3 messages2013-01-10 17:40 UTCthrough 2013-01-10 20:31 UTC
Useful Light?
Husar, Charlie [USA] (ASE)2013-01-10 17:40 UTC
Hi, All. Thought this might be useful on our boats.
[http://www.ecnmag.com/sites/ecnmag.com/files/legacyimages/light98376.jpg] Picture this: You're sitting in front of the television one night watching Ax Men when suddenly the power goes out. Stumbling over to the hall closet, you rummage around on the shelves for a flashlight. Finally, after nearly strangling yourself with a scarf, you locate the light only to discover it needs batteries. Diving back into the cavernous black hole of a closet, you emerge-triumphantly-with the battery box. No dice. Your kids got a Wii a while back and used all the AA batteries. Hope you have candles.
All this could have been avoided if you had the Any Battery Light<http://www.japantoday.com/category/new-products/view/emergency-flashlight-works-on-any-size-of-battery>, which, as its name suggests, can be used with a variety of batteries or combinations of batteries. After the natural disasters in Japan, Panasonic decided to create a light where you wouldn't have to scramble to find just the right battery in an emergency situation. The result was a flashlight that can be used with AAA, AA, C or D-sized batteries or a combination of the four. The light doesn't actually use all the batteries at once, you can select which battery to use via the power switch. The brightness of the LED-selected for energy efficiency-depends on what type of battery you're using, but even the AAA battery offers enough light to get around in a pinch. If the flashlight contains one of each type of battery, it will last around 86 hours, according to the company.
This is a really great technology that will be widely available. It's one of those things that has a lot of uses outside of natural disasters and it's pretty cheap, so the price point shouldn't be a huge barrier.
The light will be available at the end of January for about $24.
Re: [Cal_Boats] Useful Light?
Gerald Sobel2013-01-10 18:09 UTC
Charlie, how many candles can you buy for $24? What about inventing a flashlight that uses candles?
There's something on YouTube about starting a fire using a stone, a stick, and an orange. Then, what if the quake hits after you ate your last orange?
Maybe someone makes a lantern that works on veggie oil. Have to ask Google. Revenge of the Luddites!.
OK, then, what if I used my last drop of cooking oil making scrabbled eggs?
To: "CAL Yahoo (Ca… [at] yahoogroups.com)" <Ca… [at] yahoogroups.com>
Sent: Thursday, January 10, 2013 9:40 AM
Subject: [Cal_Boats] Useful Light?
Picture this: You’re sitting in front of the television one night watching Ax Men when suddenly the power goes out. Stumbling over to the hall closet, you rummage around on the shelves for a flashlight. Finally, after nearly strangling yourself with a scarf, you locate the light only to discover it needs batteries. Diving back into the cavernous black hole of a closet, you emerge—triumphantly—with the battery box. No dice. Your kids got a Wii a while back and used all the AA batteries. Hope you have candles.
All this could have been avoided if you had theAny Battery Light, which, as its name suggests, can be used with a variety of batteries or combinations of batteries. After the natural disasters in Japan, Panasonic decided to create a light where you wouldn’t have to scramble to find just the right battery in an emergency situation. The result was a flashlight that can be used with AAA, AA, C or D-sized batteries or a combination of the four. The light doesn’t actually use all the batteries at once, you can select which battery to use via the power switch. The brightness of the LED—selected for energy efficiency—depends on what type of battery you’re using, but even the AAA battery offers enough light to get around in a pinch. If the flashlight contains one of each type of battery, it will last around 86 hours, according to the company.
Chris Campbell2013-01-10 20:31 UTC
LED lights are a genuine miracle for anybody raised in the age of the
old carbon & zinc cells and incandescent bulbs. That always inclines me
greatly toward any device that uses them.
Now they are available at the hardware store or variety store checkout
counters for three bucks or so. The other day a clerk said "would you
like an LED flashlight for $3?" Chris said yes. Can't resist.
But my guess is that if this light is by Panasonic, and if they've
engineered it as an emergency device, then maybe it's like buying
marine-grade stuff that really is better and not just repriced for the
yacht market. Consider, for example, tinned conductor wiring vs.
hardware store lamp cord. Maybe the latter would work well, but maybe
you don't want to find out that it didn't when you're far from shore and
depending on it.
