Re: [Cal_Boats] glassing a rudder?
2 messages2013-02-11 20:22 UTCthrough 2013-02-11 20:39 UTC
ai… [at] aol.com2013-02-11 20:22 UTC
Hi Reggie, I would not trust 1 layer to protect the rudder. 8oz is pretty thin. I would gauge the thickness of what was original and go from there. I would guess 3 or 4 layers minimum. It is just as easy to do 4 as it is 1. Every layer after is a little smaller than the previous one. Makes fairing easier. Best to do them all at the same time for best bond/strength. Fell free to call me or David. 805-451-9335 Daniel Casey "AirTime" Cal 9.2R #75 Santa Barbara, Ca. In a message dated 2/10/2013 4:52:23 P.M. Pacific Standard Time, my… [at] hotmail.com writes: I gouged out the bad stuff from one side of the rudder. about 1/4 of the original glass skin was sacrificed. two part pourable hard urethane foam was poured in to expand for filler, then sculpted for shape. I have glassed the outside with one layer of 8oz cloth and epoxy. I tried working with plain glass mat, but I have no skills or techniques for it. I can do the cloth with slow set hardener. Opinion time: Is one layer of 8oz glass enough, then barrier coat and bottom paint? Reggie
RE: [External] Re: [Cal_Boats] glassing a rudder?
Husar, Charlie [USA] (ASE)2013-02-11 20:39 UTC
Reg, I also thought that a single layer would be too thin. However, I have bought a couple rudders from Foss Foam (CA) over the years, and the skin on them was indeed very thin. Daniel, I am not sure those rudders have enough skin thickness to do the beveling one would want to do to the shrinking size layering. My conclusion is a big question mark. Dunno. Thanks Charlie From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of ai… [at] aol.com Sent: Monday, February 11, 2013 3:23 PM To: Ca… [at] yahoogroups.com Subject: [External] Re: [Cal_Boats] glassing a rudder? Hi Reggie, I would not trust 1 layer to protect the rudder. 8oz is pretty thin. I would gauge the thickness of what was original and go from there. I would guess 3 or 4 layers minimum. It is just as easy to do 4 as it is 1. Every layer after is a little smaller than the previous one. Makes fairing easier. Best to do them all at the same time for best bond/strength. Fell free to call me or David. 805-451-9335 Daniel Casey "AirTime" Cal 9.2R #75 Santa Barbara, Ca. In a message dated 2/10/2013 4:52:23 P.M. Pacific Standard Time, my… [at] hotmail.com writes: I gouged out the bad stuff from one side of the rudder. about 1/4 of the original glass skin was sacrificed. two part pourable hard urethane foam was poured in to expand for filler, then sculpted for shape. I have glassed the outside with one layer of 8oz cloth and epoxy. I tried working with plain glass mat, but I have no skills or techniques for it. I can do the cloth with slow set hardener. Opinion time: Is one layer of 8oz glass enough, then barrier coat and bottom paint? Reggie
