15 messages2013-02-13 21:45 UTCthrough 2013-02-15 04:56 UTC
Re: [External] RE: [Cal_Boats] Is it time for the dreaded beam repla
Alfred Poor2013-02-13 21:45 UTC
Alex offered:
> AFAIK, Cal 29 and 2-29 is the same boat with some minor differences in the
cabin layout.
Here are the major differences as I understand them:
Cal 29: head and sink to port, hanging locker to starboard, starboard
quarterberth, tiller
Cal 29-2: head sink to starboard, no starboard quarterberth, wheel steering
Both have deck-stepped masts. (Roger Jones was planning a keel-stepped
carbon fiber mast for Swiss Navy, but that was definitely a departure from
factory specs.)
Alfred Poor
Alex Kunadze2013-02-13 21:53 UTC
Well, then I have a 29, except that the only sink I have is in the galley,
which is to starboard.
On Wed, Feb 13, 2013 at 1:45 PM, Alfred Poor <ap… [at] verizon.net> wrote:
> Alex offered:****
> the cabin layout.****
> Here are the major differences as I understand them:****
> quarterberth, tiller****
> factory specs.)****
> Alfred Poor****
> 1973 Tartan 34C #288 “Jambalaya”****
Mark Alan Stahnke (MAS Consulting)2013-02-14 00:48 UTC
According to my drawings, the 1968 (Cal)ifornia 29, has a quarter both port and starboard quarter berths, the head is starboard, there is no wash sink on the port side, but there is a hanging locker directly across on starboard. There is no hand held shower. There is tiller steering and an atomic 4. The galley is on the starboard side from the quarter berth to the main bulkhead. Mainsheet traveler to stern behind the rudder post.
Where as the 2-29 (Hull # 918 1976) layout is not on my set of pdf drawings, also has two quarter berths port and starboard. Wheel steering, head on port and wash basin on starboard, along with hand held shower(removed). The galley is on the starboard side from the quarter berth to the main bulkhead. Powered by a 12 hp diesel farymann. Mainsheet traveler a head of the wheel.
In about 1977, what I believe is the 3-29 has a quarter berth on the port and ice box and sink cabinetry on starboard blocking off the quarter. There is the wash sink on starboard. Additionally, there is a berth between the stove and the main bulkhead and directly across from the galley table. This version comes with wheel steering unlike the 29. When I have a chance I will pull out the hard copy and check against the pdf.
It would be great to see all of the variations. Maybe you can post some pictures of the boat described below, since it is different from the drawings.
Mark A. Stahnke
MAS Consulting
(310) 832-5992
Sent: Wednesday, February 13, 2013 1:53 PM
Subject: Re: [External] RE: [Cal_Boats] Is it time for the dreaded beam repla
Well, then I have a 29, except that the only sink I have is in the galley, which is to starboard.
Alex offered:
> AFAIK, Cal 29 and 2-29 is the same boat with some minor differences in the cabin layout.
Cal 29: head and sink to port, hanging locker to starboard, starboard quarterberth, tiller
Both have deck-stepped masts. (Roger Jones was planning a keel-stepped carbon fiber mast for Swiss Navy, but that was definitely a departure from factory specs.)
Alfred Poor
__________ Information from ESET NOD32 Antivirus, version of virus signature database 8007 (20130213) __________
http://www.eset.com
http://www.eset.com
Dylan Crouch2013-02-14 16:08 UTC
I wonder if that sink across from the head was commonly added afterwords, or in quite a few of the models? Our original brochure (1968-1970ish) has a picture of a sink being there.
I understand (3rd-4th hand) lot of owners covered the small hand sink that was directly across from the head in the old Cal 2-29's and 2-30's. If that space is a hanging locker, look at the hull below it and you may very well find a through hole which was the drain for the sink.
First time under the counter that was in our hanging locker I saw the sink still there which had been covered over to make the counter. Took a while to convince the wife that it was better as a counter than convert it back to the 2nd sink on a 30ft sailboat.
As I understand the Cal 29's were pretty much the same all around as the 30's with a shorter transom. Maybe the 30's had a sink & the 29's did not? Maybe it was a variation on both? Sounds like the very same layout on our 2-30 except the traveler is across the transom at the rear of the cockpit.
The other item which may have been a variation out of the factory which I was not aware of until I looked at the old brochures (motivated by this thread) was the wheel vs. tiller. I understand that our 2-30 had a wheel originally and it was pulled out & replaced by a tiller. We have the wheel in the garage (from the prev owner) and there is a patch on the cockpit deck where it was, so I know it was there. Most 29's and 30's I see either have a wheel or in the cases of a tiller, the owner had specifically pulled the wheel out to put a tiller in. But the old brochure I have shows a picture of the cockpit clearly having a tiller as well as the underway photo with her being steered by tiller.
Just thinking out loud...
Cheers -
Dyer
Honu, 1969 Cal 2-30, #87 / SF Bay, CA.
From:Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Mark Alan Stahnke (MAS Consulting)
Sent: Wednesday, February 13, 2013 4:49 PM
Mark A. Stahnke
MAS Consulting
(310) 832-5992
>From:Alex Kunadze
>To:Ca… [at] yahoogroups.com
>Sent:Wednesday, February 13, 2013 1:53 PM
>Subject:Re: [External] RE: [Cal_Boats] Is it time for the dreaded beam repla
>Alex offered:
>Alfred Poor
>http://www.eset.com
http://www.eset.com/
PG&E is committed to protecting our customers' privacy. To learn more, please visit http://www.pge.com/about/company/privacy/customer/
Re: [Cal_Boats] Is it time for the dreaded beam repla
Helen Horn2013-02-14 19:09 UTC
I have to respond to this comparison of the 29 and 30, they couldn't be more
different, especially in handling and hull configuration..look at
sailboatdata.com and compare the fin keel of the 29, it's prop location
vis-a-vis the rudder, the slower style more-for-cruising keel shape on the 30,
it takes an acre to turn the 30.
the basic cal 29's (not 2- and 3- s) came with the head, no head compartment
sink and the exception to this was custom orders,such as one which had the
tabbing doubled on the two bulkheads to the roof (currently in Half Moon Bay) by
the commissioning broker. My 1974 basic 29 had a wet (hanging)locker on starbd
opposite the head as original configuration. It also had a small drain port in
the floor of the pan(if a shower "could" be used and a similar hole in the wet
locker for drainage. As does the cal 36 for drainage though showers were not
necessarily installed either. In the 36, they made a gap between the cabinet
frontwall of the lockers to let water drain into the main pans. They came with
tillers, unless upgraded (2's, 3's) to more features, such as wheel steering,
second sink, shower head, etc.. And, there are quite a few locations for the
traveler on a 29..few were mounted aft, most forward just near the companionway
hatch (legbreakers) at different distances from the hatch for the tiller
models.the throttle/shift controls usually on port near the mount and the
gauges,etc panel on starbd also near the traveler. as for sailing, the 29 slices
through the water, the 30 bashes. try staying dry even in light airs in SF Bay
in a 30. the splashes hit the boat, wrap up over the cockpit, wrap around the
coaming and gets you and everyone in the cockpit from the rear as well, as it
has a rear bridge deck, unlike the quick-draining cockpit of the 29. I felt the
30 was more like the Westsail in hull shape and speed, maybe more ocean going,
and maybe more cruising comfort, but the 29 more than compensates for any
related challenges by it's hull speed, manueverability, and even layout.Helen
Sent: Thu, February 14, 2013 8:08:35 AM
Subject: RE: [Cal_Boats] Is it time for the dreaded beam repla
a sink being there.
a 30ft sailboat.
Cheers -
Dyer
Mark A. Stahnke
MAS Consulting
(310) 832-5992
>From:Alex Kunadze
>is to starboard.
>Alex offered:
>>layout.
>specs.)
>Alfred Poor
>http://www.eset.com
Mark Alan Stahnke (MAS Consulting)2013-02-14 19:23 UTC
What about interior wood? My 2-29 is teak and Stans 29 was mahogany. Is this indicative of model or availability?
Mark A. Stahnke
MAS Consulting
(310) 832-5992
Sent: Thursday, February 14, 2013 11:09 AM
Subject: Re: [Cal_Boats] Is it time for the dreaded beam repla
I have to respond to this comparison of the 29 and 30, they couldn't be more different, especially in handling and hull configuration..look at sailboatdata.com and compare the fin keel of the 29, it's prop location vis-a-vis the rudder, the slower style more-for-cruising keel shape on the 30, it takes an acre to turn the 30.
the basic cal 29's (not 2- and 3- s) came with the head, no head compartment sink and the exception to this was custom orders,such as one which had the tabbing doubled on the two bulkheads to the roof (currently in Half Moon Bay) by the commissioning broker. My 1974 basic 29 had a wet (hanging)locker on starbd opposite the head as original configuration. It also had a small drain port in the floor of the pan(if a shower "could" be used and a similar hole in the wet locker for drainage. As does the cal 36 for drainage though showers were not necessarily installed either. In the 36, they made a gap between the cabinet frontwall of the lockers to let water drain into the main pans. They came with tillers, unless upgraded (2's, 3's) to more features, such as wheel steering, second sink, shower head, etc.. And, there are quite a few locations for the traveler on a 29..few were mounted aft, most forward just near the companionway hatch (legbreakers) at different distances from the hatch for the tiller models.the throttle/shift controls usually on port near the mount and the gauges,etc panel on starbd also near the traveler. as for sailing, the 29 slices through the water, the 30 bashes. try staying dry even in light airs in SF Bay in a 30. the splashes hit the boat, wrap up over the cockpit, wrap around the coaming and gets you and everyone in the cockpit from the rear as well, as it has a rear bridge deck, unlike the quick-draining cockpit of the 29. I felt the 30 was more like the Westsail in hull shape and speed, maybe more ocean going, and maybe more cruising comfort, but the 29 more than compensates for any related challenges by it's hull speed, manueverability, and even layout.Helen
Cheers -
Dyer
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Mark Alan Stahnke (MAS Consulting)
Mark A. Stahnke
MAS Consulting
(310) 832-5992
Alex offered:
Alfred Poor
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 8011 (20130214) __________
http://www.eset.com
http://www.eset.com
Chris Campbell2013-02-14 19:30 UTC
This makes me grin. I learned early sailing skills on a S&S "Rainbow,"
a 24' fin-keeled, spade-ruddered sail training vessel designed for the
Annapolis Sailing School. I remember it as a very good boat. When you
wanted to come about, you gave the tiller a little poke to leeward and
the boat turned around. Then I started sailing on my old Seafarer
Polaris, a Tripp (the elder) keel-centerboard vessel with a low-aspect
mainsail and a long keel and keel-hung rudder. My brother and I and
friends went out sailing one night and as dusk fell we found ourselves
among stakes driven in to mark a dredging project. Hey, let's get outta
here. So I poked the tiller over to leeward. The boat headed up a
little bit and went into irons. Oh. So we fell off and I tried it
again. Same effect. So gradually it dawned on me that with this boat,
you gathered speed, made a nice graceful long arc of a turn, and it
would work. Long keel, long turn.
RE: [External] Re: [Cal_Boats] Is it time for the dreaded beam repla
Husar, Charlie [USA] (ASE)2013-02-14 21:28 UTC
Chris, Annapolis Sailing School still uses the Rainbows. They do look a bit tired. Also, it was an early bulb keel.
Wasn’t there another version of the same boat without the little cabin?
Sent: Thursday, February 14, 2013 2:31 PM
Subject: [External] Re: [Cal_Boats] Is it time for the dreaded beam repla
This makes me grin. I learned early sailing skills on a S&S "Rainbow," a 24' fin-keeled, spade-ruddered sail training vessel designed for the Annapolis Sailing School. I remember it as a very good boat. When you wanted to come about, you gave the tiller a little poke to leeward and the boat turned around. Then I started sailing on my old Seafarer Polaris, a Tripp (the elder) keel-centerboard vessel with a low-aspect mainsail and a long keel and keel-hung rudder. My brother and I and friends went out sailing one night and as dusk fell we found ourselves among stakes driven in to mark a dredging project. Hey, let's get outta here. So I poked the tiller over to leeward. The boat headed up a little bit and went into irons. Oh. So we fell off and I tried it again. Same effect. So gradually it dawned on me that with this boat, you gathered speed, made a nice graceful long arc of a turn, and it would work. Long keel, long turn.
Harleigh Ewell2013-02-14 21:45 UTC
The first boat that I actually owned was a Rainbow Weekender, which added a small cabin to the Rainbow. Leaving Annapolis in a driving rain storm on my first trip to Smith Island, our nighttime navigation technique was to sail to the middle of the Chesapeake Bay and follow the freighters. Those were simpler times.
Harleigh Ewell
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Husar, Charlie [USA] (ASE)
Sent: Thursday, February 14, 2013 4:29 PM
Subject: RE: [External] Re: [Cal_Boats] Is it time for the dreaded beam repla
Re: [External] Re: [Cal_Boats] Is it time for the dreaded beam repla
Chris Campbell2013-02-14 21:46 UTC
There were two versions--the Rainbow, with the huge, deep, self-bailing
cockpit--great for teaching nervous students--and the Weekender, the
same hull with a larger cabin. Not large, mind you, but larger. The
ones we used at the sailing school in Michigan (we had one of each) were
not built to bullet-proof standards, shall we say. But from time to
time I'll see one and have been surprised at how well they have held up
given their sub-Cal construction. I remember thinking that it was odd
that all boats didn't have bulb keels. And now I have a Cal 20 with an
iron bulb.
When I was a freshman in college, I was flying back to school after a
vacation. At the old Willow Run Airport outside Detroit I saw a
favorite high school teacher. He was flying back from Annapolis after
inspecting the sailing school operation with an eye toward getting a
Michigan franchise. He asked if I wanted a summer job. And by taking
that job I changed my whole life by becoming a sailor. Bill Plum, the
teacher, was a bit of a bon vivant, a good teacher, and a guy to whom
I've been forever grateful. He was killed in his British sports car
(MG??) one night when a guy who had worked an extra long shift at the
hospital fell asleep and hit him head-on. I never had a chance to thank
him. It's one of the few regrets I harbor. I'm weeping a bit as I type
this.
Chris
Chris Campbell2013-02-14 21:47 UTC
But the boats were sweet sailers, weren't they?
Harleigh Ewell2013-02-14 21:53 UTC
Yes they were.
Harleigh
Sent: Thursday, February 14, 2013 4:47 PM
Subject: Re: [External] Re: [Cal_Boats] Is it time for the dreaded beam repla
Husar, Charlie [USA] (ASE)2013-02-14 21:58 UTC
I wasn’t sure whether the cabin model or the non-cabin model was the plain Rainbow. Did the Rainbow bulb keel precede the CAL 20?
They apparently were not longitudinally very strong. I know a guy who had one crack in half across the beam while he was racing it. They were a one design racing fleet in Annapolis many years ago.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Harleigh Ewell
Sent: Thursday, February 14, 2013 4:46 PM
Harleigh Ewell
From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com] On Behalf Of Chris Campbell
Chris Campbell2013-02-15 04:07 UTC
As I recall, Nat Herreshoff designed fin-keeled boats with bulbs. I'm
guessing that the Cal 20 design came first but do not know when the
Rainbow was designed. Let's look at the S&S website--turns out the
Rainbow came along in 1961:
> http://sparkmanstephens.blogspot.com/2011/10/design-1701-rainbow-class.html
The Cal 20 was designed in 1960.
Not very strong, period. Or to be more flattering, "lightly built."
But I still recall the one we had at the sailing school being pleasant
to sail.
Chris
> Cheers
> Charlie
> *From:*Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]
> *On Behalf Of *Harleigh Ewell
> *Sent:* Thursday, February 14, 2013 4:46 PM
> *Subject:* RE: [External] Re: [Cal_Boats] Is it time for the dreaded
> beam repla
> Harleigh Ewell
> *On Behalf Of *Husar, Charlie [USA] (ASE)
> *Sent:* Thursday, February 14, 2013 4:29 PM
> beam repla
> Cheers
> Charlie
> *From:*Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
> [mailto:Ca… [at] yahoogroups.com] *On Behalf Of *Chris Campbell
> *Sent:* Thursday, February 14, 2013 2:31 PM
> *To:* Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
> *Subject:* [External] Re: [Cal_Boats] Is it time for the dreaded beam
> repla
> turn the 30.
> Chris Campbell
David Owen2013-02-15 04:56 UTC
Mariposa has teak that was stained "Mahogany." Look close -- probably the case.
Too busy this winter to be very active on this wonderful list. Love you guys. More later.
Wilkie
On Feb 14, 2013, at 11:23 AM, Mark Alan Stahnke (MAS Consulting) <ma… [at] cox.net> wrote:
Mark A. Stahnke
MAS Consulting
(310) 832-5992
Cheers -
Dyer
Mark A. Stahnke
MAS Consulting
(310) 832-5992
Alex offered:
Alfred Poor
http://www.eset.com
PG&E is committed to protecting our customers' privacy. To learn more, please visithttp://www.pge.com/about/company/privacy/customer/
http://www.eset.com
http://www.eset.com
