7 messages2013-03-03 03:16 UTCthrough 2013-03-03 17:22 UTC
Re: Filling Spar holes.Re: [Cal_Boats] Boom kicker for Cal 25
George Barlow2013-03-03 03:16 UTC
I was at Lowe's recently and spotted a selection of little plastic filler caps to fill small holes, down to 1/4 inch. They are in the hardware section. I'm planning to fill mine because in Texas we get mud daubers (small wasps that make nests of mud). They are hard on airplanes and motors because they seek out small hidden places for their nests. Not unusual to find them in throttle bodies on outboards. Here's a picture of the 3/8 in cap.
QuickView
Compare
The Hillman Group 2-Pack Plastic Hole Plugs
Not Yet Rated
$1.04
Qty.:
Add to Cart
Item #: 139442Model #: 881278
Hole Plugs - Black 3/8
2pc/bag
Black
George Barlow
Husar, Charlie [USA] (ASE)2013-03-03 03:29 UTC
George, we are usually talking screw holes which would be ¼" max or less. The bigger concern in our area is just stopping leaks since water could sit inside the boom or other places. I've had wasp nests in a boat before (doesn't take much sitting around to have it happen). I didn't know that wasps go into little holes as you describe, but now I won't be able to sleep tonight. Thanks a lot !!
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of George Barlow
Sent: Saturday, March 02, 2013 10:16 PM
Subject: [External] Re: Filling Spar holes.Re: [Cal_Boats] Boom kicker for Cal 25
[The Hillman Group 2-Pack Plastic Hole Plugs]<http://www.lowes.com/pd_139442-37672-881278_0__?productId=3013226&Ntt=plastic+hole+cap&pl=1¤tURL=%3FNtt%3Dplastic%2Bhole%2Bcap&facetInfo=>QuickView<http://www.lowes.com/Search=plastic+hole+cap?storeId=10151&langId=-1&catalogId=10051&N=0&newSearch=true&Ntt=plastic+hole+cap>
[ ] Compare
The Hillman Group 2-Pack Plastic Hole Plugs<http://www.lowes.com/pd_139442-37672-881278_0__?productId=3013226&Ntt=plastic+hole+cap&pl=1¤tURL=%3FNtt%3Dplastic%2Bhole%2Bcap&facetInfo=>
Not Yet Rated
$1.04
Qty.: 1
Add to CartThe Hillman Group 2-Pack Plastic Hole Plugs
· Item #: 139442
· Model #: 881278
· Hole Plugs - Black 3/8
· 2pc/bag
· Black
George Barlow
Michael D2013-03-03 06:59 UTC
I used JB Weld on Magic. It worked well. Marinetex probably would work well too.
Michael
Sent from Yahoo! Mail on Android
RE: [External] Re: Filling Spar holes.Re: [Cal_Boats] Boom kicker for Cal 25
Husar, Charlie [USA] (ASE)2013-03-03 15:16 UTC
Michael, I have also used JB Weld. Did the trick. Allen, the problem with putting screws into screw holes or pop rivet holes is that the head sticks up (thread sizes also play in). A new part is often placed over an old part area (but of course, the holes never fit the same pattern).
After drilling out a bunch of pop rivets in boom, on can shake the boom and it sounds like a maraca. It's the little things.
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Michael D
Sent: Sunday, March 03, 2013 2:00 AM
Michael
From: Husar, Charlie [USA] (ASE) <hu… [at] bah.com<mailto:hu… [at] bah.com>>;
To: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>>;
Subject: Re: Filling Spar holes.Re: [Cal_Boats] Boom kicker for Cal 25
Sent: Sun, Mar 3, 2013 3:29:48 AM
From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com] On Behalf Of George Barlow
[ ] Compare
Not Yet Rated
$1.04
Qty.: 1
* Item #: 139442
* Model #: 881278
* Hole Plugs - Black 3/8
* 2pc/bag
* Black
George Barlow
Re: [External] Re: Filling Spar holes.Re: [Cal_Boats] Boom kicker for Cal 25
Allen Edwards2013-03-03 15:53 UTC
If the new part is over the old hole, isn't that hole covered? Do you
aluminum boom guys use Sikaflex when you mount stuff on the boom?
On Sun, Mar 3, 2013 at 7:16 AM, Husar, Charlie [USA] (ASE) <
> old part area (but of course, the holes never fit the same pattern).****
> and it sounds like a maraca. It’s the little things.****
> Cheers****
> Charlie****
> Behalf Of *Michael D
> *Sent:* Sunday, March 03, 2013 2:00 AM
> *Subject:* [External] Re: Filling Spar holes.Re: [Cal_Boats] Boom kicker
> for Cal 25****
> well too. ****
> Michael****
> Sent from Yahoo! Mail on Android****
> *From: *Husar, Charlie [USA] (ASE) <hu… [at] bah.com>;
> *To: *Ca… [at] yahoogroups.com <Ca… [at] yahoogroups.com>;
> *Subject: *Re: Filling Spar holes.Re: [Cal_Boats] Boom kicker for Cal 25
> *Sent: *Sun, Mar 3, 2013 3:29:48 AM ****
> George, we are usually talking screw holes which would be ¼” max or less.
> inside the boom or other places. I’ve had wasp nests in a boat before
> (doesn’t take much sitting around to have it happen). I didn’t know that
> wasps go into little holes as you describe, but now I won’t be able to
> sleep tonight. Thanks a lot !!****
> Cheers****
> Charlie****
> *From:* Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com<Ca… [at] yahoogroups.com>]
> *On Behalf Of *George Barlow
> *Sent:* Saturday, March 02, 2013 10:16 PM
> for Cal 25****
> the 3/8 in cap.****
> *[image: The Hillman Group 2-Pack Plastic Hole Plugs]*<http://www.lowes.com/pd_139442-37672-881278_0__?productId=3013226&Ntt=plastic+hole+cap&pl=1¤tURL=%3FNtt%3Dplastic%2Bhole%2Bcap&facetInfo=>
> *QuickView*<http://www.lowes.com/Search=plastic+hole+cap?storeId=10151&langId=-1&catalogId=10051&N=0&newSearch=true&Ntt=plastic+hole+cap>
> [ ] Compare****
> *Not Yet Rated*****
> *$1.04*****
> Qty.: 1****
> Add to CartThe Hillman Group 2-Pack Plastic Hole Plugs****
> · Item #: 139442****
> · Model #: 881278****
> · Hole Plugs - Black 3/8****
> · 2pc/bag****
> · Black****
> ___________________****
> George Barlow****
Husar, Charlie [USA] (ASE)2013-03-03 16:10 UTC
Allen, the hole would not necessarily be covered unless I caulked the part into place, which I do not do. Sometimes it is a flat part (e.g., turning block) on a curved surface (boom or mast).. I do use Lanocote to minimize the reaction between stainless and aluminum.
Aluminum Boom Guy
Sent: Sunday, March 03, 2013 10:53 AM
Subject: Re: [External] Re: Filling Spar holes.Re: [Cal_Boats] Boom kicker for Cal 25
If the new part is over the old hole, isn't that hole covered? Do you aluminum boom guys use Sikaflex when you mount stuff on the boom?
On Sun, Mar 3, 2013 at 7:16 AM, Husar, Charlie [USA] (ASE) <hu… [at] bah.com<mailto:hu… [at] bah.com>> wrote:
From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>] On Behalf Of Michael D
Michael
[ ] Compare
Not Yet Rated
$1.04
Qty.: 1
* Item #: 139442
* Model #: 881278
* 2pc/bag
* Black
George Barlow
ca… [at] yahoo.com2013-03-03 17:22 UTC
Allumaloy will work
Connected by DROID on Verizon Wireless
Sent: Sun, Mar 3, 2013 15:53:44 GMT+00:00
On Sun, Mar 3, 2013 at 7:16 AM, Husar, Charlie [USA] (ASE) < hu… [at] bah.com > wrote:
After drilling out a bunch of pop rivets in boom, on can shake the boom and it sounds like a maraca. It’s the little things.
From: Ca… [at] yahoogroups.com [mailto: Ca… [at] yahoogroups.com ]
Michael
Husar, Charlie [USA] (ASE) < hu… [at] bah.com >;
To: Ca… [at] yahoogroups.com < Ca… [at] yahoogroups.com >;
George, we are usually talking screw holes which would be ¼” max or less. The bigger concern in our area is just stopping leaks since water could
sit inside the boom or other places. I’ve had wasp nests in a boat before (doesn’t take much sitting around to have it happen). I didn’t know that wasps go into little holes as you describe, but now I won’t be able to sleep tonight. Thanks a lot !!
Ca… [at] yahoogroups.com [ mailto:Ca… [at] yahoogroups.com ]
3/8 in cap.
QuickView
[ ] Compare
The
Not Yet Rated
$1.04
Qty.: 1
Add to Cart The Hillman Group 2-Pack Plastic Hole Plugs
Item #: 139442
Model #: 881278
2pc/bag
Black
George Barlow
