9 messages2014-05-02 01:29 UTCthrough 2014-05-03 02:18 UTC
wind vane
Kool Beans2014-05-02 01:29 UTC
Greets everyone,,,
Thank you all for the great advice for cleaning my engine compartment. I will be installing a wind vane at the top of the mast and need to know the angle to set the vanes to. The vane comes with a template to adjust the tabs, and can be spread out to 65 degrees max. Does anyone know what the tacking arm angle should be to match the performance of my Cal 2-29? Is there a difference for racing and cruising? What would be a good median?
Thanks again for any advice!
Happy Sailing
Jim Ives - Kool Beans
Rochester, NY
RE: [External] [Cal_Boats] wind vane
Husar, Charlie [USA] (ASE)2014-05-02 01:40 UTC
Jim, I suggest you not use them. I never do. I just want to know where the apparent wind is coming from (the arrow). Your closed hauled angle will change a lot based on wind speed and water slop. Better to watch the sail rather than the feathers. I do look at the arrow angle frequently.
My Two Cents
Annapolis
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com] On Behalf Of Kool Beans
Sent: Thursday, May 01, 2014 9:29 PM
To: ca… [at] yahoogroups.com
Subject: [External] [Cal_Boats] wind vane
Greets everyone,,,
Happy Sailing
Rochester, NY
Re: [External] [Cal_Boats] wind vane
Allen Edwards2014-05-02 02:52 UTC
Set them to +- 30 degrees. Yes, it is better to watch the sails but every
now and then things are not right and you can look up there and say, oh
shit, I got way off the wind. I need to head up. The idea is that you
probably want to sail at 45 degrees true and the wind speed and your boat
speed moves that forward. Thus my suggestion of 30 degrees apparent. But
is not something you can sail to. I also use mine to translate from
apparent wind speed to true wind speed. I think they are useful although
as was said you can't sail to them.
On Thu, May 1, 2014 at 6:40 PM, Husar, Charlie [USA] (ASE) <
> My Two Cents
> Charlie
> Annapolis
> Behalf Of *Kool Beans
> *Sent:* Thursday, May 01, 2014 9:29 PM
> *Subject:* [External] [Cal_Boats] wind vane
> Greets everyone,,,
> Happy Sailing
> Rochester, NY
pw… [at] aol.com2014-05-02 04:37 UTC
I have to respectfully agree/disagree with Charlie. I would put them up there but not depend on them for how you are sailing but merely as a quicker reference as to how well you are or are not pointing. It will take some experience but you'll know at a glance whether or not you're pointing as you should. It also helps if you turn over the tiller to someone for a bit. You can say "you should be able to keep the tail an inch inside the vane instead "keep the arrow at 10:30ish and we'll be fine". Also helps a great deal when sailing downwind, especially dead down, as the arrow will slip over a second or two before an accidental gybe. Just enough time to correct and/or yell DUCK!!
My 2 cents.
Paul
From: Husar, Charlie [USA] (ASE) [USA] (ASE) <hu… [at] bah.com>
Sent: Thu, May 1, 2014 9:40 pm
Subject: RE: [External] [Cal_Boats] wind vane
My Two Cents
Annapolis
From: Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]On Behalf Of Kool Beans
Greets everyone,,,
Happy Sailing
Rochester, NY
Allen Edwards2014-05-02 05:14 UTC
There are some tools on L-36.com that can help you get familiar with what
the windex might look like for differrent winds when you are sailing at 45
degrees to the wind. At light winds, you will likely not sail at 45
degrees so the windex is going to be closer to overlapped than what this
shows but it is close. This set is for a boat with a 24 ft wlw like your
boat. This is for a 30 degree angle (60 degrees total) on the windex. You
can adjust the settings on the page to whatever you want to try.
http://L-36.com/polar_targets.php?flag=30&flagw=10&tail=15&lwl=24&perf_factor=1.35&ref=45&polar_tws=4.7&polar_bs=3.4&polar2_tws=15&polar2_bs=6.3&tws_start=4&tws_end=20&tws_step=2&mode=target<http://l-36.com/polar_targets.php?flag=30&flagw=10&tail=15&lwl=24&perf_factor=1.35&ref=45&polar_tws=4.7&polar_bs=3.4&polar2_tws=15&polar2_bs=6.3&tws_start=4&tws_end=20&tws_step=2&mode=target>
As far as a guide to tell you if you are heading in the optimum direction,
use boat speed, not the windex. If you are going to fast, head up. Too
slow, fall off. The boat speeds on this table will be close to what you
want for your boat. Sailing to an optimum boat speed is an order of
magnitude more accurate than trying to sail to a wind angle. But it is
still useful particularly when you have something set really wrong as
happens to all of us, except Charlie.
> My 2 cents.
> Paul
> -----Original Message-----
> frequently.
> My Two Cents
> Charlie
> Annapolis
> *From:* Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com<Ca… [at] yahoogroups.com?>]
> *On Behalf Of *Kool Beans
> Greets everyone,,,
> Happy Sailing
> Rochester, NY
Chris Campbell2014-05-02 18:38 UTC
> frequently.
I'll file a minor dissent. Having the angle indicators up there gives
you a point of reference--"gee, normally I can be closer hauled than
this, what's wrong?" In some cases, as Charlie notes, it's because of
wind and wave conditions, or maybe because of the sail complement at the
moment, but sometimes we are just doing something wrong, or not paying
attention, and having a visual reminder may be helpful. Maybe I need to
flatten that main some....
I don't set mine for any special angle. I just kind of eyeball them for
equal angle on each side, then as I sail I get used to where the wind
indicator ought to be. Maybe the vane is inside the marks, maybe it's
outside, doesn't matter as long as I know what the boat usually does
when well sailed.
My constant visual indicators are the tell-tales on the sails. Those are
what really tell me what the sail is doing, and I tend to stare at them
all the time when I'm at the helm. But then I'll glance up at the
masthead fly to make sure it's where it ought to be.
> My Two Cents
> Charlie
> Annapolis
> *From:*Ca… [at] yahoogroups.com [mailto:Ca… [at] yahoogroups.com]
> Greets everyone,,,
> be a good median?
> Happy Sailing
> Rochester, NY
Elwers, George A.2014-05-02 20:07 UTC
I also use mine as a reference when tacking or gybing. When I'm steering through the maneuver and I think I'm close to the new course I'll look up and set the new angle based on the windex and the tabs. This is much more accurate than guessing, for me, and gets me on the new course before the sails are trimmed in. I look just before the tack to see the relative positions of the indicator and the tab, then set the new course slightly lower to allow the boat to accelerate as the jib is trimmed in.
George
From: Ca… [at] yahoogroups.com [Ca… [at] yahoogroups.com] on behalf of Chris Campbell [cc… [at] lsnm.org]
Sent: Friday, May 02, 2014 11:38 AM
Subject: Re: [External] [Cal_Boats] wind vane
I'll file a minor dissent. Having the angle indicators up there gives you a point of reference--"gee, normally I can be closer hauled than this, what's wrong?" In some cases, as Charlie notes, it's because of wind and wave conditions, or maybe because of the sail complement at the moment, but sometimes we are just doing something wrong, or not paying attention, and having a visual reminder may be helpful. Maybe I need to flatten that main some....
I don't set mine for any special angle. I just kind of eyeball them for equal angle on each side, then as I sail I get used to where the wind indicator ought to be. Maybe the vane is inside the marks, maybe it's outside, doesn't matter as long as I know what the boat usually does when well sailed.
My constant visual indicators are the tell-tales on the sails. Those are what really tell me what the sail is doing, and I tend to stare at them all the time when I'm at the helm. But then I'll glance up at the masthead fly to make sure it's where it ought to be.
My Two Cents
Annapolis
From: Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com> [mailto:Ca… [at] yahoogroups.com] On Behalf Of Kool Beans
To: ca… [at] yahoogroups.com<mailto:ca… [at] yahoogroups.com>
Greets everyone,,,
Happy Sailing
Rochester, NY
Mark Alan Stahnke (MAS Consulting)2014-05-02 21:54 UTC
I have the wind indicator but not for tacking. I would never think about taking my glance off the mainsail luff during a tack, and the second the luff of the sail fills in, I call course. ...
Just a few grains from an old salt.
Mark
Mark A. Stahnke
MAS Consulting
(310) 832-5992
My Two Cents
Annapolis
Greets everyone,,,
Happy Sailing
Rochester, NY
Kool Beans2014-05-03 02:18 UTC
Greets everyone,,
Thank you everyone for your valuable advice
about the wind vane and my engine compartment questions. I have enough
input to successfully succeed in my projects that are in progress.
As
for the engine compartment, I will heed the advice about the fumes,
good idea to wear a mask in tight quarters. Lots of great ideas on what
to use as well.
I'm sure that I'll put the advice to good use for the
vanes. I have bright colored yarn (yellow) on the forward and middle
shroud on both the port and starboard side. That might be old fashioned,
but was taught that when I was a youngster learning on a Comet. I
checked out the article on the L-36.com site and read with interest,
very good by the way. All your advice on how to set it up is much appreciated.
I know that it will help make me a better sailor, especially if I attempt to race and be competitive. In addition, it will easier to show people when I take them sailing for their first time, how to watch the wind for they always complain that they can't see it...... It will also help my significant other to help keep the boat pointed into wind when hoisting sails... somehow, they can't grasp the yarn concept.... I do have one of the front of the mast, which is used for my wind instrument, but which is another project to work on...
Thank you all for responding back! Have a great day, happy sailing and be safe!
Regards,,
Rochester, NY
Date: Fri, 2 May 2014 14:54:30 -0700
Mark
Mark A. Stahnke
MAS Consulting
(310)
832-5992
Chris
Campbell
vane
frequently.
I don't set
My constant
My Two
Cents
Annapolis
PM
Subject:
Greets everyone,,,
advice!
Happy Sailing
Rochester,
NY
