Cal (29) table bracket?
2 messages2012-10-21 00:06 UTCthrough 2012-10-21 00:19 UTC
Greg Beron2012-10-21 00:06 UTC
I just bought a 1969 Cal 29 and it's a bit of a project. One thing that needs to be replaced is the bracket that fits on the underside of the table and serves as the fitting for the table leg. A photo is attached. There's no manufacturer's identification and I don't know if it's a standard piece. If it helps, the leg diameter is 3.5 inches, tapering to 3-7/16" at the top and bottom. Does anyone recognize it? Do you know where I can find a replacement?
Re: [Cal_Boats] Cal (29) table bracket? [1 Attachment]
Allen Edwards2012-10-21 00:19 UTC
You might use brass 3 inch pips and replace the broken piece shown in the photo with a floor flange. It is 3.5 inches and you might have to turn it down to 3-7/16 to fit the base at the bottom if I am picturing this correctly. I use pipe for the legs and floor flanges screwed to the underside of the table. The pipe slides into the ID of the remaining pieces that were frozen into the fittings under the floor boards. I cut them off flush and found pipe that had an OD to match. Allen L-36 #5 On Sat, Oct 20, 2012 at 5:06 PM, Greg Beron <gb… [at] yahoo.com> wrote: > ** > > [Attachment(s) <#13a80a52c2a4b0cc_TopText> from Greg Beron included > below] > > I just bought a 1969 Cal 29 and it's a bit of a project. One thing that > needs to be replaced is the bracket that fits on the underside of the table > and serves as the fitting for the table leg. A photo is attached. There's > no manufacturer's identification and I don't know if it's a standard > piece. If it helps, the leg diameter is 3.5 inches, tapering to 3-7/16" at > the top and bottom. > > Does anyone recognize it? Do you know where I can find a replacement? > > >
