semigloss for V berth
we used rustoleum appliance White EPOXY in anchor locker , cupboard which also
come in RATTLE can which makes it easy for tight areas ...we like smooth surface
so that water condansation will run off and wipe off easy...but if you want
texure
you can use a fuffly roller with a slurrey epoxy paint micro filler try this
1st on a old
ice crest or sample piece but a smooth surface we not be prone to MOLD...also
if you have a aircompresser and a hopper gun you can spary texture but you MUST
prime 1st texture then prime agin then paint good luck a clean boat is a
happy boat edward Cal 36 "Caliente" #60
Sent: Mon, August 20, 2012 3:18:07 PM
Subject: Re: [Cal_Boats] Paint Options?(Rob)
Rob,
appreciated.
Rob
Michael McElhaney2012-08-21 03:24 UTC
Also be sure to ventilate and wear VOC respirator as the fumes WILL make you stupid, or worse! I was overcome by fumes using awlgrip inside a boat even though I had all hatches open and a box fan blowing. It's been nearly 4 years since and I am still "off" (slow thinking, hard to focus, stuttering speech at times and always feel like I'm in a fog. My girl still notices the difference. Its like a chemical lobotomy. And it sucks!).
Please be careful with paint.
so that water condansation will run off and wipe off easy...but if you want texure
you can use a fuffly roller with a slurrey epoxy paint micro filler try this 1st on a old
ice crest or sample piece but a smooth surface we not be prone to MOLD...also if you have a aircompresser and a hopper gun you can spary texture but you MUST prime 1st texture then prime agin then paint good luck a clean boat is a happy boat edward Cal 36 "Caliente" #60
Rob,
Rob
