Sailing / boating terms
pw… [at] aol.com2014-03-25 14:30 UTC
Here are the 'real' definitions based on experience for those new to
sailing.
Paul
~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ ~ (\_~ ~ (\_~ ~ (\_~ ~ ~ ~ ~ ~ ~ ~ ~ ~
EXPLANATION OF SOME COMMON SAILING TERMS
* Amidships - condition of being surrounded by boats.
* Anchor - a device designed to bring up mud samples from the bottom
at inopportune or unexpected times.
* Anchor Light - a small light used to discharge the battery before
daylight.
* Back Stay - Spending time at home. When your partner goes sailing
in October.
* Bare Boat - Clothing Optional.
* Beam Sea - A situation in which waves strike a boat from the
side, causing it to roll unpleasantly. This is one of the four directions from
which wave action tends to produce extreme physical discomfort. The other
three are `bow sea' (waves striking from the front), `following sea' (waves
striking from the rear), and `quarter sea' (waves striking from any other
direction).
* Berth - a little addition to the crew.
* Bilge - cheap beer (see freeboard)
* Boat ownership - Standing fully -clothed under a cold shower,
tearing up 100 -dollar bills
* Boom - sometimes the result of a surprise jibe.
* Boom - Called boom for the sound that's made when it hits crew in
the head on its way across the boat. For slow crew, it's called `boom,
boom.'
* Bottom Paint - what you get when the cockpit seats are freshly
painted.
* Calm - Sea condition characterized by the simultaneous
disappearance of the wind and the last cold beverage.
* Chart - a type of map which tells you exactly where you are
aground.
* Clew - an indication from the skipper as to what he might do next.
* Companionway - a double berth.
* Course - The direction in which a skipper wishes to steer his boat
and from which the wind is blowing. Also, the language that results by not
being able to.
* Cruising - Fixing your boat in exotic locations.
* Crew - Heavy, stationary objects used on shipboard to hold down
charts, anchor cushions in place and dampen sudden movements of the boom.
* Current - Tidal flow that carries a boat away from its desired
destination, or towards a hazard
* Dead Reckoning - a course leading directly to a reef.
* Deadrise - getting up to check the anchor at 0300.
* Deck Fluff - a scantily clad North American Big Hair, commonly
placed on the foredeck of a sailing yacht with the sole purpose to distract
the competition while rounding the mark inside their position.
* Deviation - any departure from the Captain's orders.
* Dinghy - the sound of the ship's bell.
* Displacement - when you dock your boat and can't find it later.
* Draft - The gap in your oilies between the trousers and the
jacket.
* Estimated Position - a place you have marked on the chart where
you are sure you are not.
* First Mate - crew member necessary for skippers to practice
shouting instructions to.
* Fix - the crew's estimate of your current position.
* Emergency Flares - old pair of trousers to change into if you
fall overboard.
* Flashlight - Tubular metal container used on shipboard for storing
dead batteries prior to their disposal
* Fluke - The portion of an anchor that digs securely into the
bottom, holding the boat in place; also, any occasion when this occurs on the
first try.
* Foul Wind - breeze produced by flying turkey.
* Freeboard - food and liquor supplied by the owner.
* Gybe - A common way to get unruly guests off your boat.
* Headway - what you are making if you can't get the toilet to work.
* Head up - Leaving the boat toilet seat up. When boat skipper is
female, leaving the head up is a serious offense
* Heads - the deciding factor whether to set out or not.
* Heave -Ho - what you do when you've eaten too much Ho.
* Jack Lines - `Hey baby, want to go sailing?'
* Jibe - either you like it or you don't and it gets you.
* Keel - term used by 1st mate after too much heel by skipper.
* Ketch - A sailboat with good wine in the cabin
* Landlubber - anyone on board who wishes he were not.
* Latitude - the number of degrees off course allowed a guest.
* Log - Semi submerged object responsible for suddenly rousing the
skipper on a night passage.
* Mast - religious ritual used before setting sail.
* Mate - the term used to refer to the skipper just before
explaining that the hand bearing compass has fallen overboard
* Mizzen - an object you can't find.
* Motor Sailer - A sailboat that alternates between sail/rigging
problems and engine problems, and with some booze in the cabin.
* Noserly - What to call the wind direction when it comes from where
you're going
* Ram - an intricate docking maneuver sometimes used by experienced
skippers.
* Rhumb Line - two or more crew members waiting for a drink.
* Sailing - The fine art of getting wet and becoming ill, while
going no where slowly at great expense.
* Schooner - A sailboat with a fully stocked liquor cabinet in the
cabin
* Sea Cock - (see Jack Lines)
* Sheet - cool, damp, salty night covering.
* Shroud - equipment used in connection with a wake.
* Small Craft Warnings - Power Boats come in, Sailboats go out.
* Spreaders - Barclay Card and Visa - useful for extending the
sailing season.
* Starboard - special board used by skippers for navigation (usually
with "Port" on the opposite side.)
* Stays - position in harbour when gales are forecast.
* Stowaway - rapid handling of alcoholic spirits as the customs boat
approaches.
* Swell - a wave that's just great.
* Square Rigger - a rigger over 30.
* Sloop - A sailboat with beer and/or wine in the cabin.
* Tack - A maneuver the skipper uses when telling the crew what they
did wrong without getting them mad.
* Tree - object to sit under, as a cure for seasickness.
* Wind Indicator - Sensitive person who suddenly throws open the
vents and hatches.
* Warp - The other skipper's version of events.
* Yawl - A sailboat from Texas, with some good bourbon stored down
yonder in the cabin
* Zephyr - Warm, pleasant breeze. Named after the mythical Greek god
of wishful thinking, false hopes, and unreliable forecasts. - -
Re: [Cal_Boats] Sailing / boating terms
Kris Jensen2014-03-25 18:48 UTC
I'm always careful to give new sailors the pep-talk:
"Front, bow. Back, stern. If ya don't get it right, squirt, I throw your ass out the little round window on the side." - Capt. Quint.
Sent: Tuesday, March 25, 2014 7:30 AM
Subject: [Cal_Boats] Sailing / boating terms
to sailing.
Paul
>>> * Anchor - a device designed to bring up mud samples from the bottom at inopportune or unexpected times.
>>> * Anchor Light - a small light used to discharge the battery before daylight.
>>> * Back Stay - Spending time at home. When your partner goes sailing in October.
>>> * Beam Sea - A situation in which waves strike a boat from the side, causing it to roll unpleasantly. This is one of the four directions from which wave action tends to produce extreme physical discomfort. The other three are `bow sea' (waves striking from the front), `following sea' (waves striking from the rear), and `quarter sea' (waves striking from any other direction).
>>> * Boat ownership - Standing fully -clothed under a cold shower, tearing up 100 -dollar bills
>>> * Boom - Called boom for the sound that's made when it hits crew in the head on its way across the boat. For slow crew, it's called `boom, boom.'
>>> * Bottom Paint - what you get when the cockpit seats are freshly painted.
>>> * Calm - Sea condition characterized by the simultaneous disappearance of the wind and the last cold beverage.
>>> * Chart - a type of map which tells you exactly where you are aground.
>>> * Course - The direction in which a skipper wishes to steer his boat and from which the wind is blowing. Also, the language that results by not being able to.
>>> * Crew - Heavy, stationary objects used on shipboard to hold down charts, anchor cushions in place and dampen sudden movements of the boom.
>>> * Current - Tidal flow that carries a boat away from its desired destination, or towards a hazard
>>> * Deck Fluff - a scantily clad North American Big Hair, commonly placed on the foredeck of a sailing yacht with the sole purpose to distract the competition while rounding the mark inside their position.
>>> * Draft - The gap in your oilies between the trousers and the jacket.
>>> * Estimated Position - a place you have marked on the chart where you are sure you are not.
>>> * First Mate - crew member necessary for skippers to practice shouting instructions to.
>>> * Emergency Flares - old pair of trousers to change into if you fall overboard.
>>> * Flashlight - Tubular metal container used on shipboard for storing dead batteries prior to their disposal
>>> * Fluke - The portion of an anchor that digs securely into the bottom, holding the boat in place; also, any occasion when this occurs on the first try.
>>> * Head up - Leaving the boat toilet seat up. When boat skipper is female, leaving the head up is a serious offense
>>> * Log - Semi submerged object responsible for suddenly rousing the skipper on a night passage.
>>> * Mate - the term used to refer to the skipper just before explaining that the hand bearing compass has fallen overboard
>>> * Motor Sailer - A sailboat that alternates between sail/rigging problems and engine problems, and with some booze in the cabin.
>>> * Noserly - What to call the wind direction when it comes from where you're going
>>> * Ram - an intricate docking maneuver sometimes used by experienced skippers.
>>> * Sailing - The fine art of getting wet and becoming ill, while going no where slowly at great expense.
>>> * Schooner - A sailboat with a fully stocked liquor cabinet in the cabin
>>> * Spreaders - Barclay Card and Visa - useful for extending the sailing season.
>>> * Starboard - special board used by skippers for navigation (usually with "Port" on the opposite side.)
>>> * Stowaway - rapid handling of alcoholic spirits as the customs boat approaches.
>>> * Tack - A maneuver the skipper uses when telling the crew what they did wrong without getting them mad.
>>> * Wind Indicator - Sensitive person who suddenly throws open the vents and hatches.
>>> * Yawl - A sailboat from Texas, with some good bourbon stored down yonder in the cabin
>>> * Zephyr - Warm, pleasant breeze. Named after the mythical Greek god of wishful thinking, false hopes, and unreliable forecasts. - -
