12 messages2014-03-24 22:43 UTCthrough 2014-03-25 21:58 UTC
Re: [Cal_Boats] Re: Headliner
Rodney G. Johnson2014-03-24 22:43 UTC
What are the "dorados"? I've never heard of that term before.
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II
former co-owner of "NODROG"
1970 CAL 21
On 24 Mar 2014 09:37:56 -0700 <ge… [at] msn.com> writes:
I replaced the forward panel of the Headliner on my 1987 Cal 33-2. It was
much easier than I thought it would be. I had read that the dorados on
Cals were never well glassed and I found this to be true on my boat. I
therefore glassed both port and starboard dorados before cutting a new
Masonite panel. I used the old warped and degraded panel as a pattern. If
you do not have this I suggest a 4x8 sheet of corrugated cardboard
to create a pattern.
The panels are held in place by the hand holds both sides and the 1 1/2
ish strips that cross the cabin top which screw into wooden blocks that
have been glued to the underside of the overhead.
Good luck on a project that I had put off for a long time and found to be
rather easy and very satisfying once I got the nerve to start on it.
Jim O'C
Do THIS before eating carbs (every time)
1 EASY tip to increase fat-burning, lower blood sugar & decrease fat storage
http://thirdpartyoffers.juno.com/TGL3141/5330b596ef04c3596297dst03duc
Dan2014-03-24 22:50 UTC
Ventilation scoops.
Sent: Monday, March 24, 2014 6:43 PM
Subject: Re: [Cal_Boats] Re: Headliner
1979 O'DAY DS II
1970 CAL 21
I replaced the forward panel of the Headliner on my 1987 Cal 33-2. It was much easier than I thought it would be. I had read that the dorados on Cals were never well glassed and I found this to be true on my boat. I therefore glassed both port and starboard dorados before cutting a new Masonite panel. I used the old warped and degraded panel as a pattern. If you do not have this I suggest a 4x8 sheet of corrugated cardboard
The panels are held in place by the hand holds both sides and the 1 1/2 ish strips that cross the cabin top which screw into wooden blocks that have been glued to the underside of the overhead.
Good luck on a project that I had put off for a long time and found to be rather easy and very satisfying once I got the nerve to start on it.
Jim O'C
info.fixyourbloodsugar.com
Greg Beron2014-03-24 23:04 UTC
Dorado vents or, properly, Dorado Boxes sit underneath those tuba-looking cowl vents. The boxes prevent water from going into the boat through the vents. The name is often used incorrectly for the cowl vents themselves.
Greg
Cal 29 "Happy Hour"
>1979 O'DAY DS II
>1970 CAL 21
>Jim O'C
>____________________________________________________________
Rodney G. Johnson2014-03-24 23:28 UTC
Those are "DORADE" vents, so-called because they were (allegedly?) first
used on the famous S&S yawl, "DORADE"
I kind-of thought that was what you meant, but wasn't sure. A "dorado" is
a fish, also known as a dolphin, but no relation to the marine mammal by
that name.
for anyone unfamiliar with Dorade-style vents (or Dorade boxes as they
are also known), they are usually a cowl vent mounted atop a box on the
cabin top, the box allows the vent to be off-set from the hole or tube
that goes through the cabin top (or deck) so any water that gets in the
vent will drain out of holes along the side of the dorade box instead of
"pouring" below. Many newer boats actually have these integrated into the
deck instead of mounted on top of the deck. Pretty neat!
1979 O'DAY DS II
1970 CAL 21
On Mon, 24 Mar 2014 16:04:28 -0700 Greg Beron <gb… [at] yahoo.com> writes:
Greg
Cal 29 "Happy Hour"
1979 O'DAY DS II
1970 CAL 21
Jim O'C
1 EASY tip to increase fat-burning, lower blood sugar decrease fat
storage
LifeLock® Services
24/7 Credit Fraud Monitoring Plan. Proactive Credit Fraud Protection.
http://thirdpartyoffers.juno.com/TGL3141/5330bfd8e86083fd867fbst01duc
mi… [at] yahoo.com2014-03-25 00:07 UTC
"Dorade" rather than "Dorado," named after the 1936 and 2013 Transpac winner http://dorade.org/ http://dorade.org/
https://en.wikipedia.org/wiki/Dorade_(yacht) https://en.wikipedia.org/wiki/Dorade_(yacht)
Chris Campbell2014-03-25 13:38 UTC
> winner
> http://dorade.org/
> <https://en.wikipedia.org/wiki/Dorade_%28yacht%29>
Here's my vote for helping each other use accurate terms. Sailing is
perhaps unique in the number and oddness of its terminology, largely
because it has such an extended history. On our local historical
schooner, we have a fife rail, and when i was using the rigging model
the other evening, I explained where the term comes from. It helps us
to have some sense of our history. So also with Dorade, the most famous
vessel of her day (the Cal 40 of her day, to be more specific).
I get grumpy when I hear people speak of "incidences" when they mean
incidents, and of "contingency" fees in my field of work when they mean
"contingent" fees.
RE: [Cal_Boats] Re: Headliner
Harleigh Ewell2014-03-25 14:19 UTC
Agreed. Here are a few of my favorite mistakes:
Coarse for course
Gail for gale
Healed for heeled
Loose for lose
Stantion for stanchion
Teather for tether
Harleigh
Sent: Tuesday, March 25, 2014 9:39 AM
http://dorade.org/
https://en.wikipedia.org/wiki/Dorade_(yacht) <https://en.wikipedia.org/wiki/Dorade_%28yacht%29>
Here's my vote for helping each other use accurate terms. Sailing is perhaps unique in the number and oddness of its terminology, largely because it has such an extended history. On our local historical schooner, we have a fife rail, and when i was using the rigging model the other evening, I explained where the term comes from. It helps us to have some sense of our history. So also with Dorade, the most famous vessel of her day (the Cal 40 of her day, to be more specific).
I get grumpy when I hear people speak of "incidences" when they mean incidents, and of "contingency" fees in my field of work when they mean "contingent" fees.
Carl2014-03-25 14:27 UTC
And, don't forget the infamous "cutlass" bearing for cutLESS!
> Coarse for course
> Gail for gale
> Healed for heeled
> Loose for lose
> Teather for tether
> Harleigh
sailing terminology and pet peeves [ was Re: Headliner
Joe DeMers2014-03-25 14:28 UTC
Here's my pet peeve -
Calling the stern of the boat the "back".
Joe D
> Coarse for course
> Gail for gale
> Healed for heeled
> Loose for lose
> Teather for tether
> Harleigh
> *From:*Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]
> *On Behalf Of *Chris Campbell
> *Sent:* Tuesday, March 25, 2014 9:39 AM
> *Subject:* Re: [Cal_Boats] Re: Headliner
> Transpac winner
> http://dorade.org/
> Chris Campbell
*Joe DeMers - owner*
Sound Marine Diesel LLC
(860) 666-2184*
Rodney G. Johnson2014-03-25 20:22 UTC
And don't forget.... "tiller handle" when they mean TILLER. Can't get
over how many times I've heard or read that one.
Also: Swing-keel when htey mean Centerboard
Full-keel when they mean Deep-fin keel
Ceiling, when htey mean Overhead (ceiling on a boat is
the covering for the inside of the hull, often cedar strips on a wooden
boat)
And the funniest one, (maybe caused by spell-check?)
Wench, when they mean
Winch (well ,at least I think they mean winch?)
1979 O'DAY DS II
former co-owner (with Dad) of "NODROG"
1970 CAL 21
On Tue, 25 Mar 2014 10:19:10 -0400 "Harleigh Ewell" <hp… [at] hpewell.com>
writes:
Coarse for course
Gail for gale
Healed for heeled
Loose for lose
Teather for tether
Harleigh
winner
http://dorade.org/
"contingent" fees.
Fast-Growing Industry
A New Player In The Booming Bottled Water Market.
http://thirdpartyoffers.juno.com/TGL3141/5331e5c2a199a65c24b96st04duc
drizzlelimu2014-03-25 20:38 UTC
Or "top sides" when they mean on deck.
<div>-------- Original message --------</div><div>From: "Rodney G. Johnson" <rj… [at] juno.com> </div><div>Date:03/25/2014 13:22 (GMT-08:00) </div><div>To: Ca… [at] yahoogroups.com </div><div>Subject: Re: [Cal_Boats] Re: Headliner </div><div>
</div>
And don't forget.... "tiller handle" when they mean TILLER. Can't get over how many times I've heard or read that one.
Ceiling, when htey mean Overhead (ceiling on a boat is the covering for the inside of the hull, often cedar strips on a wooden boat)
Wench, when they mean Winch (well ,at least I think they mean winch?)
1979 O'DAY DS II
1970 CAL 21
On Tue, 25 Mar 2014 10:19:10 -0400 "Harleigh Ewell" <hp… [at] hpewell.com> writes:
Coarse for course
Gail for gale
Healed for heeled
Loose for lose
Teather for tether
Harleigh
http://dorade.org/
AlkameWater.com
Re: Yawl talkin funny
Tom Vandiver2014-03-25 21:58 UTC
I am very happy that some of yawl who live north of Interstate 10 and survived global warming this winter still have your sense of humor. Now we can all get to work on our boats and go play.
Here is some proper "Southernese".
Bayou is not pronounced by-you, it is bay-o.
Tom in Baja Alabama, AKA NW FL
Sent: Tuesday, March 25, 2014 3:38 PM
keel
by spell-check?)
1979 O'DAY DS II
1970 CAL 21
>Coarse for course
>Gail for gale
>Healed for heeled
>Loose for lose
>Teather for tether
>Harleigh
>From:Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Chris Campbell
>>http://dorade.org/
specific).
>Chris Campbell
AlkameWater.com
