10 messages2012-11-27 17:27 UTCthrough 2012-11-28 03:30 UTC
Re: [External] Re: [Cal_Boats] LED retrofit(Jerry)
pw… [at] aol.com2012-11-27 17:27 UTC
Is it me or is there some explanation as to why LED's are easier to be seen
from a distance than to use to see for a distance? We bought some big
LED flashlights some years ago to use for luff lites for night sailing and as
I recall paid a fair sum for them. Long story short, they are pieces of
sh*t and basically useless. It seems their light just scatters and provides
a very dim light for a short distance but if you look directly at them they
seem very bright.
Thanks -
Paul
In a message dated 11/27/2012 12:13:50 P.M. Eastern Standard Time,
hu… [at] bah.com writes:
An interesting point. I was thinking that the reds and greens might have
a problem going through colored lenses since the LEDs a specific to a
single frequency, and the passband of the lens might not be good at that
frequency.
Need to remember that the white light of the LED lamps is a very
interesting mix of a small number of specific single frequencies that approximates
the white - unlike white sunlight or incandescent light that is a mix of all
visible frequencies. Hence maybe the white is weak through colored
lenses.
Behalf Of david dobbs
Sent: Tuesday, November 27, 2012 11:39 AM
Subject: [External] Re: [Cal_Boats] LED retrofit(Jerry)
Jerry,
Yes, but I don't remember where I saw it, something about the white light
from an LED not getting through a colored lens, very well. I don't know
about a tri-color, interesting question. If I get a chance I'll look for an
answer, maybe on Aqua Signal's website or Perko's.
David
Sent: Monday, November 26, 2012 11:03 PM
Subject: Re: [Cal_Boats] LED retrofit
David, RU shore about that? It looks like the replacement LED for the
masthead tricolor are all white bulbs, but I could be wrong. I was thinking of
trying to find an LED bulb to replace the bi color fixture that came with
my boat, which I haven't used (actually, had removed) because it's located
where the jib would land on the deck if it was dropped down. So, I'd have to
make a bow pulpit mount for it.
Date: Monday, November 26, 2012, 1:11 PM
Chris,
I forgot, you need to get a green for starboard and a red for port, white
won't work.
David
Sent: Monday, November 26, 2012 3:00 PM
If you know the bulb type there are charts that tell what the LED
replacement is. I used _superbrightleds.com_ (http://superbrightleds.com/) ,
reasonable prices.
David Dobbs
Sent: Monday, November 26, 2012 1:34 PM
Subject: [Cal_Boats] LED retrofit
Listmates:
I know this is an old and much-discussed subject, but I'll pose my
question.
Both of my boats are from the 1960s. I'd like to retrofit LED running
light illumination because of the battery-life advantages. Neither boat
has an inboard engine for charging, and my Cal 20 doesn't even have a
battery aboard. I figure that with LEDs, I could use lantern batteries
for running light service.
The older boat has nice bronze teardrop Wilcox-Crittendon light
fixtures, and the Cal has standard little half-sphere stainless steel
fixtures. My plan is to e-mail photos of the fixtures to the LED vendor
and ask is they can supply suitable drop-in devices.
Can anybody recommend bulb suppliers that are familiar with
standard-issue boat fixtures and that are good to work with?
Chris Campbell2012-11-27 20:47 UTC
> seen from a distance than to use to see for a distance? We bought
> some big LED flashlights some years ago to use for luff lites for
> night sailing and as I recall paid a fair sum for them. Long story
> short, they are pieces of sh*t and basically useless. It seems their
> light just scatters and provides a very dim light for a short distance
> but if you look directly at them they seem very bright.
I carry an LED flashlight on my daily walk/run exercise route after
work, which is an after-dark activity at this season of the year. The
flashlight offers a variety of flash options, useful for catching the
attention of drivers for the portion of the route that's in the road. I
have noticed that the LED light is especially effective with reflective
surfaces--the various 3M products and similar advanced reflective
materials. There must be something about the way the light is polarized.
chris1232012-11-27 21:05 UTC
Chris:
Here's and interesting read. Also carry a battery operated set for your 20.
http://www.duckworksmagazine.com/09/howto/led-nav/index.htm
chris1232012-11-27 21:06 UTC
Btw...thanks for introducing me to Kevin, very interesting lad.
chris1232012-11-27 21:10 UTC
This is the anchor light I used. Easily meets coast guard regs in
Canada and the States, sucks virtually no power. Ran a line up to the
spreaders and then hung the light from it, bungy cord to the deck.
Could see the boat and deck for miles.
http://www.bebi-electronics.com/owl.html
Chris Campbell2012-11-27 21:15 UTC
On 11/27/2012 4:05 PM, chris123 wrote:
> Chris:
> your 20.
That looks like an excellent solution for the Cal 20. Add 12 V lantern
battery and illumination is at hand. The other boat really does need to
retain her old Wilcox-Crittendon bronze fixtures because they're sooo
1961 and bronze and altogether just the right style. When you're an old
boat, style is a big deal. The 20 is a bit more hip and adaptable.
chris1232012-11-27 21:40 UTC
Send me a picture if you can. It may be able to convert these to kerosone
or simple lamp oil burners. All depends on the lenses used. Many long term
voyagers hunt out such old lanterns and convert them to kero or lamp oils
specifically for that reason.
https://plus.google.com/115249722133644145266/posts?banner=pwa
You can see them sitting on the decks and there is one below the windvane.
chris1232012-11-27 21:44 UTC
Sorry Chris...that google plus thing just gets in the way all the
time. See attachment.
RE: [External] Re: [Cal_Boats] LED retrofit(Jerry)
Ted Wrobel2012-11-27 23:11 UTC
LEDs produce an exceptionally high intensity light from a very small spot.
Your eye can see the spot because of the intensity. The amount of light is
often fairly small, so it cannot provide much illumination over an area like
a sail.
Lumens is the measurement of the amount of light. Comparing lumen output of
different lights is, well, illuminating. (sorry)
Further, these very small spot of light is difficult to diffuse and focus
into a beam covering an area. Diffusion costs lumens.
With an incandescent filament the light radiates in a wide pattern and is
easy to focus into a beam.
Ted Wrobel
CAL 33 Celebration
Newport, RI
Of Chris Campbell
Sent: Tuesday, November 27, 2012 3:47 PM
Subject: Re: [External] Re: [Cal_Boats] LED retrofit(Jerry)
from a distance than to use to see for a distance? We bought some big LED
flashlights some years ago to use for luff lites for night sailing and as I
recall paid a fair sum for them. Long story short, they are pieces of sh*t
and basically useless. It seems their light just scatters and provides a
seem very bright.
I carry an LED flashlight on my daily walk/run exercise route after work,
which is an after-dark activity at this season of the year. The flashlight
offers a variety of flash options, useful for catching the attention of
drivers for the portion of the route that's in the road. I have noticed
that the LED light is especially effective with reflective surfaces--the
various 3M products and similar advanced reflective materials. There must
No virus found in this message.
Checked by AVG - www.avg.com
Version: 10.0.1427 / Virus Database: 2629/5422 - Release Date: 11/27/12
Allen Edwards2012-11-28 03:30 UTC
Try one of these
http://www.costco.com/Life%2bGear-1000-Lumen-LED-Flashlight-with-Flasher.product.100008746.html
PS. These were not the ones I was recommending.
On Tue, Nov 27, 2012 at 3:11 PM, Ted Wrobel <tw… [at] tacticaltech.com>wrote:
> like a sail.
> of different lights is, well, illuminating. (sorry)
> Ted Wrobel
> CAL 33 Celebration
> Newport, RI
> Behalf Of *Chris Campbell
> *Sent:* Tuesday, November 27, 2012 3:47 PM
> *Subject:* Re: [External] Re: [Cal_Boats] LED retrofit(Jerry)
> seen from a distance than to use to see for a distance? We bought some big
> as I recall paid a fair sum for them. Long story short, they are pieces of
> seem very bright.
> Chris Campbell
