7 messages2012-09-24 15:23 UTCthrough 2012-09-26 12:27 UTC
Lead weight at rudder post Cal 39
Greg vanDalen2012-09-24 15:23 UTC
Well I've come across something that I've never seen before. while removing the thru-hulls for the cockpit drains (the ones that exit right above the rudder), I noticed the forward one was sitting in a bed of lead shot. The whole mess was fiberglassed in. I can't for the life of me figure out what lead is doing at the rudder post.
Any ideas?
Re: [Cal_Boats] Lead weight at rudder post Cal 39
Joe DeMers2012-09-24 17:02 UTC
Trim ballast.
Joe
> Any ideas?
> No virus found in this message.
> Checked by AVG - www.avg.com <http://www.avg.com>
> Version: 2012.0.2221 / Virus Database: 2441/5288 - Release Date: 09/23/12
*Joe DeMers - owner*
Sound Marine Diesel LLC
*phone & fax (860) 666-2184*
Greg vanDalen2012-09-24 17:38 UTC
Joe,
Interesting. I was wondering if that is what it could be, but it only looks like about 50 lbs or so. I will glass over it and leave it be!
Greg
--- On Mon, 9/24/12, Joe DeMers <je… [at] mindspring.com> wrote:
Subject: Re: [Cal_Boats] Lead weight at rudder post Cal 39
Date: Monday, September 24, 2012, 10:02 AM
Trim ballast.
Joe
Any ideas?
Joe DeMers - owner
Sound Marine Diesel LLCSoundMarineDiesel.com
Re: [Cal_Boats] Lead weight at rudder post Cal 39 (Greg)
Duane Knize2012-09-24 22:22 UTC
Greg,
/Marlyn/, my 1878 Cal 2-39 #18* had* a large slab of lead shot and resin
just forward of the rudder post.
I'm guessing that it was added, apparently by the factory, to achieve
proper longitudinal trim.
I estimate that it was about 400 pounds.
Over the years I asked many Cal 39 owners (earlier and later models) if
they had similar ballast; no one did.
Marlyn floated low in the stern; about 1" below the top of the bottom paint.
Having added a radar tower and larger than stock batteries, I figured
that I no longer needed the extra ballast.
Last year I bought a double circular saw and cut throught the resin
layer (fortunately only the top 2" was resin saturated; there was loose
lead shot below).
She still sits low in the stern but not as bad.
I considered replacing the plastic cockpit drain through hulls with
proper seacocks when I had the bottom done last year. I couldn't figure
a way to fit them in. The plastic through hulls with no good way to
close them in case of failure still bothers me. Wooden plugs will
interfere with rudder movement.
I know of one Cal 39, /Zalika/, modified to have oversized 2" cockpit
drains led through the stern. Is that where you are leading your drains?
Regards,
Duane Knize
S/V /Marlyn/
1979 Cal 2-39 #18
> Any ideas?
Greg vanDalen2012-09-25 12:26 UTC
Duane,
I'm planning on putting them just to port and starboard of the rudder post (just above the water line). I wasn't planning on ball valves because it is such a low risk installation. I need to measure everything first, but in the mean time my wife just glassed over the old holes and we will epoxy over the top area for now. Eventually we will get a proper lower rudder bearing, but in the mean time this will get us back in the water.
Thanks for the information on the lead. At least I know where to remove some weight some day!
Greg
--- On Mon, 9/24/12, Duane Knize <kn… [at] san.rr.com> wrote:
Subject: Re: [Cal_Boats] Lead weight at rudder post Cal 39 (Greg)
Date: Monday, September 24, 2012, 3:22 PM
Greg,
Marlyn, my 1878 Cal 2-39 #18 had a large slab of lead shot and resin just forward of the rudder post.
I'm guessing that it was added, apparently by the factory, to achieve proper longitudinal trim.
Over the years I asked many Cal 39 owners (earlier and later models) if they had similar ballast; no one did.
Having added a radar tower and larger than stock batteries, I figured that I no longer needed the extra ballast.
Last year I bought a double circular saw and cut throught the resin layer (fortunately only the top 2" was resin saturated; there was loose lead shot below).
I considered replacing the plastic cockpit drain through hulls with proper seacocks when I had the bottom done last year. I couldn't figure a way to fit them in. The plastic through hulls with no good way to close them in case of failure still bothers me. Wooden plugs will interfere with rudder movement.
I know of one Cal 39, Zalika, modified to have oversized 2" cockpit drains led through the stern. Is that where you are leading your drains?
Regards,
Duane Knize
S/V Marlyn
1979 Cal 2-39 #18
Any ideas?
Duane Knize2012-09-26 00:31 UTC
Greg,
'Just a note about Cal 39's re drain outlet placement.
In a following swell the water can come half-way up the transom; the
diesel exhaust pipe is often under water.
When heeling, at times, the leeward aft corner of the cockpit is
apparently below the water line.
We can get an inch or so of sea water in the low corner. This water
enters through the drain.
Regards,
Duane
On 9/25/2012 5:26 AM, Greg vanDalen wrote:
> Duane,
> Greg
> --- On *Mon, 9/24/12, Duane Knize /<kn… [at] san.rr.com>/* wrote:
> From: Duane Knize <kn… [at] san.rr.com>
> Greg,
> bottom paint.
> Regards,
> Duane Knize
> S/V /Marlyn/
> 1979 Cal 2-39 #18
>> the rudder post.
>> Any ideas?
Greg vanDalen2012-09-26 12:27 UTC
My plan was to cross the drain lines so that the starboard drain exits on the port side and vice-versa. I don't want to obstruct access to the rudder quandrant, but also want to make sure the thru hulls are low enough that they drain well. I'm heading out there today to do some sight lines to see where the best location is. It may well be that I install new ones right where the old ones were!
Greg
Date: Tuesday, September 25, 2012, 5:31 PM
Greg,
In a following swell the water can come half-way up the transom; the diesel exhaust pipe is often under water.
When heeling, at times, the leeward aft corner of the cockpit is apparently below the water line.
We can get an inch or so of sea water in the low corner. This water enters through the drain.
Regards,
Duane
Duane,
Greg
Greg,
Regards,
Duane Knize
S/V Marlyn
1979 Cal 2-39 #18
Any ideas?
