2 messages2013-10-09 03:18 UTCthrough 2013-10-09 15:24 UTC
Spin pole/Gin pole
Kevin Swart2013-10-09 03:18 UTC
When I put the new deck and beam in my Cal 25 I also installed a hinged mast base so I could step without assistance. Would my Spinnaker pole be adequate to use as a gin pole? Just need to build a bracket to attach to the mast/base. Otherwise I'll use a wooden beam that I can clamp on the mast.
Thanks for your help!
Kevin
Cal 25
Panache
Re: [Cal_Boats] Spin pole/Gin pole
Allen Edwards2013-10-09 15:24 UTC
Spin pole is stronger than a whisker pole and lots of people use them to
pole out a jib. A whisker pole will be longer. The whisker pole can be up
to some multiple of the foot, I think 1.5 times but not sure. For
example, my spin pole is 13.5 ft and the whisker pole is to 22 feet. We
usually pole out about 20 feet.
On Oct 8, 2013 8:18 PM, "Kevin Swart" <kg… [at] earthlink.net> wrote:
> **********When I put the new deck and beam in my Cal 25 I also installed
> on the mast.
> Kevin
> Cal 25
> *Panache*
