4 messages2013-08-07 20:45 UTCthrough 2013-08-08 16:02 UTC
Stainless vs. bronze slider for external main track.
Dylan Crouch2013-08-07 20:45 UTC
I have an old external track on our Cal 2-30 and I am looking at replacing the old ones that came with the boat (I believe they are bronze?), with the stainless steel ones that Bainbridge sells.
In addition to the SS ones having a better gap for the external track to slide through, I would imagine they have less friction as well.
Anyone have experience with these?
Before anyone suggests:
A: Clean and lube the external track (done that).
B: Add a "Strong Track" sail track. I have looked at those and they are a bit of overkill for my purposes. I am almost there with how I want the mainsail & just getting a little less friction is my goal. Besides, a strong track will be in the $700 dollar range vs. $150 in new sliders.
Thanks in advance -
Dyer
Honu, 1969 Cal 2-30 #87
SF Bay.
Re: [Cal_Boats] Stainless vs. bronze slider for external main track.
Allen Edwards2013-08-08 14:45 UTC
I think you are talking about using stainless steel slides on the sail. It
is a little hard to tell from your description. Don't do it. When I
bought my new sails, we were careful to strip the bronze slides off the old
sails and use them on the new sails. Bronze is a nice low friction
material and is used for bearings when ball bearings cannot carry the load.
Go to your local Ace hardware and look at the bronze bushings they sell.
While you are there, buy some Super Lube Dry lube.
> Thanks in advance -
> Dyer
> SF Bay.
RE: [Cal_Boats] Stainless vs. bronze slider for external main track.
Ted Wrobel2013-08-08 15:55 UTC
Hi Allen,
Think your are not quite right about bronze as a bearing material. The
bronse used for bearings is sintered, oil impregnated bronse. Tiny spheres
of bronze are sintered into a solid, porus material and oil is then forced
into the spaces.
The coefficient of dry bronze and steel on cast iron are virtually identical
(0.23 vs 0.22), on aluminum they are also nearly identical.
Ted
Cal 33 Celebration
Newport, RI
Of Allen Edwards
Sent: Thursday, August 08, 2013 10:45 AM
Subject: Re: [Cal_Boats] Stainless vs. bronze slider for external main
track.
is a little hard to tell from your description. Don't do it. When I bought
my new sails, we were careful to strip the bronze slides off the old sails
and use them on the new sails. Bronze is a nice low friction material and
is used for bearings when ball bearings cannot carry the load. Go to your
local Ace hardware and look at the bronze bushings they sell. While you are
Thanks in advance -
Dyer
SF Bay.
No virus found in this message.
Checked by AVG - www.avg.com
Version: 10.0.1432 / Virus Database: 3209/6059 - Release Date: 08/08/13
george macon2013-08-08 16:02 UTC
I had my old bronze slides moved to my new Pentex main on my Cal25. I felt it was an immediate improvement. No binding! As of late, I have noticed the sailmakers now use a Nylon slider instead of the stainless. I asked about the Bronze slider and I recall them being not available, or out of price range.
George Macon
Date: Thu, 8 Aug 2013 11:55:58 -0400
Subject: RE: [Cal_Boats] Stainless vs. bronze slider for external main track.
Hi
Allen,
Think
your are not quite right about bronze as a bearing material. The bronse used for
bearings is sintered, oil impregnated bronse. Tiny spheres of bronze are
sintered into a solid, porus material and oil is then forced into the
spaces.
The
coefficient of dry bronze and steel on cast iron are virtually identical (0.23
Ted
Cal 33
Celebration
Newport, RI
[mailto:Ca… [at] yahoogroups.com] On Behalf Of Allen
Edwards
To:
sail. It is a little hard to tell from your description. Don't do
it. When I bought my new sails, we were careful to strip the bronze slides
off the old sails and use them on the new sails. Bronze is a nice low
friction material and is used for bearings when ball bearings cannot carry the
load. Go to your local Ace hardware and look at the bronze bushings they
sell. While you are there, buy some Super Lube Dry lube.
friction as well.
Thanks in advance -
Dyer
SF Bay.
message.
