2 messages2013-07-24 15:46 UTCthrough 2013-07-24 17:13 UTC
Re: [Cal_Boats] Strange engine problem
Bruce Boyles2013-07-24 15:46 UTC
Did you check impeller? I have killed more than one by forgetting to open thru hull.
Allen Edwards <al… [at] gmail.com> wrote:
>It is a raw water cooled engine. As it has been fine for over a year I am
>thinking wondering what was different this time. Thanks to a chat with
>Chris123 I am thinking it was something like this:
>1) Start the engine at low RPM. Forgot to check stern for flow. (Mistake
>one and two)
>2) Pump did not have flow as it needs a little kick of RPM to prime it
>3) Overheat and alarm
>4) Checked oil pressure and increased RPM creating flow
>5) Check stern and see flow and steam
>6) Check head which had just been cooled by the sea water now flowing
>through it.
>But I don't really remember the sequence of events, when I increased the
>RPM and when I checked the exhaust. This I guess is a best case
>explanation so I hope it is correct. The only problem is that if the head
>overheated, I would think it would have been at least as hot as the engine
>is when warmed up and it was not.
>In the past I have had trouble with pumps not drawing prime, particularly
>pumps from this rebuilder. I think I mentioned in another thread that I
>had been using Depco pumps but with the rebuild that is no longer the case.
> Increasing the RPM at start, which I typically do, helps to get prime.
>They say that failures are usually a combination of things, not just one.
> If it happened like I am saying, it would be a combination of not giving
>the engine enough RPM at start and not checking the stern for water. I
>usually do both of these things.
>Allen
>On Wed, Jul 24, 2013 at 6:46 AM, r good <my… [at] hotmail.com> wrote:
>> bad typing and no spell check!
>> Reggie
>> To: ca… [at] yahoogroups.com
>> From: my… [at] hotmail.com
>> Date: Wed, 24 Jul 2013 07:44:31 -0600
>> Subject: RE: [Cal_Boats] Strange engine problem
>> haust hose replaced when engine rebuilt? inside layer of exhaust howe
>> can crack, delaminate, and create flaps which may/will get in the way of
>> flow.. The hose looks great on the outside, but...
>> Reggie
>> To: Ca… [at] yahoogroups.com
>> From: al… [at] gmail.com
>> Date: Tue, 23 Jul 2013 23:45:43 -0700
>> Subject: [Cal_Boats] Strange engine problem
>> Coming back from a race tonight the engine alarm went off. I checked
>> the oil pressure and it was OK. Then I checked the exhaust and saw both
>> steam and lots of water. I increased the revs and the alarm quit. My plan
>> is to take the water pump apart and flush the engine. This is a Gary
>> marine rebuilt a year and a half ago. I also felt the head and I could
>> easily put my hand on it, it was not hot. But something was making the
>> steam as when I looked after the alarm went off things looked normal -- no
>> steam.
>> Anyone have any ideas what could be going on?
>> Allen
Allen Edwards2013-07-24 17:13 UTC
I will check it tomorrow.
> thru hull.
> one and two)
> through it.
> Allen
>> Reggie
>> Reggie
>> steam.
>> Allen
