Re: Stands for Cal 29 -- How many and what size?
2 messages2013-08-27 23:52 UTCthrough 2013-08-28 13:10 UTC
Brad Bates2013-08-27 23:52 UTC
Tue Aug 27, 2013 11:07 am (PDT) . Posted by:"Helen Horn" he… [at] sbcglobal.netbrad. ..you need 5 stands 4 med sailboat (Bronnell?) and one stright for the nose...under the keel you need 12 in of base rock maybe order on truck load of base rock and rent vibe-plate compactor and work the base rock into the soil keel is 5-6 ft long aprox 12" wide I think the stands should be 10 ft apart back to back and 6-8 ft apart side to side...You also need 20 feet of chain to tie the side stands together...good luck..... However I MUST CAUTION you that home projects sometimes take years longer than you think weather earth quakes ... any disaters can stop work as new wife old wife...job changes...health ...many things will keep you from compeleting your project(S)... If you haul in a busy DO IT YOURSELF (DIY) yard you tend to keep foscased and work harder...we hauled our Cal 29 "Noah's Kid" 1st time 5 weeks ...2nd time 2weeks yard charges $11 ft press wash in and out $25 lay days ...also if your boat needs this much work find a more worthy project...also if you doing inside work the time you need mesure or fit you must climb ladder ... after you pay for stands haul delivery maybe buy a boat that needs less work ..that you SAIL HOME edward "Caliente" Cal36 #60...good luck ...We bought or boat 400 miles away south... repowered eng.....from 800 miles north 88 hours motoring to Santa Cruz..then though the "gate" then to haul out "Berekely Marine center" 5-6 weeks have been racing last 21 weds beer cans (7 togo) if we trucked home she would STILL BE IN our YARD edward Thank you Edward. That is all good information to know. The boat was more or less a gift (paid less than $1300 for it), and I now live seven hours from the marina where it is docked. The restoration I plan to do will be a complete retro fit of the interior and repair of blemishes or issues on the hull, along with new paint. As for the time issue, I am nearly retired and the restoration will be my new job until it is complete, at which point we will begin cruising. My wife will be heavily involved too. Your point about the "up and down" ladders is very true, which is why I plan to build a very wide and sound scaffold around the boat after it is delivered that will include water-tight storage for all tools, shade, probably some fans, and fixed electrical service so that drop cords that become disconnected do not drop over the side, and so on. When the project is complete all of that scaffold can be used to build a new deck for our home on the farm, including space for a new hot tub! I may get really ambitious and put some weather-proof areas in so that neither winter cold or summer heat will get in the way of working -- but that remains to be seen. Again, thank you for the important information and your advice. I am pretty sure the group will read about the results when I finish. Best Regards, Brad Bates Play Mate Coffee Springs, Alabama (soon)
Brad Bates2013-08-28 13:10 UTC
Thank you again Edward. Brad Bates
