Re: [Cal_Boats] HID
Typically;
The HIN was in one of 2 formats:
CABxxhhhMyym or CABxxhhhmmyy
In either case, CAB = CAL Boats
xx = Model designation (25, 27, T2, 29, etc)
hhh = Hull Number or Class# (number of boats of that model built)
Myym = Model year Format, where yy = model year (ie: M77 == 1977 Model
year)
In that format, m = code letter for month (A = August, B = September, C =
October) and Model years ran August to July (example, 1977 Model year ran
Aug 1976 to July 1977).
mmyy = Alternate Format (used in early-mid 1970s by CAL)
where mm = Month (01 = Jan, 02 = Feb, .....12 = Dec) and yy = Year (77
for 1977)
The 12-digit HIN was used starting with the 1973 Model Year. Prior Model
years CAL marked each boat with a Hull# only, and it was marked on the
INSIDE of the transom, usually offset to starboard, marking looks like a
number (usually 3-digit) printed on a piece of paper and covered by a
thin layer of fiberglass cloth. Hull# also was marked on drawers in
Galley and any other loose parts.
Now, there is one complication in the Hull#s, and that is that CAL
(actually, JENSEN MARINE) had 2 Factories, building boats at the same
time one in Marlboro, NJ (1967-80) and one in Costa Mesa, CA (1959-80).
East Coast (NJ) boats had Hull#s starting with Even Numbers (235, 454,
602, etc) and West Coats (CA) boats had Hull#s starting with odd numbers
(185, 354, 555 ,etc.) Not all models were built at both plants, but I
know NJ Plant built the 20, 21, 25, 28,29, 2-46, perhaps others, West
Coast plant built all models for shipment to West Coast Dealers, and any
models not built in NJ for East Coast Dealers. The complication is that
there is no way to really tell how many boats total were built, since the
hulls were numbered as they came off 2 production lines at the same time,
so.... who knows whether CAL 21 Hull # 300 was built before or after
Hull# 285 (our old boat).
Production was exclusively in Florida from 1980 until moved to Fall
River, MA around 1985 (O'DAY Plant). For those years, only one set of
Hull#s was used for each Model.
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II #10201 (XDY10201M79E-D)
former co-owner of "NODROG"
1970 CAL 21 #285
On Sun, 28 Apr 2013 18:52:00 -0700 (PDT) Ronald Plank
<ro… [at] yahoo.com> writes:
4/28/13
The hull ID on transom of Cal 2-27 indicates information about that hull.
The last two digits indicate year built. Which numbers indicate Hull
number?
Ron
How to Sleep Like a Rock
Obey this one natural trick to fall asleep and stay asleep all night.
http://thirdpartyoffers.juno.com/TGL3141/517df64fcf97f764f2590st02duc
