3 messages2014-06-12 12:23 UTCthrough 2014-06-12 13:15 UTC
Re: depth finder - Cal 2-29
Paulus2014-06-12 12:23 UTC
Why make a hole? Most if not all senders will shoot through the hull once you find solid glass (a place where there is no liner and no bubbles in the glass). I just put on in and am shooting through the hull under the settee.
Put the ducer in a baggy with water and find the spot that is out of the way and where you get a good and steady reading - then clean the spot and glass the puck to the hull.
Re: [Cal_Boats] Re: depth finder - Cal 2-29
Joe DeMers2014-06-12 12:44 UTC
Excellent idea. You can also use a big blob of silicone to bed the
transducer in, instead of glassing it in.
*Joe DeMers - owner*
Sound Marine Diesel LLC
(860) 666-2184*
> Sent from my iPod
> Posted by: Paulus <du… [at] aim.com>
> Yahoo Groups Links
(860) 666-2184*
Alfred Poor2014-06-12 13:15 UTC
I hate making more holes in a boat hull. We have mounted our depth
transducers inside the hull. Some people bed them with a gob of silicone
caulk, but I prefer to make a container (a section of PVC pipe can work
well) epoxied to the hull), and then filled with mineral oil (doesn't spoil
or grow critters) and suspend the transducer in the oil.
Incidentally, a previous owner had mounted the transducer under the port
quarterberth, and it worked fine for us there. Our Tartan has it in the bow
as you describe, but I don't have a strong opinion about location.
All the best,
Alfred Poor
(former owner of 1969 Cal 29 #132 "Pentaquod")
