Cal-20 Sliding Hatch
7 messages2013-09-03 13:13 UTCthrough 2013-09-03 16:14 UTC
mi… [at] wahini.org2013-09-03 13:13 UTC
Hey folks! Does anyone know of someone with a Cal-20 sliding hatch? Mine blew off somewhere on the road between Pensacola and Nevada. If a hatch can't be found, dimensions for a new one I will have to make would be very much appreciated. Thanks.
Re: [Cal_Boats] Cal-20 Sliding Hatch
Chris Campbell2013-09-03 13:17 UTC
On 9/3/2013 9:13 AM, mi… [at] wahini.org wrote: > > > Hey folks! Does anyone know of someone with a Cal-20 sliding hatch? > Mine blew off somewhere on the road between Pensacola and Nevada. If a > hatch can't be found, dimensions for a new one I will have to make > would be very much appreciated. Thanks. > If nobody has a hatch for you, I can send some photos of mine. The dimensions can be calculated right off your boat, probably. And I suspect that the actual fit was done on the factory floor with a grinder or sanding disc. If you find a used hatch, you may have to do some adapting to make it fit properly. Chris Campbell > > >
RE: Cal-20 Sliding Hatch
mi… [at] wahini.org2013-09-03 14:00 UTC
Chris, I can see you wrote a reply on the message list. It even gives me a sample of what you wrote, but when I click on it, it just repeats what I wrote. I haven't logged into our group in a couple months and this is the first time its gone wonky in a long time. Could you repost? --- In ca… [at] yahoogroups.com, <ccampbell@...> wrote: On 9/3/2013 9:13 AM, mike@... wrote: Hey folks! Does anyone know of someone with a Cal-20 sliding hatch? Mine blew off somewhere on the road between Pensacola and Nevada. If a hatch can't be found, dimensions for a new one I will have to make would be very much appreciated. Thanks.
Re: [Cal_Boats] RE: Cal-20 Sliding Hatch
Chris Campbell2013-09-03 14:58 UTC
On 9/3/2013 10:00 AM, mi… [at] wahini.org wrote: > > > Chris, > I can see you wrote a reply on the message list. It even gives me a > sample of what you wrote, but when I click on it, it just repeats what > I wrote. I haven't logged into our group in a couple months and this > is the first time its gone wonky in a long time. Could you repost? OK, here's what I posted. > If nobody has a hatch for you, I can send some photos of mine. The > dimensions can be calculated right off your boat, probably. And I > suspect that the actual fit was done on the factory floor with a > grinder or sanding disc. If you find a used hatch, you may have to do > some adapting to make it fit properly. > > Chris Campbell Chris > > > --- In ca… [at] yahoogroups.com, <ccampbell@...> wrote: > > On 9/3/2013 9:13 AM, mike@... wrote: > > Hey folks! Does anyone know of someone with a Cal-20 sliding > hatch? Mine blew off somewhere on the road between Pensacola and > Nevada. If a hatch can't be found, dimensions for a new one I will > have to make would be very much appreciated. Thanks. > > > > >
Mike2013-09-03 15:14 UTC
That's what I figured, but was hoping that I could find one that would fit. I already have some divynicell sheets and fg cloth in case I need to reinvent the wheel. It shouldn't be too difficult but would rather spend the time sailing instead. Shoot, I can sail without it in nv as it doesn't rain much and, when it does, work on a new hatch in the shop. When I get time off to actually be home! Thanks for reposting. Cheers! Chris Campbell <cc… [at] lsnm.org> wrote: >On 9/3/2013 10:00 AM, mi… [at] wahini.org wrote: >> >> >> Chris, >> I can see you wrote a reply on the message list. It even gives me a >> sample of what you wrote, but when I click on it, it just repeats >what >> I wrote. I haven't logged into our group in a couple months and this >> is the first time its gone wonky in a long time. Could you repost? > >OK, here's what I posted. >> If nobody has a hatch for you, I can send some photos of mine. The >> dimensions can be calculated right off your boat, probably. And I >> suspect that the actual fit was done on the factory floor with a >> grinder or sanding disc. If you find a used hatch, you may have to >do >> some adapting to make it fit properly. >> >> Chris Campbell > >Chris > >> >> >> --- In ca… [at] yahoogroups.com, <ccampbell@...> wrote: >> >> On 9/3/2013 9:13 AM, mike@... wrote: >> >> Hey folks! Does anyone know of someone with a Cal-20 sliding >> hatch? Mine blew off somewhere on the road between Pensacola and >> Nevada. If a hatch can't be found, dimensions for a new one I >will >> have to make would be very much appreciated. Thanks. >> >> >> >> >> --
Gerald Sobel2013-09-03 15:41 UTC
I'd try contacting Jib Kelly's in San Pedro CA, maybe he knows a local junkyard with one, or he can help you with dimensions. He specializes in rebuilding Cal 20's Jerry From: Mike <mi… [at] wahini.org> To: Ca… [at] yahoogroups.com Sent: Tuesday, September 3, 2013 8:14 AM Subject: Re: [Cal_Boats] RE: Cal-20 Sliding Hatch That's what I figured, but was hoping that I could find one that would fit. I already have some divynicell sheets and fg cloth in case I need to reinvent the wheel. It shouldn't be too difficult but would rather spend the time sailing instead. Shoot, I can sail without it in nv as it doesn't rain much and, when it does, work on a new hatch in the shop. When I get time off to actually be home! Thanks for reposting. Cheers! Chris Campbell <cc… [at] lsnm.org> wrote: >On 9/3/2013 10:00 AM, mi… [at] wahini.org wrote: > >Chris, >>I can see you wrote a reply on the message list. It even gives me a sample of what you wrote, but when I click on it, it just repeats what I wrote. I haven't logged into our group in a couple months and this is the first time its gone wonky in a long time. Could you repost? >> >OK, here's what I posted. > >If nobody has a hatch for you, I can send some photos of mine. The dimensions can be calculated right off your boat, probably. And I suspect that the actual fit was done on the factory floor with a grinder or sanding disc. If you find a used hatch, you may have to do some adapting to make it fit properly. >> >>Chris Campbell >Chris > > > >> >> >>--- In ca… [at] yahoogroups.com, <ccampbell@...> wrote: >> >> >>On 9/3/2013 9:13 AM, mike@... wrote: >> >>Hey folks! Does anyone know of someone with a Cal-20 sliding hatch? Mine blew off somewhere on the road between Pensacola and Nevada. If a hatch can't be found, dimensions for a new one I will have to make would be very much appreciated. Thanks. >>> >> > --
Mike2013-09-03 16:14 UTC
Thanks, will do! Gerald Sobel <so… [at] yahoo.com> wrote: >I'd try contacting Jib Kelly's in San Pedro CA, maybe he knows a local >junkyard with one, or he can help you with dimensions. He specializes >in rebuilding Cal 20's >Jerry > > > > >________________________________ > From: Mike <mi… [at] wahini.org> >To: Ca… [at] yahoogroups.com >Sent: Tuesday, September 3, 2013 8:14 AM >Subject: Re: [Cal_Boats] RE: Cal-20 Sliding Hatch > > > > >That's what I figured, but was hoping that I could find one that would >fit. I already have some divynicell sheets and fg cloth in case I need >to reinvent the wheel. It shouldn't be too difficult but would rather >spend the time sailing instead. Shoot, I can sail without it in nv as >it doesn't rain much and, when it does, work on a new hatch in the >shop. When I get time off to actually be home! >Thanks for reposting. >Cheers! > > > >Chris Campbell <cc… [at] lsnm.org> wrote: > >>On 9/3/2013 10:00 AM, mi… [at] wahini.org wrote: >> >>Chris, >>>I can see you wrote a reply on the message list. It even gives me > a sample of what you wrote, but when I click on it, it just > repeats what I wrote. I haven't logged into our group in a couple > months and this is the first time its gone wonky in a long time. > Could you repost? >>> >>OK, here's what I posted. >> >>If nobody has a hatch for you, I can send some photos of mine. The >dimensions can be calculated right off your boat, probably. And I >suspect that the actual fit was done on the factory floor with a >grinder or sanding disc. If you find a used hatch, you may have to do >some adapting to make it fit properly. >>> >>>Chris Campbell >>Chris >> >> >> >>> >>> >>>--- In ca… [at] yahoogroups.com, <ccampbell@...> wrote: >>> >>> >>>On 9/3/2013 9:13 AM, mike@... wrote: >>> >>>Hey folks! Does anyone know of someone with a Cal-20 sliding hatch? >Mine blew off somewhere on the road between Pensacola and Nevada. If a >hatch can't be found, dimensions for a new one I will have to make >would be very much appreciated. Thanks. >>>> >>> >> >-- >Sent from my Android phone with K-9 Mail. Please excuse my brevity. --
