Re: [Cal_Boats] Cal 39 Keel hull joint crack pics (bad)
7 messages2014-05-20 13:10 UTCthrough 2014-05-20 18:19 UTC
pw… [at] aol.com2014-05-20 13:10 UTC
Greg - Crack happened last summer. Just discovered as I was sanding the bottom to repaint a few days ago. I had done some repair work on the keel when I first got the boat 6 yrs ago but the voids you see are not in my work. I am headed over there tonight to start feathering back the divot I ground down to find the bottom of the crack. I am also going to add more layers to the interior as suggested by a friend of mine who's an expert in the boat repair biz. Paul In a message dated 5/20/2014 8:56:20 A.M. Eastern Daylight Time, Ca… [at] yahoogroups.com writes: Paul, Is this new? Or is this an old project? There looks like a lot of voids in the glass work. Greg -------------------------------------------- On Mon, 5/19/14, pw… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Subject: [Cal_Boats] Cal 39 Keel hull joint crack pics (bad) To: Ca… [at] yahoogroups.com Date: Monday, May 19, 2014, 7:47 PM Peter - No, not bolted on and it has turned out to be a BFD. Here are the latest pics. Started grinding down to get to the bottom of the crack and was able to see daylight in the cabin! Not good! This is looking forward just aft of the mast step. The green is light coming thru where I ground out below. This is looking to port under the shower pan. Again the greenish area is where the light is coming thru. This is for reference. You can see the light in the corner of where the sole is pulled out. This is the side view. I've got a lot more grinding to do to feather out the divot in the leading edge of the keel. Not fun. Paul In a message dated 5/19/2014 10:38:24 P.M. Eastern Daylight Time, Ca… [at] yahoogroups.com writes: Your 39 has the keel bolted on? Ours is internal ballast. I would be a little excited to see a crack on ours! Peter 1978 39' Bribon "It's not just the cars, it's the people!" Porsche slogan Hmmm, for boating list should be boats, not cars...
Greg vanDalen2014-05-20 13:57 UTC
Paul, Good luck with it. What a crappy way to start your summer, but I guess it's better to know now rather than when you are off shore. The next time we haul out I'm going to do some serious inspecting around that port. Greg -------------------------------------------- On Tue, 5/20/14, pw… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Subject: Re: [Cal_Boats] Cal 39 Keel hull joint crack pics (bad) To: Ca… [at] yahoogroups.com Date: Tuesday, May 20, 2014, 6:10 AM Greg - Crack happened last summer. Just discovered as I was sanding the bottom to repaint a few days ago. I had done some repair work on the keel when I first got the boat 6 yrs ago but the voids you see are not in my work. I am headed over there tonight to start feathering back the divot I ground down to find the bottom of the crack. I am also going to add more layers to the interior as suggested by a friend of mine who's an expert in the boat repair biz. Paul In a message dated 5/20/2014 8:56:20 A.M. Eastern Daylight Time, Ca… [at] yahoogroups.com writes: Paul, Is this new? Or is this an old project? There looks like a lot of voids in the glass work. Greg -------------------------------------------- On Mon, 5/19/14, pw… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Subject: [Cal_Boats] Cal 39 Keel hull joint crack pics (bad) To: Ca… [at] yahoogroups.com Date: Monday, May 19, 2014, 7:47 PM Peter - No, not bolted on and it has turned out to be a BFD. Here are the latest pics. Started grinding down to get to the bottom of the crack and was able to see daylight in the cabin! Not good! This is looking forward just aft of the mast step. The green is light coming thru where I ground out below. This is looking to port under the shower pan. Again the greenish area is where the light is coming thru. This is for reference. You can see the light in the corner of where the sole is pulled out. This is the side view. I've got a lot more grinding to do to feather out the divot in the leading edge of the keel. Not fun. Paul In a message dated 5/19/2014 10:38:24 P.M. Eastern Daylight Time, Ca… [at] yahoogroups.com writes: Your 39 has the keel bolted on? Ours is internal ballast. I would be a little excited to see a crack on ours! Peter 1978 39' Bribon "It's not just the cars, it's the people!" Porsche slogan Hmmm, for boating list should be boats, not cars...
Re: Cal 39 Keel hull joint crack pics (bad)
br… [at] gmail.com2014-05-20 16:23 UTC
For some reason I cannot get your photos to display. I would really like to see them as I have some keel concerns with my Cal29. Can you send them direct to me? If so, my email is: Br… [at] gmail.com Many thanks, and best of luck with this issue. Brad Bates
Michael Kennedy2014-05-20 16:24 UTC
Ugh ! I hate to bring it up but you might want to look at what they did to Montgomery Street. The owners cut off the old keel, built a new structure on the bottom and added a bolt on keel. After that, they won the Transpac with the new configuration. The Cal 40 keel (and the Cal 39) was a new innovation in 1963 but they get old. That was a big job but this looks scary. Sinking scary. You might want to contact Dave Denning and get the info on their job. They did a lot of it themselves with a design from an architect. Mike Kennedy On Tue, May 20, 2014 at 6:57 AM, Greg vanDalen no… [at] yahoo.com[Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > > Paul, > > Good luck with it. What a crappy way to start your summer, but I guess > it's better to know now rather than when you are off shore. The next time > we haul out I'm going to do some serious inspecting around that port. > > Greg > -------------------------------------------- > On Tue, 5/20/14, pw… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> > wrote: > > Subject: Re: [Cal_Boats] Cal 39 Keel hull joint crack pics (bad) > To: Ca… [at] yahoogroups.com > Date: Tuesday, May 20, 2014, 6:10 AM > > > > Greg - > > Crack happened last summer. Just discovered as I was > sanding the > bottom to repaint a few days ago. I had done some repair > work on the keel > when I first got the boat 6 yrs ago but the voids you see > are not in my > work. I am headed over there tonight to start feathering > back the divot I > ground down to find the bottom of the crack. I am also > going to add more > layers to the interior as suggested by a friend of mine > who's an expert in the > boat repair biz. > > Paul > > > In a message dated 5/20/2014 8:56:20 A.M. Eastern > Daylight Time, > Ca… [at] yahoogroups.com writes: > > > Paul, > > Is this new? Or > is this an old project? There looks like a lot > of voids in the glass > work. > > Greg > -------------------------------------------- > On Mon, > 5/19/14, pw… [at] aol.com [Cal_Boats] > <Ca… [at] yahoogroups.com> > wrote: > > Subject: > [Cal_Boats] Cal 39 Keel hull joint crack pics > (bad) > To: Ca… [at] yahoogroups.com > Date: Monday, May 19, 2014, 7:47 > PM > > > > > Peter - > > No, not bolted on and it has > turned out to be a > BFD. Here are the > latest > pics. > > Started grinding > down to get to the bottom of the > crack > and was able to see > daylight in the cabin! Not good! > > This > is looking forward just aft of the mast > step. The green is light > > coming thru where I ground out below. > > > This is > looking to > port under the shower pan. > Again the > greenish area > is where the > light is coming thru. > > > > This is for > reference. You > can see the light in > the corner of where > > the sole is pulled > out. > > > This is the side view. I've got a lot > more > grinding to do to feather > out the divot in the leading edge of the > keel. > Not fun. > > Paul > > > In a message dated > 5/19/2014 10:38:24 P.M. Eastern > Daylight > Time, > > Ca… [at] yahoogroups.com writes: > > > Your 39 > has the keel > bolted on? Ours is internal > ballast. I > would be a > little excited to see > a crack on ours! > Peter > 1978 39' > Bribon > > "It's not just the > cars, it's the people!" > Porsche > > slogan > Hmmm, for boating > list should > be boats, not > cars... > > > > > > > > > > > > > -- > { > margin:10px > 0;padding:0 10px;} > > hr { > } > > { > color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px > 0;} > > { > margin-bottom:10px;} > > .yiv6577984854ad { > } > > .yiv6577984854ad p { > } > > .yiv6577984854ad a { > color:#0000ff;text-decoration:none;} > > { > } > > > { > margin:10px > 0px;font-weight:700;font-size:78%;line-height:122%;} > > > .yiv6577984854ad { > margin-bottom:10px;padding:0 0;} > > { > } > > { > > background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} > > span { > font-weight:700;} > > span:first-child { > text-transform:uppercase;} > > span a { > color:#5085b6;text-decoration:none;} > > span span { > color:#ff7900;} > > span > .yiv6577984854underline { > text-decoration:underline;} > > .yiv6577984854attach { > clear:both;display:table;font-family:Arial;font-size:12px;padding:10px > 0;width:400px;} > > .yiv6577984854attach div a { > text-decoration:none;} > > .yiv6577984854attach img { > padding-right:5px;} > > .yiv6577984854attach label { > display:block;margin-bottom:5px;} > > .yiv6577984854attach label a { > text-decoration:none;} > > blockquote { > } > > .yiv6577984854bold { > font-weight:700;} > > .yiv6577984854bold a { > text-decoration:none;} > > dd.yiv6577984854last p a { > font-weight:700;} > > dd.yiv6577984854last p span { > margin-right:10px;font-family:Verdana;font-weight:700;} > > dd.yiv6577984854last p > span.yiv6577984854yshortcuts { > margin-right:0;} > > div.yiv6577984854attach-table div div a { > text-decoration:none;} > > div.yiv6577984854attach-table { > } > > div.yiv6577984854file-title a, > div.yiv6577984854file-title a:active, > div.yiv6577984854file-title a:hover, > div.yiv6577984854file-title a:visited { > text-decoration:none;} > > div.yiv6577984854photo-title a, > div.yiv6577984854photo-title a:active, > div.yiv6577984854photo-title a:hover, > div.yiv6577984854photo-title a:visited { > text-decoration:none;} > > div > p a span.yiv6577984854yshortcuts { > font-weight:normal;} > > .yiv6577984854green { > color:#628c2a;} > > .yiv6577984854MsoNormal { > } > > o { > } > > div { > float:left;width:72px;} > > div div { > border:1px solid > #666666;height:62px;overflow:hidden;width:62px;} > > div label { > > color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} > > { > } > > { > } > > .yiv6577984854replbq { > } > > div a:first-child { > margin-right:2px;padding-right:5px;} > > { > font-family:Arial, helvetica, clean, > sans-serif;} > > table { > font:100%;} > > select, > input, textarea { > font:99% Arial, Helvetica, clean, sans-serif;} > > pre, > code { > font:115% monospace;} > > * { > } > > { > padding-bottom:10px;} > > > p a { > } > > > p span { > color:#1E66AE;font-weight:700;} > > > { > color:#ff7900;font-weight:700;} > > { > margin-bottom:20px;padding:0px;} > > > li a { > text-decoration:none;} > > > li { > list-style-type:square;padding:6px 0;} > > > ul { > } > > { > } > > p { > } > > tt { > } > > ul li:last-child { > border-right:none !important; > } > > > >
pw… [at] aol.com2014-05-20 16:39 UTC
Mike - My boat is a 1980 so it's not "that old" but I hear ya. I spoke with a friend who is an expert in this type of work and did the same thing you mentioned to another boat. He also sails on Belle Aurore the Cal 40 that won the last Newport to Bermuda race (I think) and was consulted on the repair of Sein Finn after Sandy hit. Anyway, when they did the Marblehead to Halifax race on Belle Aurore they were taking on water from a crack behind the keel. When they got to Halifax they "pinned" the boat up against the bulkhead (dont' ask me how) and when the tide went out they inspected the crack, filled it with 5200 to get them back to the states and then fixed it correctly. My friend advised me to lay up more layers on the inside of the hull to add more strength to that area which I will do. Wish me luck. Paul In a message dated 5/20/2014 12:24:13 P.M. Eastern Daylight Time, Ca… [at] yahoogroups.com writes: Ugh ! I hate to bring it up but you might want to look at what they did to Montgomery Street. The owners cut off the old keel, built a new structure on the bottom and added a bolt on keel. After that, they won the Transpac with the new configuration. The Cal 40 keel (and the Cal 39) was a new innovation in 1963 but they get old. That was a big job but this looks scary. Sinking scary. You might want to contact Dave Denning and get the info on their job. They did a lot of it themselves with a design from an architect. Mike Kennedy On Tue, May 20, 2014 at 6:57 AM, Greg vanDalen _n… [at] yahoo.com_ (mailto:no… [at] yahoo.com) [Cal_Boats] <_C… [at] yahoogroups.com_ (mailto:Ca… [at] yahoogroups.com) > wrote: Paul, Good luck with it. What a crappy way to start your summer, but I guess it's better to know now rather than when you are off shore. The next time we haul out I'm going to do some serious inspecting around that port. Greg -------------------------------------------- On Tue, 5/20/14, _p… [at] aol.com_ (mailto:pw… [at] aol.com) [Cal_Boats] <_C… [at] yahoogroups.com_ (mailto:Ca… [at] yahoogroups.com) > wrote: Subject: Re: [Cal_Boats] Cal 39 Keel hull joint crack pics (bad) To: _C… [at] yahoogroups.com_ (mailto:Ca… [at] yahoogroups.com) Date: Tuesday, May 20, 2014, 6:10 AM Greg - Crack happened last summer. Just discovered as I was sanding the bottom to repaint a few days ago. I had done some repair work on the keel when I first got the boat 6 yrs ago but the voids you see are not in my work. I am headed over there tonight to start feathering back the divot I ground down to find the bottom of the crack. I am also going to add more layers to the interior as suggested by a friend of mine who's an expert in the boat repair biz. Paul In a message dated 5/20/2014 8:56:20 A.M. Eastern Daylight Time, _C… [at] yahoogroups.com_ (mailto:Ca… [at] yahoogroups.com) writes: Paul, Is this new? Or is this an old project? There looks like a lot of voids in the glass work. Greg -------------------------------------------- On Mon, 5/19/14, _p… [at] aol.com_ (mailto:pw… [at] aol.com) [Cal_Boats] <_C… [at] yahoogroups.com_ (mailto:Ca… [at] yahoogroups.com) > wrote: Subject: [Cal_Boats] Cal 39 Keel hull joint crack pics (bad) To: _C… [at] yahoogroups.com_ (mailto:Ca… [at] yahoogroups.com) Date: Monday, May 19, 2014, 7:47 PM Peter - No, not bolted on and it has turned out to be a BFD. Here are the latest pics. Started grinding down to get to the bottom of the crack and was able to see daylight in the cabin! Not good! This is looking forward just aft of the mast step. The green is light coming thru where I ground out below. This is looking to port under the shower pan. Again the greenish area is where the light is coming thru. This is for reference. You can see the light in the corner of where the sole is pulled out. This is the side view. I've got a lot more grinding to do to feather out the divot in the leading edge of the keel. Not fun. Paul In a message dated 5/19/2014 10:38:24 P.M. Eastern Daylight Time, _C… [at] yahoogroups.com_ (mailto:Ca… [at] yahoogroups.com) writes: Your 39 has the keel bolted on? Ours is internal ballast. I would be a little excited to see a crack on ours! Peter 1978 39' Bribon "It's not just the cars, it's the people!" Porsche slogan Hmmm, for boating list should be boats, not cars...
pw… [at] aol.com2014-05-20 16:52 UTC
Thanks Greg - Just wish I'd discovered it on haul out. You can bet I'll be inspecting things a LOT more closely from now on! Paul In a message dated 5/20/2014 12:49:45 P.M. Eastern Daylight Time, Ca… [at] yahoogroups.com writes: Paul, Good luck with it. What a crappy way to start your summer, but I guess it's better to know now rather than when you are off shore. The next time we haul out I'm going to do some serious inspecting around that port. Greg -------------------------------------------- On Tue, 5/20/14, pw… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Subject: Re: [Cal_Boats] Cal 39 Keel hull joint crack pics (bad) To: Ca… [at] yahoogroups.com Date: Tuesday, May 20, 2014, 6:10 AM Greg - Crack happened last summer. Just discovered as I was sanding the bottom to repaint a few days ago. I had done some repair work on the keel when I first got the boat 6 yrs ago but the voids you see are not in my work. I am headed over there tonight to start feathering back the divot I ground down to find the bottom of the crack. I am also going to add more layers to the interior as suggested by a friend of mine who's an expert in the boat repair biz. Paul In a message dated 5/20/2014 8:56:20 A.M. Eastern Daylight Time, Ca… [at] yahoogroups.com writes: Paul, Is this new? Or is this an old project? There looks like a lot of voids in the glass work. Greg -------------------------------------------- On Mon, 5/19/14, pw… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: Subject: [Cal_Boats] Cal 39 Keel hull joint crack pics (bad) To: Ca… [at] yahoogroups.com Date: Monday, May 19, 2014, 7:47 PM Peter - No, not bolted on and it has turned out to be a BFD. Here are the latest pics. Started grinding down to get to the bottom of the crack and was able to see daylight in the cabin! Not good! This is looking forward just aft of the mast step. The green is light coming thru where I ground out below. This is looking to port under the shower pan. Again the greenish area is where the light is coming thru. This is for reference. You can see the light in the corner of where the sole is pulled out. This is the side view. I've got a lot more grinding to do to feather out the divot in the leading edge of the keel. Not fun. Paul In a message dated 5/19/2014 10:38:24 P.M. Eastern Daylight Time, Ca… [at] yahoogroups.com writes: Your 39 has the keel bolted on? Ours is internal ballast. I would be a little excited to see a crack on ours! Peter 1978 39' Bribon "It's not just the cars, it's the people!" Porsche slogan Hmmm, for boating list should be boats, not cars...
Allen Edwards2014-05-20 18:19 UTC
It is nice to have friends like that. I am lucky to have one who knows the L-36 well. His dad built them and he spent his youth hanging out in the yard. Allen On Tue, May 20, 2014 at 9:52 AM, pw… [at] aol.com [Cal_Boats] < Ca… [at] yahoogroups.com> wrote: > > > Thanks Greg - > > Just wish I'd discovered it on haul out. You can bet I'll be inspecting > things a LOT more closely from now on! > > Paul > > In a message dated 5/20/2014 12:49:45 P.M. Eastern Daylight Time, > Ca… [at] yahoogroups.com writes: > > > > Paul, > > Good luck with it. What a crappy way to start your summer, but I guess > it's better to know now rather than when you are off shore. The next time > we haul out I'm going to do some serious inspecting around that port. > > Greg > -------------------------------------------- > On Tue, 5/20/14, pw… [at] aol.com [Cal_Boats] <Ca… [at] yahoogroups.com> > wrote: > > Subject: Re: [Cal_Boats] Cal 39 Keel hull joint crack pics (bad) > To: Ca… [at] yahoogroups.com > Date: Tuesday, May 20, 2014, 6:10 AM > > > Greg - > > Crack happened last summer. Just discovered as I was > sanding the > bottom to repaint a few days ago. I had done some repair > work on the keel > when I first got the boat 6 yrs ago but the voids you see > are not in my > work. I am headed over there tonight to start feathering > back the divot I > ground down to find the bottom of the crack. I am also > going to add more > layers to the interior as suggested by a friend of mine > who's an expert in the > boat repair biz. > > Paul > > > In a message dated 5/20/2014 8:56:20 A.M. Eastern > Daylight Time, > Ca… [at] yahoogroups.com writes: > > > Paul, > > Is this new? Or > is this an old project? There looks like a lot > of voids in the glass > work. > > Greg > -------------------------------------------- > On Mon, > 5/19/14, pw… [at] aol.com [Cal_Boats] > <Ca… [at] yahoogroups.com> > wrote: > > Subject: > [Cal_Boats] Cal 39 Keel hull joint crack pics > (bad) > To: Ca… [at] yahoogroups.com > Date: Monday, May 19, 2014, 7:47 > PM > > > > > Peter - > > No, not bolted on and it has > turned out to be a > BFD. Here are the > latest > pics. > > Started grinding > down to get to the bottom of the > crack > and was able to see > daylight in the cabin! Not good! > > This > is looking forward just aft of the mast > step. The green is light > > coming thru where I ground out below. > > > This is > looking to > port under the shower pan. > Again the > greenish area > is where the > light is coming thru. > > > > This is for > reference. You > can see the light in > the corner of where > > the sole is pulled > out. > > > This is the side view. I've got a lot > more > grinding to do to feather > out the divot in the leading edge of the > keel. > Not fun. > > Paul > > > In a message dated > 5/19/2014 10:38:24 P.M. Eastern > Daylight > Time, > > Ca… [at] yahoogroups.com writes: > > > Your 39 > has the keel > bolted on? Ours is internal > ballast. I > would be a > little excited to see > a crack on ours! > Peter > 1978 39' > Bribon > > "It's not just the > cars, it's the people!" > Porsche > > slogan > Hmmm, for boating > list should > be boats, not > cars... > > > > > > > > > > > > > -- > { > margin:10px > 0;padding:0 10px;} > > hr { > } > > { > color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px > 0;} > > { > margin-bottom:10px;} > > .yiv6577984854ad { > } > > .yiv6577984854ad p { > } > > .yiv6577984854ad a { > color:#0000ff;text-decoration:none;} > > { > } > > > { > margin:10px > 0px;font-weight:700;font-size:78%;line-height:122%;} > > > .yiv6577984854ad { > margin-bottom:10px;padding:0 0;} > > { > } > > { > > background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} > > span { > font-weight:700;} > > span:first-child { > text-transform:uppercase;} > > span a { > color:#5085b6;text-decoration:none;} > > span span { > color:#ff7900;} > > span > .yiv6577984854underline { > text-decoration:underline;} > > .yiv6577984854attach { > clear:both;display:table;font-family:Arial;font-size:12px;padding:10px > 0;width:400px;} > > .yiv6577984854attach div a { > text-decoration:none;} > > .yiv6577984854attach img { > padding-right:5px;} > > .yiv6577984854attach label { > display:block;margin-bottom:5px;} > > .yiv6577984854attach label a { > text-decoration:none;} > > blockquote { > } > > .yiv6577984854bold { > font-weight:700;} > > .yiv6577984854bold a { > text-decoration:none;} > > dd.yiv6577984854last p a { > font-weight:700;} > > dd.yiv6577984854last p span { > margin-right:10px;font-family:Verdana;font-weight:700;} > > dd.yiv6577984854last p > span.yiv6577984854yshortcuts { > margin-right:0;} > > div.yiv6577984854attach-table div div a { > text-decoration:none;} > > div.yiv6577984854attach-table { > } > > div.yiv6577984854file-title a, > div.yiv6577984854file-title a:active, > div.yiv6577984854file-title a:hover, > div.yiv6577984854file-title a:visited { > text-decoration:none;} > > div.yiv6577984854photo-title a, > div.yiv6577984854photo-title a:active, > div.yiv6577984854photo-title a:hover, > div.yiv6577984854photo-title a:visited { > text-decoration:none;} > > div > p a span.yiv6577984854yshortcuts { > font-weight:normal;} > > .yiv6577984854green { > color:#628c2a;} > > .yiv6577984854MsoNormal { > } > > o { > } > > div { > float:left;width:72px;} > > div div { > border:1px solid > #666666;height:62px;overflow:hidden;width:62px;} > > div label { > > color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} > > { > } > > { > } > > .yiv6577984854replbq { > } > > div a:first-child { > margin-right:2px;padding-right:5px;} > > { > font-family:Arial, helvetica, clean, > sans-serif;} > > table { > font:100%;} > > select, > input, textarea { > font:99% Arial, Helvetica, clean, sans-serif;} > > pre, > code { > font:115% monospace;} > > * { > } > > { > padding-bottom:10px;} > > > p a { > } > > > p span { > color:#1E66AE;font-weight:700;} > > > { > color:#ff7900;font-weight:700;} > > { > margin-bottom:20px;padding:0px;} > > > li a { > text-decoration:none;} > > > li { > list-style-type:square;padding:6px 0;} > > > ul { > } > > { > } > > p { > } > > tt { > } > > ul li:last-child { > border-right:none !important; > } > > > >
