How to resell hull to deck joint of my 1968 original Cal Cruising 46
12 messages2013-05-28 08:12 through 2013-05-30 02:03 UTC
edwmama2013-05-28 08:12
Hi all I noticed that the roll of paper towel that was tucked in a port side wall Storage area beneath my dinette in the pilothouse was showing signs of water intrusion I've concluded that its probably a leaky hull to deck joint although I have not ruled out stanchions leaking How do I approach this resealing hull to deck joints on my cal 46?
Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46
Jim Englert2013-05-28 18:03 UTC
I would rule out all other things before going at the hull & deck joint. My cal 29 leaks a bit there in spots. I removed the rub rail and tried 5200, it helped but didn't solve the problem. On my boat, the deck and hull make up the flange for the rub rail and it is riveted together. I have seen some people grind the flange off, but that is more work then I want to do and I want to keep the rub rail. My next approach will be to remove the rub rail, cut the rivets off, put tape on the underside to cover all the little holes where the rub rail was screwed in and I am going to fill the joint w some shredded glass cloth and epoxy in the places where the gap is large and colliodal silica and epoxy along the entire seam. I think this will be plenty strong and will seal it up. My only concern is the colliodal silica will be brittle and may crack if impacted. Just some ideas. Hope it helps. On Tue, May 28, 2013 at 4:12 AM, edwmama <ed… [at] gmail.com> wrote: > ** > > > Hi all > I noticed that the roll of paper towel that was tucked in a port side wall > Storage area beneath my dinette in the pilothouse was showing signs of > water intrusion > > I've concluded that its probably a leaky hull to deck joint although I > have not ruled out stanchions leaking > > How do I approach this resealing hull to deck joints on my cal 46? > > >
RE: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46
george macon2013-05-28 18:05 UTC
Move the paper towel roll inboard - problem solved! To: Ca… [at] yahoogroups.com From: sa… [at] gmail.com Date: Tue, 28 May 2013 14:03:16 -0400 Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 I would rule out all other things before going at the hull & deck joint. My cal 29 leaks a bit there in spots. I removed the rub rail and tried 5200, it helped but didn't solve the problem. On my boat, the deck and hull make up the flange for the rub rail and it is riveted together. I have seen some people grind the flange off, but that is more work then I want to do and I want to keep the rub rail. My next approach will be to remove the rub rail, cut the rivets off, put tape on the underside to cover all the little holes where the rub rail was screwed in and I am going to fill the joint w some shredded glass cloth and epoxy in the places where the gap is large and colliodal silica and epoxy along the entire seam. I think this will be plenty strong and will seal it up. My only concern is the colliodal silica will be brittle and may crack if impacted. Just some ideas. Hope it helps. On Tue, May 28, 2013 at 4:12 AM, edwmama <ed… [at] gmail.com> wrote: Hi all I noticed that the roll of paper towel that was tucked in a port side wall Storage area beneath my dinette in the pilothouse was showing signs of water intrusion I've concluded that its probably a leaky hull to deck joint although I have not ruled out stanchions leaking How do I approach this resealing hull to deck joints on my cal 46?
Gerald Sobel2013-05-28 19:03 UTC
It could be condensation, too! I noticed there is lots of that after the sun goes down. Warm air inside the boat holds lots of water vapor which deposits itself on interior surfaces as the air chills out. Jerry From: george macon <ge… [at] hotmail.com> To: "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com> Sent: Tuesday, May 28, 2013 11:05 AM Subject: RE: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 Move the paper towel roll inboard - problem solved! To: Ca… [at] yahoogroups.com From: sa… [at] gmail.com Date: Tue, 28 May 2013 14:03:16 -0400 Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 I would rule out all other things before going at the hull & deck joint. My cal 29 leaks a bit there in spots. I removed the rub rail and tried 5200, it helped but didn't solve the problem. On my boat, the deck and hull make up the flange for the rub rail and it is riveted together. I have seen some people grind the flange off, but that is more work then I want to do and I want to keep the rub rail. My next approach will be to remove the rub rail, cut the rivets off, put tape on the underside to cover all the little holes where the rub rail was screwed in and I am going to fill the joint w some shredded glass cloth and epoxy in the places where the gap is large and colliodal silica and epoxy along the entire seam. I think this will be plenty strong and will seal it up. My only concern is the colliodal silica will be brittle and may crack if impacted. Just some ideas. Hope it helps. On Tue, May 28, 2013 at 4:12 AM, edwmama <ed… [at] gmail.com> wrote: > >Hi all >I noticed that the roll of paper towel that was tucked in a port side wall >Storage area beneath my dinette in the pilothouse was showing signs of water intrusion > >I've concluded that its probably a leaky hull to deck joint although I have not ruled out stanchions leaking > >How do I approach this resealing hull to deck joints on my cal 46? > > >
edwmama2013-05-29 04:12 UTC
Great Idea Gerry I will have to take a closer look Thx Edwin Marina del Rey CA On May 28, 2013, at 12:03, Gerald Sobel <so… [at] yahoo.com> wrote: > It could be condensation, too! I noticed there is lots of that after the sun goes down. > Warm air inside the boat holds lots of water vapor which deposits itself on interior surfaces as the air chills out. > Jerry > > > From: george macon <ge… [at] hotmail.com> > To: "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com> > Sent: Tuesday, May 28, 2013 11:05 AM > Subject: RE: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 > > > > Move the paper towel roll inboard - problem solved! > > > > To: Ca… [at] yahoogroups.com > From: sa… [at] gmail.com > Date: Tue, 28 May 2013 14:03:16 -0400 > Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 > > > > I would rule out all other things before going at the hull & deck joint. My cal 29 leaks a bit there in spots. I removed the rub rail and tried 5200, it helped but didn't solve the problem. > On my boat, the deck and hull make up the flange for the rub rail and it is riveted together. I have seen some people grind the flange off, but that is more work then I want to do and I want to keep the rub rail. My next approach will be to remove the rub rail, cut the rivets off, put tape on the underside to cover all the little holes where the rub rail was screwed in and I am going to fill the joint w some shredded glass cloth and epoxy in the places where the gap is large and colliodal silica and epoxy along the entire seam. I think this will be plenty strong and will seal it up. My only concern is the colliodal silica will be brittle and may crack if impacted. > > Just some ideas. Hope it helps. > > > On Tue, May 28, 2013 at 4:12 AM, edwmama <ed… [at] gmail.com> wrote: > > Hi all > I noticed that the roll of paper towel that was tucked in a port side wall > Storage area beneath my dinette in the pilothouse was showing signs of water intrusion > > I've concluded that its probably a leaky hull to deck joint although I have not ruled out stanchions leaking > > How do I approach this resealing hull to deck joints on my cal 46? > > > > > > >
edwmama2013-05-29 04:15 UTC
Thx jim That's helpful Edwin Marina del Rey CA On May 28, 2013, at 11:03, Jim Englert <sa… [at] gmail.com> wrote: > I would rule out all other things before going at the hull & deck joint. My cal 29 leaks a bit there in spots. I removed the rub rail and tried 5200, it helped but didn't solve the problem. > On my boat, the deck and hull make up the flange for the rub rail and it is riveted together. I have seen some people grind the flange off, but that is more work then I want to do and I want to keep the rub rail. My next approach will be to remove the rub rail, cut the rivets off, put tape on the underside to cover all the little holes where the rub rail was screwed in and I am going to fill the joint w some shredded glass cloth and epoxy in the places where the gap is large and colliodal silica and epoxy along the entire seam. I think this will be plenty strong and will seal it up. My only concern is the colliodal silica will be brittle and may crack if impacted. > > Just some ideas. Hope it helps. > > > On Tue, May 28, 2013 at 4:12 AM, edwmama <ed… [at] gmail.com> wrote: > > Hi all > I noticed that the roll of paper towel that was tucked in a port side wall > Storage area beneath my dinette in the pilothouse was showing signs of water intrusion > > I've concluded that its probably a leaky hull to deck joint although I have not ruled out stanchions leaking > > How do I approach this resealing hull to deck joints on my cal 46? > > >
Allen Edwards2013-05-29 14:02 UTC
Run a hose on deck and see if it is a leak. That will also help you locate the source of the leak. Allen On Tue, May 28, 2013 at 9:15 PM, edwmama <ed… [at] gmail.com> wrote: > ** > > > Thx jim > > That's helpful > > Edwin > Marina del Rey CA > > Sent from my iPhone > > On May 28, 2013, at 11:03, Jim Englert <sa… [at] gmail.com> wrote: > > > > I would rule out all other things before going at the hull & deck joint. > My cal 29 leaks a bit there in spots. I removed the rub rail and tried > 5200, it helped but didn't solve the problem. > On my boat, the deck and hull make up the flange for the rub rail and it > is riveted together. I have seen some people grind the flange off, but that > is more work then I want to do and I want to keep the rub rail. My next > approach will be to remove the rub rail, cut the rivets off, put tape on > the underside to cover all the little holes where the rub rail was screwed > in and I am going to fill the joint w some shredded glass cloth and epoxy > in the places where the gap is large and colliodal silica and epoxy along > the entire seam. I think this will be plenty strong and will seal it up. > My only concern is the colliodal silica will be brittle and may crack if > impacted. > > Just some ideas. Hope it helps. > > > On Tue, May 28, 2013 at 4:12 AM, edwmama < <ed… [at] gmail.com> > ed… [at] gmail.com> wrote: > >> ** >> >> >> Hi all >> I noticed that the roll of paper towel that was tucked in a port side wall >> Storage area beneath my dinette in the pilothouse was showing signs of >> water intrusion >> >> I've concluded that its probably a leaky hull to deck joint although I >> have not ruled out stanchions leaking >> >> How do I approach this resealing hull to deck joints on my cal 46? >> >> > >
Mark Alan Stahnke (MAS Consulting)2013-05-29 22:36 UTC
Also, one might try pressurizing the cabin with an electric shop vac with leaf blower. Set up the leaf blower inside and close up cabin to increase pressure. Now with the cabin pressurized, take a squirt bottle with soapy water and test all thru deck fittings. Any traceable leakage will create active bubbles. Mark A. Stahnke MAS Consulting (310) 832-5992 The information in this electronic mail transmission covered by the electronic communications privacy act (18 USC Sections 2510-2521) is confidential and intended to be sent only to the stated recipient(s) of the transmission. It may therefore be protected from unauthorized use or dissemination by client/attorney work-product privileges. If you are not the intended recipient or the intended recipient's agent, you are hereby notified that any review, use, dissemination or copying of this communication is strictly prohibited. You are also asked to notify us immediately by telephone and to delete/destroy the original. ----- Original Message ----- From: edwmama To: Ca… [at] yahoogroups.com Sent: Tuesday, May 28, 2013 9:12 PM Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 Great Idea Gerry I will have to take a closer look Thx Edwin Marina del Rey CA Sent from my iPhone On May 28, 2013, at 12:03, Gerald Sobel <so… [at] yahoo.com> wrote: It could be condensation, too! I noticed there is lots of that after the sun goes down. Warm air inside the boat holds lots of water vapor which deposits itself on interior surfaces as the air chills out. Jerry ---------------------------------------------------------------------------- From: george macon <ge… [at] hotmail.com> To: "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com> Sent: Tuesday, May 28, 2013 11:05 AM Subject: RE: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 Move the paper towel roll inboard - problem solved! ---------------------------------------------------------------------------- To: Ca… [at] yahoogroups.com From: sa… [at] gmail.com Date: Tue, 28 May 2013 14:03:16 -0400 Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 I would rule out all other things before going at the hull & deck joint. My cal 29 leaks a bit there in spots. I removed the rub rail and tried 5200, it helped but didn't solve the problem. On my boat, the deck and hull make up the flange for the rub rail and it is riveted together. I have seen some people grind the flange off, but that is more work then I want to do and I want to keep the rub rail. My next approach will be to remove the rub rail, cut the rivets off, put tape on the underside to cover all the little holes where the rub rail was screwed in and I am going to fill the joint w some shredded glass cloth and epoxy in the places where the gap is large and colliodal silica and epoxy along the entire seam. I think this will be plenty strong and will seal it up. My only concern is the colliodal silica will be brittle and may crack if impacted. Just some ideas. Hope it helps. On Tue, May 28, 2013 at 4:12 AM, edwmama <ed… [at] gmail.com> wrote: Hi all I noticed that the roll of paper towel that was tucked in a port side wall Storage area beneath my dinette in the pilothouse was showing signs of water intrusion I've concluded that its probably a leaky hull to deck joint although I have not ruled out stanchions leaking How do I approach this resealing hull to deck joints on my cal 46? __________ Information from ESET NOD32 Antivirus, version of virus signature database 8386 (20130528) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 8390 (20130529) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com
Allen Edwards2013-05-30 01:03 UTC
That is so cool an idea. Does it work? ;-) On Wed, May 29, 2013 at 3:36 PM, Mark Alan Stahnke (MAS Consulting) < ma… [at] cox.net> wrote: > ** > > > ** > Also, one might try pressurizing the cabin with an electric shop vac > with leaf blower. Set up the leaf blower inside and close up cabin > to increase pressure. > Now with the cabin pressurized, take a squirt bottle with soapy water and > test all thru deck fittings. Any traceable leakage will create active > bubbles. > > > Mark A. Stahnke > MAS Consulting > (310) 832-5992 > > The information in this electronic mail transmission covered by the > electronic communications privacy act (18 USC Sections 2510-2521) is > confidential and intended to be sent only to the stated recipient(s) of the > transmission. It may therefore be protected from unauthorized use or > dissemination by client/attorney work-product privileges. If you are not > the intended recipient or the intended recipient's agent, you are hereby > notified that any review, use, dissemination or copying of this > communication is strictly prohibited. You are also asked to notify us > immediately by telephone and to delete/destroy the original. > > > > > ----- Original Message ----- > *From:* edwmama <ed… [at] gmail.com> > *To:* Ca… [at] yahoogroups.com > *Sent:* Tuesday, May 28, 2013 9:12 PM > *Subject:* Re: [Cal_Boats] How to resell hull to deck joint of my 1968 > original Cal Cruising 46 > > > > Great Idea Gerry > I will have to take a closer look > > Thx > > Edwin > Marina del Rey CA > > Sent from my iPhone > > On May 28, 2013, at 12:03, Gerald Sobel <so… [at] yahoo.com> wrote: > > > > It could be condensation, too! I noticed there is lots of that after the > sun goes down. > Warm air inside the boat holds lots of water vapor which deposits itself > on interior surfaces as the air chills out. > Jerry > > > ------------------------------ > *From:* george macon <ge… [at] hotmail.com> > *To:* "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com> > *Sent:* Tuesday, May 28, 2013 11:05 AM > *Subject:* RE: [Cal_Boats] How to resell hull to deck joint of my 1968 > original Cal Cruising 46 > > > > Move the paper towel roll inboard - problem solved! > > > > ------------------------------ > To: <Ca… [at] yahoogroups.com>Ca… [at] yahoogroups.com > From: <sa… [at] gmail.com>sa… [at] gmail.com > Date: Tue, 28 May 2013 14:03:16 -0400 > Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 > original Cal Cruising 46 > > > > I would rule out all other things before going at the hull & deck > joint. My cal 29 leaks a bit there in spots. I removed the rub rail and > tried 5200, it helped but didn't solve the problem. > On my boat, the deck and hull make up the flange for the rub rail and it > is riveted together. I have seen some people grind the flange off, but that > is more work then I want to do and I want to keep the rub rail. My next > approach will be to remove the rub rail, cut the rivets off, put tape on > the underside to cover all the little holes where the rub rail was screwed > in and I am going to fill the joint w some shredded glass cloth and epoxy > in the places where the gap is large and colliodal silica and epoxy along > the entire seam. I think this will be plenty strong and will seal it up. > My only concern is the colliodal silica will be brittle and may crack if > impacted. > > Just some ideas. Hope it helps. > > > On Tue, May 28, 2013 at 4:12 AM, edwmama < <ed… [at] gmail.com> > ed… [at] gmail.com> wrote: > > ** > > Hi all > I noticed that the roll of paper towel that was tucked in a port side wall > Storage area beneath my dinette in the pilothouse was showing signs of > water intrusion > > I've concluded that its probably a leaky hull to deck joint although I > have not ruled out stanchions leaking > > How do I approach this resealing hull to deck joints on my cal 46? > > > > > > > > > __________ Information from ESET NOD32 Antivirus, version of virus > signature database 8386 (20130528) __________ > > The message was checked by ESET NOD32 Antivirus. > > http://www.eset.com > > > > __________ Information from ESET NOD32 Antivirus, version of virus > signature database 8390 (20130529) __________ > > The message was checked by ESET NOD32 Antivirus. > > http://www.eset.com > > >
Gerald Sobel2013-05-30 01:13 UTC
Maties, So far we have the water hose method, and the air pressure soap bubble method. I propose a third way, over canvas the boat and take it off shore in heavy seas, in 25 to 30 knots, leaving a crewman below who is impervious to sea sickness, to look for water dribbling down below. It should be easy, since he or she only needs to look for a leak on the leeward side, well, mostly. Jerry PS: The air pressure method sounds pretty neat, but it sounds like a job sealing up all the vents, hatches, and companionways with quack tape or masking tape. At least you don't have to leave someone below to up chuck or suffocate, now that I think of it. But, way you kill two crew with one bash. From: Allen Edwards <al… [at] gmail.com> To: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com> Sent: Wednesday, May 29, 2013 6:03 PM Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 That is so cool an idea. Does it work? ;-) On Wed, May 29, 2013 at 3:36 PM, Mark Alan Stahnke (MAS Consulting) <ma… [at] cox.net> wrote: > > >Also, one might try pressurizing the cabin with an electric shop vac with leaf blower. Set up the leaf blower inside and close up cabin to increase pressure. >Now with the cabin pressurized, take a squirt bottle with soapy water and test all thru deck fittings. Any traceable leakage will create active bubbles. > > >Mark A. Stahnke >MAS Consulting >(310) 832-5992 > >The information in this electronic mail transmission covered by the electronic communications privacy act (18 USC Sections 2510-2521) is confidential and intended to be sent only to the stated recipient(s) of the transmission. It may therefore be protected from unauthorized use or dissemination by client/attorney work-product privileges. If you are not the intended recipient or the intended recipient's agent, you are hereby notified that any review, use, dissemination or copying of this communication is strictly prohibited. You are also asked to notify us immediately by telephone and to delete/destroy the original. > > > >----- Original Message ----- >>From: edwmama >>To: Ca… [at] yahoogroups.com >>Sent: Tuesday, May 28, 2013 9:12 PM >>Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 >> >> >>Great Idea Gerry >>I will have to take a closer look >> >> >>Thx >> >> >>Edwin >>Marina del Rey CA >> >>Sent from my iPhone >> >>On May 28, 2013, at 12:03, Gerald Sobel <so… [at] yahoo.com> wrote: >> >> >> >>>It could be condensation, too! I noticed there is lots of that after the sun goes down. >>>Warm air inside the boat holds lots of water vapor which deposits itself on interior surfaces as the air chills out. >>>Jerry >>> >>> >>> >>> >>> >>> >>>________________________________ >>> From: george macon <ge… [at] hotmail.com> >>>To: "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com> >>>Sent: Tuesday, May 28, 2013 11:05 AM >>>Subject: RE: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 >>> >>> >>> >>> >>> >>>Move the paper towel roll inboard - problem solved! >>> >>> >>> >>> >>> >>>________________________________ >>> To: Ca… [at] yahoogroups.com >>>From: sa… [at] gmail.com >>>Date: Tue, 28 May 2013 14:03:16 -0400 >>>Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 >>> >>> >>> >>> >>>I would rule out all other things before going at the hull & deck joint. My cal 29 leaks a bit there in spots. I removed the rub rail and tried 5200, it helped but didn't solve the problem. >>> >>>On my boat, the deck and hull make up the flange for the rub rail and it is riveted together. I have seen some people grind the flange off, but that is more work then I want to do and I want to keep the rub rail. My next approach will be to remove the rub rail, cut the rivets off, put tape on the underside to cover all the little holes where the rub rail was screwed in and I am going to fill the joint w some shredded glass cloth and epoxy in the places where the gap is large and colliodal silica and epoxy along the entire seam. I think this will be plenty strong and will seal it up. My only concern is the colliodal silica will be brittle and may crack if impacted. >>> >>> >>>Just some ideas. Hope it helps. >>> >>> >>> >>> >>>On Tue, May 28, 2013 at 4:12 AM, edwmama <ed… [at] gmail.com> wrote: >>> >>> >>>> >>>>Hi all >>>>I noticed that the roll of paper towel that was tucked in a port side wall >>>>Storage area beneath my dinette in the pilothouse was showing signs of water intrusion >>>> >>>>I've concluded that its probably a leaky hull to deck joint although I have not ruled out stanchions leaking >>>> >>>>How do I approach this resealing hull to deck joints on my cal 46? >>>> >>>> >>>> >>> >>> >>> >>> >> >>__________ Information from ESET NOD32 Antivirus, version of virus signature database 8386 (20130528) __________ >> >>The message was checked by ESET NOD32 Antivirus. >> >>http://www.eset.com >> > >__________ Information from ESET NOD32 Antivirus, version of virus signature database 8390 (20130529) __________ > >The message was checked by ESET NOD32 Antivirus. > >http://www.eset.com >
Dave & Cathy Paulson2013-05-30 01:19 UTC
That is how I found the leaks in my sunfish Dave Paulson ----- Original Message ----- From: Allen Edwards To: Ca… [at] yahoogroups.com Sent: Wednesday, May 29, 2013 6:03 PM Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 That is so cool an idea. Does it work? ;-) On Wed, May 29, 2013 at 3:36 PM, Mark Alan Stahnke (MAS Consulting) <ma… [at] cox.net> wrote: Also, one might try pressurizing the cabin with an electric shop vac with leaf blower. Set up the leaf blower inside and close up cabin to increase pressure. Now with the cabin pressurized, take a squirt bottle with soapy water and test all thru deck fittings. Any traceable leakage will create active bubbles. Mark A. Stahnke MAS Consulting (310) 832-5992 The information in this electronic mail transmission covered by the electronic communications privacy act (18 USC Sections 2510-2521) is confidential and intended to be sent only to the stated recipient(s) of the transmission. It may therefore be protected from unauthorized use or dissemination by client/attorney work-product privileges. If you are not the intended recipient or the intended recipient's agent, you are hereby notified that any review, use, dissemination or copying of this communication is strictly prohibited. You are also asked to notify us immediately by telephone and to delete/destroy the original. ----- Original Message ----- From: edwmama To: Ca… [at] yahoogroups.com Sent: Tuesday, May 28, 2013 9:12 PM Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 Great Idea Gerry I will have to take a closer look Thx Edwin Marina del Rey CA Sent from my iPhone On May 28, 2013, at 12:03, Gerald Sobel <so… [at] yahoo.com> wrote: It could be condensation, too! I noticed there is lots of that after the sun goes down. Warm air inside the boat holds lots of water vapor which deposits itself on interior surfaces as the air chills out. Jerry ------------------------------------------------------------------------ From: george macon <ge… [at] hotmail.com> To: "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com> Sent: Tuesday, May 28, 2013 11:05 AM Subject: RE: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 Move the paper towel roll inboard - problem solved! ------------------------------------------------------------------------ To: Ca… [at] yahoogroups.com From: sa… [at] gmail.com Date: Tue, 28 May 2013 14:03:16 -0400 Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 I would rule out all other things before going at the hull & deck joint. My cal 29 leaks a bit there in spots. I removed the rub rail and tried 5200, it helped but didn't solve the problem. On my boat, the deck and hull make up the flange for the rub rail and it is riveted together. I have seen some people grind the flange off, but that is more work then I want to do and I want to keep the rub rail. My next approach will be to remove the rub rail, cut the rivets off, put tape on the underside to cover all the little holes where the rub rail was screwed in and I am going to fill the joint w some shredded glass cloth and epoxy in the places where the gap is large and colliodal silica and epoxy along the entire seam. I think this will be plenty strong and will seal it up. My only concern is the colliodal silica will be brittle and may crack if impacted. Just some ideas. Hope it helps. On Tue, May 28, 2013 at 4:12 AM, edwmama <ed… [at] gmail.com> wrote: Hi all I noticed that the roll of paper towel that was tucked in a port side wall Storage area beneath my dinette in the pilothouse was showing signs of water intrusion I've concluded that its probably a leaky hull to deck joint although I have not ruled out stanchions leaking How do I approach this resealing hull to deck joints on my cal 46? __________ Information from ESET NOD32 Antivirus, version of virus signature database 8386 (20130528) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 8390 (20130529) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com
Brian McNamara2013-05-30 02:03 UTC
I removed the rubrail (gunnel) and repaired the damaged flange by building it up with fiberglass cloth then sanding it smooth. Then I scraped out the sealant in the hull deck joint and cleaned the surface with scotchbrite pad, nylon brush and soap and water then alcohol. Then I sealed the joint with an industrial adhesive sealant that I like. High bonding strength while remaining flexible to retain seal during temperature expansion or boat flex. There's no more water in the boat. That was the source alright. One more job done. From: edwmama <ed… [at] gmail.com> To: "Ca… [at] yahoogroups.com" <Ca… [at] yahoogroups.com> Sent: Wednesday, May 29, 2013 12:12 AM Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 Great Idea Gerry I will have to take a closer look Thx Edwin Marina del Rey CA On May 28, 2013, at 12:03, Gerald Sobel <so… [at] yahoo.com> wrote: >It could be condensation, too! I noticed there is lots of that after the sun goes down. >Warm air inside the boat holds lots of water vapor which deposits itself on interior surfaces as the air chills out. >Jerry > > > > > > >________________________________ > From: george macon <ge… [at] hotmail.com> >To: "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com> >Sent: Tuesday, May 28, 2013 11:05 AM >Subject: RE: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 > > > > > >Move the paper towel roll inboard - problem solved! > > > > > >________________________________ >To: Ca… [at] yahoogroups.com >From: sa… [at] gmail.com >Date: Tue, 28 May 2013 14:03:16 -0400 >Subject: Re: [Cal_Boats] How to resell hull to deck joint of my 1968 original Cal Cruising 46 > > > > >I would rule out all other things before going at the hull & deck joint. My cal 29 leaks a bit there in spots. I removed the rub rail and tried 5200, it helped but didn't solve the problem. > >On my boat, the deck and hull make up the flange for the rub rail and it is riveted together. I have seen some people grind the flange off, but that is more work then I want to do and I want to keep the rub rail. My next approach will be to remove the rub rail, cut the rivets off, put tape on the underside to cover all the little holes where the rub rail was screwed in and I am going to fill the joint w some shredded glass cloth and epoxy in the places where the gap is large and colliodal silica and epoxy along the entire seam. I think this will be plenty strong and will seal it up. My only concern is the colliodal silica will be brittle and may crack if impacted. > > >Just some ideas. Hope it helps. > > > > >On Tue, May 28, 2013 at 4:12 AM, edwmama <ed… [at] gmail.com> wrote: > > >> >>Hi all >>I noticed that the roll of paper towel that was tucked in a port side wall >>Storage area beneath my dinette in the pilothouse was showing signs of water intrusion >> >>I've concluded that its probably a leaky hull to deck joint although I have not ruled out stanchions leaking >> >>How do I approach this resealing hull to deck joints on my cal 46? >> >> >> > > > >
