6 messages2013-10-11 01:06 UTCthrough 2013-10-11 16:23 UTC
RE: [Cal_Boats] Done - Tarps
Husar, Charlie [USA] (ASE)2013-10-11 01:06 UTC
Curiosity item. I've heard stories. Can a tarp or shrink wrap that holds moisture against the hull cause blistering on Imron or Awlgrip paint jobs?
Many Thanks
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of david dobbs
Sent: Thursday, October 10, 2013 8:55 PM
Subject: [External] [Cal_Boats] Done
Done it is. Delivered the CAL to the yard today, perfect weather, sunny, 70 and flat water. Left the harbor at 10:30 and docked at 3. Took an hour to lock through the O'brien Lock, a barge was going the other way and they get priority. They also take longer to lock through than small boats. We dodged 2 big ships, outbound and one small barge, but a nice trip, good way to end the season. As we left the yard guys were power washing the bottom. I may go down Saturday and take some stuff off, put some anti-freeze in the head and holding tank. I have some projects that may or may not get done, depends how fast it gets cold here. I think I will have them shrink-wrap it this year, I am tired of fighting with tarps.
David Dobbs, CAL 29 411
Re: RE: [Cal_Boats] Done - Tarps
Michael D2013-10-11 01:33 UTC
I don't think so. It takes water pressure.
Sent from Yahoo! Mail on Android
Husar, Charlie [USA] (ASE) <hu… [at] bah.com>;
To:
Ca… [at] yahoogroups.com <Ca… [at] yahoogroups.com>;
Subject:
Sent:
Fri, Oct 11, 2013 1:06:54 AM
Curiosity item. I’ve heard stories. Can a tarp or shrink wrap that holds moisture against the hull cause blistering on Imron or Awlgrip paint jobs?
Many Thanks
Re: [Cal_Boats] Done - Tarps
sailor7312 .2013-10-11 03:59 UTC
Charlie,
I think the answer is yes, Awlgrip and Imron can blistor if wet for very
long periods of time.
I have seen it in dinghies where a tarp fills w water and traps constant
moister between the tarp and seats or deck.
I have seen in on painted decks of big boats where water gets trapped and
sits.
I have also heard trailor bunks that are carpeted and hold moister for long
periods of time can cause blistering w paints.
That said, I painted my 505 deck, seat tanks and floor w awlcraft 2000
which is similar to Imron.
On a windy event, there are areas that are underwater all day and wet all
weekend.
I have never had a problem.
if I had a boat w a painted deck, I would probably do a boom tent. It
would protect it and let it breath.
Jim
cal 29 sailor
On Thu, Oct 10, 2013 at 9:06 PM, Husar, Charlie [USA] (ASE) <
> jobs?****
> Many Thanks****
> Charlie****
> Behalf Of *david dobbs
> *Sent:* Thursday, October 10, 2013 8:55 PM
> *Subject:* [External] [Cal_Boats] Done****
> David Dobbs, CAL 29 411****
David Owen2013-10-11 04:36 UTC
Actually, Awl Grip is susceptible to constant immersion, or water contact. I remember reading of a boat that had blisters on the port topsides from a long reach to Hawaii - that portion of boat constantly under water from heeling. My beautifully awl-gripped mast was trashed because I left it in the yard covered in bubble-wrap for too long. Water condensed inside the plastic and bubbled the paint. I had to sand and re-paint it.
Wilkie
> From: Husar, Charlie [USA] (ASE) <hu… [at] bah.com>;
> To: Ca… [at] yahoogroups.com <Ca… [at] yahoogroups.com>;
> Subject: RE: [Cal_Boats] Done - Tarps
> Sent: Fri, Oct 11, 2013 1:06:54 AM
> Many Thanks
> Charlie
Husar, Charlie [USA] (ASE)2013-10-11 04:46 UTC
Thanks, Folks for your responses. Wilkie, I think that story is what started me thinking. If I recall (harder all the time) it came from Captain dEmO (Timm Lessley) lo these many years ago.
Annapolis
The Land of CAL 25s (and the occasional CAL 40, but very few CAL 20s)
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of David Owen
Sent: Friday, October 11, 2013 12:37 AM
Subject: [External] Re: [Cal_Boats] Done - Tarps
Wilkie
On Oct 10, 2013, at 6:33 PM, Michael D <md… [at] yahoo.com<mailto:md… [at] yahoo.com>> wrote:
From: Husar, Charlie [USA] (ASE) <hu… [at] bah.com<mailto:hu… [at] bah.com>>;
To: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>>;
Many Thanks
From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com<http://yahoogroups.com>] On Behalf Of david dobbs
Chris Campbell2013-10-11 16:23 UTC
I've heard the polyurethane paints are susceptible to damage from
extended moisture contact. Many years ago (1983??) my other boat's hull
was professionally painted with Imron. It got a lot of little tiny
pimples where, I think, the winter plastic cover trapped moisture. The
boat lives indoors in the winter but there are sometimes condensation
issues in spring and fall when warm, moist air hits cold boats. I no
longer let the Visqueen cover lie against the topsides (although the
paint finish is well past the end of its useful life anyway). It's
possible that those arose from other causes. And on the other hand, we
painted the deck and cabin trunk ourselves with brush and roll two-part
polyurethane a LONG time ago, when they were first available as consumer
DIY products ((Interlux, I think). That was about 1975 or so and it has
been quite durable. The one place it has failed is a very small area at
deck scuppers where water may puddle if the drain is blocked. But
generally it has adhered tenaciously.
I wouldn't use two-part polyurethane on boottop stripes that are likely
to be wet all the time, but I've not had any extreme problem with
moisture-related failure.
> Cheers
> Charlie
> Annapolis
> *From:*Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]
> *On Behalf Of *David Owen
> *Sent:* Friday, October 11, 2013 12:37 AM
> *Subject:* [External] Re: [Cal_Boats] Done - Tarps
> Wilkie
> *From:*Husar, Charlie [USA] (ASE) <hu… [at] bah.com
> *To:*Ca… [at] yahoogroups.com
> <mailto:Ca… [at] yahoogroups.com><Ca… [at] yahoogroups.com
> *Subject:*RE: [Cal_Boats] Done - Tarps
> *Sent:*Fri, Oct 11, 2013 1:06:54 AM
> paint jobs?
> Many Thanks
> Charlie
> <mailto:Ca… [at] yahoogroups.com>[mailto:Ca… [at] yahoogroups.com
> <http://yahoogroups.com>]*On Behalf Of*david dobbs
> *Sent:*Thursday, October 10, 2013 8:55 PM
> *To:*Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
> *Subject:*[External] [Cal_Boats] Done
