4 messages2013-09-27 20:16 UTCthrough 2013-09-28 02:14 UTC
Re: Americas Cup - Allen
Alfred Poor2013-09-27 20:16 UTC
Regarding gyroscopes et al: cell phones have driven the development of
extremely inexpensive, low-power, and tiny inertial navigation devices that
are very sensitive. The whole package is a chip with a footprint the size of
a pencil eraser or smaller. The electronics of such a system could probably
be driven by a small solar panel, or just about any other energy harvesting
device (no stored power required). The actuators that it controls would
probably be driven by the same hydraulics used to raise and lower the dagger
foils.
Alfred Poor
Re: [Cal_Boats] Re: Americas Cup - Allen
Allen Edwards2013-09-27 20:42 UTC
hydraulics cannot have any direct input from any sensors. Batteries are OK
for controlling the hydraulics. Below is the interesting part of the
rules. "batteries to power instruments" are legal. The SAS could be an
instrument. Instruments are not defined.
(i) hydraulic valves. These operations shall only provide the input for the
position of the valve;
(ii) drive clutches in winch systems.
The valves and drive clutches referred to in (i) and (ii) above, shall be
commercially
available and Competitors shall have had these approved by the Measurement
Committee for use via an issued interpretation.
The operation for (i) and (ii) above, shall not receive external input from
any source
other than manual input. Any data acquisition system, associated sensors or
electronics shall be physically separate and completely isolated from any
electrical
operation referred to in (i) and (ii) with the exception of the voltage
supply. The
manual input may latch the valve(s) or clutch(es), operate multiple valves
or
clutches, and /or provide variable position. Valves and clutches may be
operated
from multiple manual inputs.
> of a pencil eraser or smaller. The electronics of such a system could
> probably be driven by a small solar panel, or just about any other energy
> harvesting device (no stored power required). The actuators that it
> controls would probably be driven by the same hydraulics used to raise and
> lower the dagger foils.****
> Alfred Poor****
> 1973 Tartan 34C #288 “Jambalaya”****
Gerald Sobel2013-09-28 01:32 UTC
Mates, not to beat a dead horse, but wouldn't any kind of GPS or inertial device employ sensors? Only thing I can think of is you'd have to have someone monitoring a device, and following its indicators by operating controlling devices manually. The rule specifically states you can't have a valve controlled directly by anything with a sensor. And, come to think of it, a gyroscope is an energy storage device, but it might have no link to a boat other than spinning fast enuf or with enuff mass to impart stability, but, over 7 tons of bounding, plunging catamaran?
Nice mystery.
On Friday, September 27, 2013 1:43 PM, Allen Edwards <al… [at] gmail.com> wrote:
>hydraulics cannot have any direct input from any sensors. Batteries are OK for controlling the hydraulics. Below is the interesting part of the rules. "batteries to power instruments" are legal. The SAS could be an instrument. Instruments are not defined.
>Allen
>The valves and drive clutches referred to in (i) and (ii) above, shall be commercially
>The operation for (i) and (ii) above, shall not receive external input from any source
>electronics shall be physically separate and completely isolated from any electrical
>operation referred to in (i) and (ii) with the exception of the voltage supply. The
>manual input may latch the valve(s) or clutch(es), operate multiple valves or
>clutches, and /or provide variable position. Valves and clutches may be operated
>>Regarding gyroscopes et al: cell phones have driven the development of extremely inexpensive, low-power, and tiny inertial navigation devices that are very sensitive. The whole package is a chip with a footprint the size of a pencil eraser or smaller. The electronics of such a system could probably be driven by a small solar panel, or just about any other energy harvesting device (no stored power required). The actuators that it controls would probably be driven by the same hydraulics used to raise and lower the dagger foils.
>>Alfred Poor
Allen Edwards2013-09-28 02:14 UTC
my post from SA on the subject:
Spent some time reading the AC rules. They are very clear that no sensor
can control the hydraulics. In fact, the wiring needs to be separated so
that it is easy to see that sensors and controls are indeed separate. Crew
using sensors to tell them how to adjust things is common. On my boat, I
sail to a target speed. Head up if I am going to fast, fall off is too
slow. So they have a Herbie and know from its readout how to set the
foils. As long as they are not connected, legal. If it was automatic,
illegal but surely would have been caught given the separation of the
wiring requirement.
When I saw OTUSA driving the bow into the water on every tack my reaction
was they should take weight out of the bow and put weight in the stern.
They say they put more of the load on the rudder. Sounds like another way
of saying the same thing. Keep the bow from diving in and you will not
lose so much on each tack, which is what was happening.
In terms of the AC-45 rule infraction. Looking at the report and
particularly the pictures, it looks like there was a problem with the
strength of the end fittings and what they did was improve the design by
making the insert section longer. That likely made they heavier. They
should have proposed that as a change for the fleet. Stupid mistake.
Saying adding 5 pounds on the boat in the wrong place is cheating is
beyond reason. Saying it was a violation of the rules is fair. Taking
away their wing trimmer certainly would impact performance in the earlier
races. That should be considered when trying to explain the improvement.
> Nice mystery.
> Jerry
> Allen
> the
> commercially
> from any source
> or
> electrical
> supply. The
> or
> operated
> Alfred Poor****
