Internal Halyards
Internal Halyards
7 messages2013-10-01 02:16 UTCthrough 2013-10-04 22:07 UTC
Internal Halyards
david dobbs2013-10-01 02:16 UTC
I wanted to send a pix of my setup, but my IPhone and my Microsoft laptop are not talking to each other, so I will use words. On my boat, a ,CAL29, all lines are lead back to the cockpit; I have internal halyards, and at the base of the mast I have a swivel block for each line, which is then led to a deck organizer, then to the Garhauer clutches. The boat came to me that way, but I added one for the outhaul. It's less hassle than trying to figure out how to install a mast plate organizer. I bought the block from Sailcare, it's a Viadana, from Italy, and the quality is as good as Harken, and much less expensive. I'll work on the pix, later. David Dobbs CAL 29 411
Internal Halyards
david dobbs2013-10-03 23:54 UTC
----- Forwarded Message ----- From: david dobbs <d.… [at] comcast.net> To: david dobbs <tm… [at] yahoo.com> Sent: Thursday, October 3, 2013 6:48 PM Subject: IMG_0007.JPG Pix of my mast base setup, the halyards are led back to an organizer, then to clutches mounted on the cabin. The block on the right is original, the other is a Viadana that I added for my outhaul. I have them for the main and jib, spare jib,spinnaker, and pole lift. David Dobbs CAL 29 411
RE: [Cal_Boats] Internal Halyards
Craig Johnson2013-10-04 11:30 UTC
That is exactly what I need! Viadana? Where did you get it? Thanks, Craig Johnson To: Ca… [at] yahoogroups.com From: tm… [at] yahoo.com Date: Thu, 3 Oct 2013 16:54:59 -0700 Subject: [Cal_Boats] Internal Halyards ----- Forwarded Message ----- From: david dobbs <d.… [at] comcast.net> To: david dobbs <tm… [at] yahoo.com> Sent: Thursday, October 3, 2013 6:48 PM Subject: IMG_0007.JPG Pix of my mast base setup, the halyards are led back to an organizer, then to clutches mounted on the cabin. The block on the right is original, the other is a Viadana that I added for my outhaul. I have them for the main and jib, spare jib,spinnaker, and pole lift.David Dobbs CAL 29 411
Craig Johnson2013-10-04 11:48 UTC
Darn, Went through Viadana's web site and all I found was a "Pivoting block on base" for 1/4" wire. Something like this for halyards of 1/2" to 5/8" would solve sooo many problems for me. Though I have to say thanks for another reason as I was finally able to find the wire blocks I need to rebuild my back stay adjuster. I can't believe how difficult those have been to find! Thanks, Craig Johnson To: Ca… [at] yahoogroups.com From: tm… [at] yahoo.com Date: Thu, 3 Oct 2013 16:54:59 -0700 Subject: [Cal_Boats] Internal Halyards ----- Forwarded Message ----- From: david dobbs <d.… [at] comcast.net> To: david dobbs <tm… [at] yahoo.com> Sent: Thursday, October 3, 2013 6:48 PM Subject: IMG_0007.JPG Pix of my mast base setup, the halyards are led back to an organizer, then to clutches mounted on the cabin. The block on the right is original, the other is a Viadana that I added for my outhaul. I have them for the main and jib, spare jib,spinnaker, and pole lift.David Dobbs CAL 29 411
Craig Johnson2013-10-04 11:49 UTC
Do'h!!! And then I found it http://www.viadana.it/PDF%20CATALOGO/pagina%2032-33.pdf Thanks, Craig Johnson To: Ca… [at] yahoogroups.com From: tm… [at] yahoo.com Date: Thu, 3 Oct 2013 16:54:59 -0700 Subject: [Cal_Boats] Internal Halyards ----- Forwarded Message ----- From: david dobbs <d.… [at] comcast.net> To: david dobbs <tm… [at] yahoo.com> Sent: Thursday, October 3, 2013 6:48 PM Subject: IMG_0007.JPG Pix of my mast base setup, the halyards are led back to an organizer, then to clutches mounted on the cabin. The block on the right is original, the other is a Viadana that I added for my outhaul. I have them for the main and jib, spare jib,spinnaker, and pole lift.David Dobbs CAL 29 411
r good2013-10-04 13:17 UTC
http://garhauermarine.com/catalog_process.cfm?cid=70 To: ca… [at] yahoogroups.com From: cr… [at] hotmail.com Date: Fri, 4 Oct 2013 07:48:09 -0400 Subject: RE: [Cal_Boats] Internal Halyards Darn, Went through Viadana's web site and all I found was a "Pivoting block on base" for 1/4" wire. Something like this for halyards of 1/2" to 5/8" would solve sooo many problems for me. Though I have to say thanks for another reason as I was finally able to find the wire blocks I need to rebuild my back stay adjuster. I can't believe how difficult those have been to find! Thanks, Craig Johnson To: Ca… [at] yahoogroups.com From: tm… [at] yahoo.com Date: Thu, 3 Oct 2013 16:54:59 -0700 Subject: [Cal_Boats] Internal Halyards ----- Forwarded Message ----- From: david dobbs <d.… [at] comcast.net> To: david dobbs <tm… [at] yahoo.com> Sent: Thursday, October 3, 2013 6:48 PM Subject: IMG_0007.JPG Pix of my mast base setup, the halyards are led back to an organizer, then to clutches mounted on the cabin. The block on the right is original, the other is a Viadana that I added for my outhaul. I have them for the main and jib, spare jib,spinnaker, and pole lift.David Dobbs CAL 29 411
Re: [Cal_Boats] Internal Halyards
david dobbs2013-10-04 22:07 UTC
Craig, from Sailcare, don't remember the price, but first quality and cheaper than Harken. Sailcare.com DD From: Craig Johnson <cr… [at] hotmail.com> To: CalList <ca… [at] yahoogroups.com> Sent: Friday, October 4, 2013 6:30 AM Subject: RE: [Cal_Boats] Internal Halyards That is exactly what I need! Viadana? Where did you get it? Thanks, Craig Johnson To: Ca… [at] yahoogroups.com From: tm… [at] yahoo.com Date: Thu, 3 Oct 2013 16:54:59 -0700 Subject: [Cal_Boats] Internal Halyards ----- Forwarded Message ----- From: david dobbs <d.… [at] comcast.net> To: david dobbs <tm… [at] yahoo.com> Sent: Thursday, October 3, 2013 6:48 PM Subject: IMG_0007.JPG Pix of my mast base setup, the halyards are led back to an organizer, then to clutches mounted on the cabin. The block on the right is original, the other is a Viadana that I added for my outhaul. I have them for the main and jib, spare jib,spinnaker, and pole lift. David Dobbs CAL 29 411
