6 messages2013-10-24 13:02 UTCthrough 2013-12-04 14:51 UTC
Re: Cal T/2 Spreaders
George Barlow2013-10-24 13:02 UTC
I recently refurbished my 1966 mast. The wooden spreaders had quite a bit of lichen on the top surfaces. I scraped and sanded them, then gave them a generous bath in neat epoxy. The wood took up the epoxy well. Put them back up for another 45 years I hope.
George Barlow
Cal 28 No. 155
Re: [Cal_Boats] Re: Cal T/2 Spreaders
John Raxter2013-10-24 14:20 UTC
Epoxy is not UV tolerant. Perhaps a good coat of varnish or since it will not be visible from below, one of the marine (petit) paints to protect the epoxy.
Just a thought.
John Raxter
> ___________________
> George Barlow
> Cal 28 No. 155
RE: [Cal_Boats] Re: Cal T/2 Spreaders
r good2013-10-24 15:06 UTC
Paint the top white to reflect heat. then paint on a caricature of a snake to reflect birds.
reggie
CC: Ca… [at] yahoogroups.com
Date: Thu, 24 Oct 2013 10:20:21 -0400
Subject: Re: [Cal_Boats] Re: Cal T/2 Spreaders
Just a thought.
John Raxter
___________________ George Barlow Cal 28 No. 155
sailor7312 .2013-10-24 15:21 UTC
I had these guys to spreaders for my cal 2-29 in aluminum.
I thought their prices were very good and the product was great.
http://www.newjsi.com/spars.aspx
I sent them a dimensioned drawing of my spreaders and then back that up
with pictures showing the spreader with a tape measure next to it.
A great feeling not having to maintain the wood.
Jim
Cal 29 sailor
Helen Horn2013-10-25 06:39 UTC
that's what I did on my cal 29,,,did penetrating epoxy several coats on all sides, the when last coat was tacky, I painted with white EZpoxy, two layers. then I painted a green snake with an open mouth and white teeth. New owner also says he's the only boat on his dock not splattered with bird dirt. (in Santa Cruz now). It's been this way for over 4 years and they still sparkle. Helen (the boatyard laughed when I did it, but my boom sailcover is still unspotted).
To: "Ca… [at] yahoogroups.com" <ca… [at] yahoogroups.com>
Sent: Thursday, October 24, 2013 8:06 AM
Subject: RE: [Cal_Boats] Re: Cal T/2 Spreaders
reggie
Just a thought.
John Raxter
>___________________
> George Barlow
> Cal 28 No. 155
Chris Campbell2013-12-04 14:51 UTC
> protect the epoxy.
This is a very late reply, but what the heck. My other boat has
varnished wooden spreaders. Keeping varnish on the top surface was an
annual chore. Taking a cue from this list, I painted the upper surface,
which is indeed invisible unless you're higher than the spreaders. The
white surface has been maintenance-free ever since. I think I repainted
once.
Unprotected epoxy is a disaster. It will yellow and peel, except where
it chooses not to, and then it's a struggle getting that part off in the
future. My Cal 20 came with an epoxied companionway dropboard. It was
peeling and awful. Getting the @#$%&**!!! stuff off was tough. I
finally got it off, stained, and then varnished (without epoxy under it).
My sea kayak has a deck that's epoxied and then varnished for UV
protection. First I used regular epoxy and it began to fail. I removed
that with the most poisonous paint remover I could find and lots of
swearing. Then I used Gougeon's special coating hardener and multiple
coats of UV filter spar varnish. It has survived for another 14 years
or so, but it lives indoors when not in the water.
