RE: [Cal_Boats] Re: gas engine question
Husar, Charlie [USA] (ASE)2014-07-06 03:21 UTC
Whoever gave this response, thank you very much. The back EMF causes the current flow to drop. The DC resistance of the coil wire is not the driving factor.
Kind of like a capacitor starts high current, then it drops off a the capacitor charges. The inductor is similar to the capacitor except that the energy is stored in the magnetic field instead of in the electron charge (as in the capacitor).
Take Care
Sent: Saturday, July 05, 2014 9:47 AM
Subject: [External] [Cal_Boats] Re: gas engine question
A coil is an inductive electrical circuit which opposes the flow of current through it. The current limiting factor is due to the presence of the self induced emf within the inductor as a result of the growth of magnetic flux, (Lenz’s Law). After a time the voltage source neutralizes the effect of the self induced emf, the current flow, quickly reduced from a theoretical initial short circuit, becomes constant and the induced current and field are reduced to zero.
Re: [Cal_Boats] Re: gas engine question
Allen Edwards2014-07-06 06:26 UTC
Kind of like a capacitor except totally the opposite. When a voltage is
applied, a capacitor starts off at high current and drops to zero. An
inductor starts at zero current and increases.
Inductor v = L*di/dt
Capacitor i = C * dv/dt
See, very similar but opposite.
Said another way, with a capacitor, the voltage is proportional to the
integral of the current. The longer you supply a current to a capacitor,
the higher the voltage. Similarly, with an inductor the current is the
integral of the voltage. The longer you apply a voltage, the higher the
current. If there is no resistance, the current will grow until it is
infinitely large at which point the thing blows up.
It has been a long time since I studied this stuff but I do have a masters
in electrical engineering from a local college here in Palo Alto.
On Sat, Jul 5, 2014 at 8:21 PM, 'Husar, Charlie [USA] (ASE)'
> driving factor.
> Take Care
> Charlie
> *Sent:* Saturday, July 05, 2014 9:47 AM
> *Subject:* [External] [Cal_Boats] Re: gas engine question
