4 messages2012-09-03 14:16 UTCthrough 2012-09-04 12:23 UTC
Re: Battery size
Harold Beer2012-09-03 14:16 UTC
I've got a Cal 2-27 - and your battery choice depends on how you use your boat. If you mainly day sail from a slip with shorepower, you might make one choice; whereas, if you sail mainly at night, with a lot of electronics, you'll probably want batteries with more capacity.
So what does this Cal sailor have? A pair of group 24 (that's a size) deep-cycle lead acid batteries from Interstate - they are just about done, being eight years old - carefully topped up with water, not over-charged - even still, 18 hours of sailing will flatten them both.
I guess you could put golf cart batteries in the lockers under the settees (would make maintenance a treat), but I don't mind (too much) having them stashed under the galley - access through the lazarette is sometimes difficult.
Harold Beer
Arcturus
Cal 2-27
Re: [Cal_Boats] Re: Battery size
roline2012-09-03 14:34 UTC
I use a pair of 110AH AGM for the house and red top orbital for engine.
The house will go low after 100AH of consumption, 9 amps for 12 hrs as
expected. I upgraded to an 80Amp alternator to top them up during motoring.
> Harold Beer
> Arcturus
> Cal 2-27
RE: [Cal_Boats] Re: Battery size
John Boyce2012-09-03 14:41 UTC
On my Cal227 I use marine batteries that have high CCA's rather than deep
cycle, the size is the biggest that will fit in the allocated space under
the cockpit floor. The position of the batteries was changed near the end
of the production run, it is virtually inaccessible. A friend with an older
227 unbolted the stove so that it could be lifted out giving easy access to
the batteries.
John B
CAL 227 #650
Of Harold Beer
Sent: Monday, September 03, 2012 10:17 AM
Subject: [Cal_Boats] Re: Battery size
difficult.
Harold Beer
Arcturus
Cal 2-27
Re: [Cal_Boats] Re: Battery size (Harold)
Michael D2012-09-04 12:23 UTC
Harold,
When I bought Magic, the PO had two group 24's installed on a 1/2/both battery switch. They were both dead. Looking at replacements, I went with two group 27's (dual-purpose). When they finally gave it up, I put in two group 31's (deep cycle). They are wet/flooded batteries. I check them regularly and top off with distilled water. We have a ProSport 12 to keep them charged.
While we do race Magic on a regular basis, the additional weight is minimal. Besides, with the size of my crew, I don't think it makes much difference.
We also cruise southeast Florida and the Bahamas, so the added power available is welcome. If we were only day sailing Magic, I would probably just have one small battery to crank the diesel.
Michael
s/v Magic, Cal 2-27 #627
Pompano Beach, FL
Sent: Monday, September 3, 2012 10:16 AM
Harold Beer
Arcturus
Cal 2-27
