3 messages2013-08-16 19:33 UTCthrough 2013-08-19 02:06 UTC
Water cooling system
John Boyce2013-08-16 19:33 UTC
While I was working on my engine cooling system (Universal 5411 / M15) I
found a device in line that I think is a pressure relief valve. The device
is screwed into a tee in the cooling water line. My question is; Is this a
pressure relief valve? Is it on all diesels? Should it be routinely
replaced, if so with what?
This device is not shown on any diagrams that I have seen. I could be an
anti siphon device but again I have not seen anything like it.
John B
CAL 227 #650
Re: [Cal_Boats] Water cooling system (John)
Michael D2013-08-16 20:00 UTC
John,
If it's in the hose between the engine and exhaust elbow, I will guess that it is an anti-siphon valve.
Michael
Sent: Friday, August 16, 2013 3:33 PM
Subject: [Cal_Boats] Water cooling system
While I was working on my engine cooling system (Universal 5411 / M15) I found a device in line that I think is a pressure relief valve. The device is screwed into a tee in the cooling water line. My question is; Is this a pressure relief valve? Is it on all diesels? Should it be routinely replaced, if so with what?
This device is not shown on any diagrams that I have seen. I could be an anti siphon device but again I have not seen anything like it.
John B
CAL 227 #650
Brian McNamara2013-08-19 02:06 UTC
Is it the thermostat?
Is the T located to enable a bypass of the coolant system until the engine warms up?
If it is a thermostat, don't replace it, but keep a spare for when it eventually fails.
John B
CAL 227 #650
