Replacement portlights
5 messages2013-03-14 00:41 through 2013-03-14 01:43
jimroddds2013-03-14 00:41
1971 Cal 39 Hull #8 aft fixed aluminum portlight frames need replacement what have others done for the early 39's or for any 39's for that matter
RE: [Cal_Boats] Replacement portlights
r good2013-03-14 01:19 UTC
cal 36Reggie To: Ca… [at] yahoogroups.com From: br… [at] yahoo.com Date: Thu, 14 Mar 2013 00:41:31 +0000 Subject: [Cal_Boats] Replacement portlights 1971 Cal 39 Hull #8 aft fixed aluminum portlight frames need replacement what have others done for the early 39's or for any 39's for that matter
Re: [Cal_Boats] Replacement portlights
Duane Knize2013-03-14 01:23 UTC
Jim, The later Cal39's, 1977+, have plastic frames for both the fixed and opening ports. Cal 40 may have comparable ports. For the 1977+ Cal 39 models the large fixed ports can be had from Mark Plastics in Corona Cal. I replaced mine 4 years ago. I replaced the 4 x 14 opening ports 20 years ago with Pompanette/Bomar direct replacements - these are no longer available. You can get 4 x 14 stainless steel opening ports from Newfound Metals, Port Townsend, Wash. Regards, Duane Knize Marlyn 1978 Cal 2-39, #18 On 3/13/2013 5:41 PM, jimroddds wrote: > > 1971 Cal 39 Hull #8 aft fixed aluminum portlight frames need > replacement what have others done for the early 39's or for any 39's > for that matter > >
Daniel Richmond2013-03-14 01:29 UTC
Hi I have looked into it for my early Cal 30. If you have the funds you can get new ones made that look verry much the same by a compony in Vancover Wa. I do not remember the name right off. I found it with a google search. Dan R On Wed, Mar 13, 2013 at 5:41 PM, jimroddds <br… [at] yahoo.com> wrote: > ** > > > 1971 Cal 39 Hull #8 aft fixed aluminum portlight frames need replacement > what have others done for the early 39's or for any 39's for that matter > > >
Re: Replacement portlights
John Caldwell2013-03-14 01:43
Mark Heacox at Mark Plastics (951-735-7705) does plastic and aluminum frames with acrylic or tempered glass for a variety of boats and a variety of Cal boats; and he original templates for most. A set of smoked tempered glass for my 2-29 ran about $250/each back in 2006. --- In Ca… [at] yahoogroups.com, "jimroddds" <brokerjim@...> wrote: > > 1971 Cal 39 Hull #8 aft fixed aluminum portlight frames need replacement what have others done for the early 39's or for any 39's for that matter >
