7 messages2013-06-13 15:44 through 2013-06-14 14:52 UTC
Cal 28 mast base plate & hull ID
ewan.anderson2013-06-13 15:44
Hi all,
Just bought a Cal 28 and I have a long list of upgrades (and fixes, of course). Among those is installing a halyard organiser plate under the mast base. Does anyone have photos of one of these on a Cal 28 with turning blocks, vang, etc attached?
Second part: does anyone know where to find a hull number for a Cal 28, likely manufactured by CalGan Marine in North Van? The boat came with no papers... I love a good mystery!
Cheers,
Ewan
'Kali'
Victoria, BC
Re: [Cal_Boats] Cal 28 mast base plate & hull ID
Adam Thorp2013-06-13 16:36 UTC
What year is your cal 28?
I have a 1964 Cal 28 flattop and machined a deck plate out of stainless
steel to fit under my aluminum tabernacle. I also machined a g10 plate to
sit between the two to prevent galvanic corrosion.
I can post pictures tonight.
On Thu, Jun 13, 2013 at 8:44 AM, ewan.anderson <
ew… [at] googlemail.com> wrote:
> Hi all,
> Cheers,
> Ewan
> 'Kali'
> Victoria, BC
RE: [External] Re: [Cal_Boats] Cal 28 mast base plate & hull ID
Husar, Charlie [USA] (ASE)2013-06-13 19:01 UTC
I can send pictures for a CAL 25 if you need. The real trick is in placing the deck organizers. Do you have mast dimensions (section width and length)?
Take Care
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Adam Thorp
Sent: Thursday, June 13, 2013 12:37 PM
To: cal_boats
Subject: [External] Re: [Cal_Boats] Cal 28 mast base plate & hull ID
I have a 1964 Cal 28 flattop and machined a deck plate out of stainless steel to fit under my aluminum tabernacle. I also machined a g10 plate to sit between the two to prevent galvanic corrosion.
On Thu, Jun 13, 2013 at 8:44 AM, ewan.anderson <ew… [at] googlemail.com<mailto:ew… [at] googlemail.com>> wrote:
Hi all,
Cheers,
Ewan
'Kali'
Victoria, BC
ewan.anderson2013-06-13 20:17
Adam: I don't have the tools or skills to machine my own parts, so I'm
trying to source something out locally (would be great to do that sort
of thing on my own though...). I have no idea what year my boat is -
probably one of the 300 Cals built in North Vancouver by Al Nairne.
I've posted a few photos of the boat; I'll post a few more after
haul-out this weekend. There's another Cal 28 ('Late Riser') with a
base plate at my marina...I'll post a photo in my album "Cal 28 'Kali'".
Charlie: rough measurements are 7 x 41/2" at the base. I thought there
would be specs for a standard mass section for Cal 28s online, but I
couldn't find them. I'm definitely curious about what other Cal owners
have done, so I'd love to see some photos.
Ewan
and length)?
> Take Care
> Charlie
> To: cal_boats
> On Thu, Jun 13, 2013 at 8:44 AM, ewan.anderson ewan.r.anderson@...
wrote:
> Hi all,
> Cheers,
> Ewan
> 'Kali'
> Victoria, BC
Re: [External] Re: [Cal_Boats] Cal 28 mast base plate & hull ID
Terrence Spencer2013-06-13 21:31 UTC
Check the mast base plates that are available through Seal's Spars. That is where I got one for my Cal 2-29.
Terry
On Jun 13, 2013, at 1:17 PM, "ewan.anderson" <ew… [at] googlemail.com> wrote:
> Adam: I don't have the tools or skills to machine my own parts, so I'm trying to source something out locally (would be great to do that sort of thing on my own though...). I have no idea what year my boat is - probably one of the 300 Cals built in North Vancouver by Al Nairne. I've posted a few photos of the boat; I'll post a few more after haul-out this weekend. There's another Cal 28 ('Late Riser') with a base plate at my marina...I'll post a photo in my album "Cal 28 'Kali'".
> Charlie: rough measurements are 7 x 41/2" at the base. I thought there would be specs for a standard mass section for Cal 28s online, but I couldn't find them. I'm definitely curious about what other Cal owners have done, so I'd love to see some photos.
> Ewan
> > Take Care
> > Charlie
> > To: cal_boats
> > On Thu, Jun 13, 2013 at 8:44 AM, ewan.anderson ewan.r.anderson@... wrote:
> > Hi all,
> > Cheers,
> > Ewan
> > 'Kali'
> > Victoria, BC
Jeff Raethke2013-06-14 04:32 UTC
Ewan
FWIW Rigrite lists a 4060 MORC mast section it lists as being used on the Cal 28. That would be a 4" x 6" cross section. Rigrite also lists mast plates by size in another area on its website.
Good luck
Jeff Raethke
Cal 2-25
"Molly Rose"
On Jun 13, 2013, at 3:17 PM, "ewan.anderson" <ew… [at] googlemail.com> wrote:
> Ewan
> > Take Care
> > Charlie
> > To: cal_boats
> > Hi all,
> > Cheers,
> > Ewan
> > 'Kali'
> > Victoria, BC
Adam Thorp2013-06-14 14:52 UTC
I'm not able to sign in to yahoo and upload pictures, hope this works.
[image: Inline image 2][image: Inline image 3][image: Inline image 1]
On Thu, Jun 13, 2013 at 9:32 PM, Jeff Raethke <js… [at] yahoo.com> wrote:
> Ewan
> Good luck
> Jeff Raethke
> Cal 2-25
> "Molly Rose"
> Ewan
> length)?
> > Take Care
> > Charlie
> > From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com<Ca… [at] yahoogroups.com>]
> > To: cal_boats
> wrote:
> > Hi all,
> > Cheers,
> > Ewan
> > 'Kali'
> > Victoria, BC
