Exhaust Leak
Exhaust Leak
5 messages2013-10-10 23:40 UTCthrough 2013-10-23 20:39 UTC
Exhaust Leak
bs… [at] yahoo.com2013-10-10 23:40 UTC
Hi all, I was out motoring along the other day and noticed a small exhaust leak. When we started the engine back up to come in it got a lot louder. I found a hole in the exhaust manifold about the size of a large BB. The engine is an A30 Farymann (1976). Does anyone know if there was a zinc or some type of plug that is supposed to go in there or can I just have it welded closed?
Re: [Cal_Boats] Exhaust Leak
Allen Edwards2013-10-11 04:25 UTC
A generic answer not specific to your engine. Tap the manifold lightly with a hammer. a) It breaks -- buy a new one b) it is solid -- drill out the hole, tap it, and screw in a plug. 1) above breaks the manifold -- go to a) 2) above doesn't break anything -- you are exceedingly lucky. Go have a scotch to celebrate. :-) On Thu, Oct 10, 2013 at 4:40 PM, <bs… [at] yahoo.com> wrote: > ** > > > Hi all, I was out motoring along the other day and noticed a small > exhaust leak. When we started the engine back up to come in it got a lot > louder. I found a hole in the exhaust manifold about the size of a large > BB. The engine is an A30 Farymann (1976). Does anyone know if there was a > zinc or some type of plug that is supposed to go in there or can I just > have it welded closed? > > >
Chuck Lennox2013-10-12 00:28 UTC
I would bet the exhaust manifold has rusted out. I had this problem on My R-30. If your going to try welding be sure to find a really good welder. The casting is poor and you will have to grind back to find something good to weld to. I tried to weld mine. The whole water jacket was paper thin. Good luck On Thursday, October 10, 2013 9:26 PM, Allen Edwards <al… [at] gmail.com> wrote: A generic answer not specific to your engine. Tap the manifold lightly with a hammer. a) It breaks -- buy a new one b) it is solid -- drill out the hole, tap it, and screw in a plug. 1) above breaks the manifold -- go to a) 2) above doesn't break anything -- you are exceedingly lucky. Go have a scotch to celebrate. :-) On Thu, Oct 10, 2013 at 4:40 PM, <bs… [at] yahoo.com> wrote: > >Hi all, I was out motoring along the other day and noticed a small exhaust leak. When we started the engine back up to come in it got a lot louder. I found a hole in the exhaust manifold about the size of a large BB. The engine is an A30 Farymann (1976). Does anyone know if there was a zinc or some type of plug that is supposed to go in there or can I just have it welded closed?
RE: Re: [Cal_Boats] Exhaust Leak
bs… [at] yahoo.com2013-10-22 17:09 UTC
Thanks for the advice everyone! I am going to remove the manifold this week and see what it looks like. Crossing my fingers it will be repaired with an easy fix ---In Ca… [at] yahoogroups.com, <ca… [at] yahoogroups.com> wrote: I would bet the exhaust manifold has rusted out. I had this problem on My R-30. If your going to try welding be sure to find a really good welder. The casting is poor and you will have to grind back to find something good to weld to. I tried to weld mine. The whole water jacket was paper thin. Good luck On Thursday, October 10, 2013 9:26 PM, Allen Edwards <allen.p.edwards@...> wrote: A generic answer not specific to your engine. Tap the manifold lightly with a hammer. a) It breaks -- buy a new one b) it is solid -- drill out the hole, tap it, and screw in a plug. 1) above breaks the manifold -- go to a) 2) above doesn't break anything -- you are exceedingly lucky. Go have a scotch to celebrate. :-) On Thu, Oct 10, 2013 at 4:40 PM, <bsauls925@... mailto:bsauls925@...> wrote: Hi all, I was out motoring along the other day and noticed a small exhaust leak. When we started the engine back up to come in it got a lot louder. I found a hole in the exhaust manifold about the size of a large BB. The engine is an A30 Farymann (1976). Does anyone know if there was a zinc or some type of plug that is supposed to go in there or can I just have it welded closed?
Re: Re: [Cal_Boats] Exhaust Leak
Leslie Newman2013-10-23 20:39 UTC
Use nickel rod. Expensive, but works best when welding cast iron. If welding a crack, grind a V down the crack, drill holes at each end and weld. You can pre-heat the metal or weld cold.If welding cold, weld very short bits of bead (1"), not letting things heat too much and peen the weld with a hammer after each bead to help stress relieve and prevent cracking. Or preheat the piece to like 600 degrees and weld away, then peen the weld. Then bury the piece in sand so that it cools very slowly, to hopefully prevent cracking. Just about every piece of my old Caterpillar crawlers are cast iron, so I've experimented with different cast weld methods over the years. On Tue, Oct 22, 2013 at 1:09 PM, <bs… [at] yahoo.com> wrote: > ** > > > Thanks for the advice everyone! I am going to remove the manifold this > week and see what it looks like. Crossing my fingers it will be repaired > with an easy fix > > > ---In Ca… [at] yahoogroups.com, <ca… [at] yahoogroups.com> wrote: > > I would bet the exhaust manifold has rusted out. I had this problem on My > R-30. If your going to try welding be sure to find a really good welder. > The casting is poor and you will have to grind back to find something good > to weld to. I tried to weld mine. The whole water jacket was paper thin. > Good luck > > > On Thursday, October 10, 2013 9:26 PM, Allen Edwards <allen.p.edwards@...> > wrote: > > A generic answer not specific to your engine. Tap the manifold lightly > with a hammer. > a) It breaks -- buy a new one > b) it is solid -- drill out the hole, tap it, and screw in a plug. > 1) above breaks the manifold -- go to a) > 2) above doesn't break anything -- you are exceedingly lucky. Go have > a scotch to celebrate. > > :-) > > > On Thu, Oct 10, 2013 at 4:40 PM, <bsauls925@...> wrote: > > ** > > Hi all, I was out motoring along the other day and noticed a small > exhaust leak. When we started the engine back up to come in it got a lot > louder. I found a hole in the exhaust manifold about the size of a large > BB. The engine is an A30 Farymann (1976). Does anyone know if there was a > zinc or some type of plug that is supposed to go in there or can I just > have it welded closed? > > > > > >
