7 messages2012-11-06 22:22 UTCthrough 2012-11-07 16:00 UTC
Re: [Cal_Boats] window glass (Charlie)
John Thorn2012-11-06 22:22 UTC
Use Lexan. Very tough, same stuff airplane windows are made of also car
headlight lenses. I put 0.280 thick on a Hunter 34 across two windows about
5 feet. Followed the curve great.I used a grey tint. That's the stuff most
new boats like Cat 320 use. Very nice look.
John R Thorn
NuDawn Inc
479.263.6448 Cell
jt… [at] nudawninc.com
RE: [External] Re: [Cal_Boats] window glass (Charlie)
Husar, Charlie [USA] (ASE)2012-11-06 22:28 UTC
Thanks, John. I used what Marl Plastics was providing as standard at the time. It was tinted. Do not know the material composition.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of John Thorn
Sent: Tuesday, November 06, 2012 5:22 PM
Subject: [External] Re: [Cal_Boats] window glass (Charlie)
Use Lexan. Very tough, same stuff airplane windows are made of also car headlight lenses. I put 0.280 thick on a Hunter 34 across two windows about 5 feet. Followed the curve great.I used a grey tint. That's the stuff most new boats like Cat 320 use. Very nice look.
John R Thorn
NuDawn Inc
479.263.6448 Cell
jt… [at] nudawninc.com<mailto:jt… [at] nudawninc.com>
Chris Campbell2012-11-07 14:44 UTC
If that's what car headlight lenses are now, then consider that some of
them do start to go dull and slightly yellow after a decade or so. But
also consider that these are in very tough service--at least where I
live, there's a lot of abrasion in the winter from the sand used on snow
& ice, plus the lenses are almost constantly exposed to light and the
elements. My 2005 Ranger has lived outdoors for 7 years and the
headlight lenses look new. Also, there are abrasives formulated to
polish these up and sold as kits in auto parts stores. I'd say that
automobile service is a testament to the durability of polycarbonate
designed for exterior exposure.
Sail track question.
Robert Libbert2012-11-07 15:12 UTC
So I went to reef my main for the first time the other day and discovered that my T/2 has a unique (to me) sail track configuration. There is an upper and a lower track. The lower is about a foot long, and the the upper of course goes to the top of the mast. Between the two is about a 1 foot gap. Each have a stop at the bottom held on with a screw. While I'm sure this makes changing mains very easy (take the stop off the upper track, slide the sail down the bottom one, then up the top, reattach the stop), it makes reefing a PITA because you have to remove the stop to get the reef points down to the reef hook. I can tell you this is no fun to discover or attempt during the time of need (lesson learned there).
So...
Either I'm completely missing something, and this is a brilliant configuration and I'm too dumb to figure it out or-
I need to get a piece of track to put in the open space. Where would I get something like that without having to fabricate it?
Rob
Re: [Cal_Boats] Sail track question.
Allen Edwards2012-11-07 15:31 UTC
When I got my boat there were longish lines that held the bottom two slides
on the sail that you loosen when you want to reef. Then the slide can stay
on the upper track but its corresponding part of the sail can still go down
to where it needs to be. I didn't have two tracks, just one but it ended
fairly high. I added a section of track to eliminate the need when I
bought my new sail. On my previous sail, I just cut out the bottom slide
as it was a pain to deal with the line. Thus is presented three options...
> So...
> Thanks,
> Rob
RE: [Cal_Boats] Sail track question.
r good2012-11-07 15:54 UTC
I suspect you are missing a short piece of track. There was a piece of track linking the two, and no stop on the upper section. the boom rode up with the main when hoisted, then was held down with a tensionable line at the gooseneck. Before I set a fixed gooseneck at the black line, I would drop the boom with thew main at full hoist, as sort of a partial reef-just lowers the entire main to reduce effort up high- then tie in the flattening reef.
Date: Wed, 7 Nov 2012 07:12:21 -0800
Subject: [Cal_Boats] Sail track question.
So...
Rob
Harleigh Ewell2012-11-07 16:00 UTC
Google sail track. E.g.,
http://www.rigrite.com/Hardware/Track/Sailtrack.htm
Harleigh
Rob
