10 messages2014-07-28 14:33 UTCthrough 2014-07-29 16:14 UTC
carburetor advice
Chris Campbell2014-07-28 14:33 UTC
Listmates:
This is slightly off-topic, but many of us are old enough to remember
what a carburetor is, so I'll pose the question.
I'm rebuilding the Rochester 4-Jet carb from a 1961 Chevy. I had the
original shop manual so disassembly and reassembly were fairly easy.
But one of the last steps is setting the float height. It's an old carb
so I don't have a nice factory kit with a float height gauge to measure
it. The shop manual cites a primary float height of 1-33/64" and
secondary of 1-37/64". Geez, this is a device that you adjust by
bending pieces of metal--and who can even SEE 1/64"???
So I rounded off to the nearest 32nd inch (they provide a little scale
in 32nds). Then I kinda eyeballed it.
So the question is--how exact do you have to be in setting float height
in an old carb like this? When they talk about 64ths of an inch, it
makes it sound like I ought to have a dial gauge deployed, but it's
usually done with a cardboard gauge device. How much should I fret over
this?
Re: [Cal_Boats] carburetor advice
pw… [at] aol.com2014-07-28 14:59 UTC
The carb kit didn't come with a guage? I wouldn't sweat it too much but as my fading memory recalls, the kits used to come with a cardboard guage. I remember those old 4 barrels well as kicking in the secondaries was like flushing the toilet. I inherited my grandmother's old Pontiac Grand Ville with a 455 cid in it and I could literally watch the gas gauge move when I punched it.
Hell, I adjusted the float on my 2 barrel carb on my Jeep on the top of a mountain pass in Colorado once because all the bouncing around I was doing was bending the metal on the float plus the change in altitude was making it run even richer due to larger jets for lower altitude.
Good luck -
Paul
From: Chris Campbell cc… [at] lsnm.org [Cal_Boats] <Ca… [at] yahoogroups.com>
Sent: Mon, Jul 28, 2014 10:33 am
Subject: [Cal_Boats] carburetor advice
Listmates:
this?
RE: [Cal_Boats] carburetor advice
Ted Wrobel2014-07-28 15:13 UTC
I wouldn't worry at all. Remember that a long as the float closes the needle
valve before the bowl overflows you won't have a real problem.
A small difference in fuel level in the bowl will have a very small effect
on the fuel drawn by the suction in the venturie. The difference in fuel
supply pressure will be tiny.
Ted
CAL 33 Celebration
Newport, RI
Sent: Monday, July 28, 2014 10:34 AM
Listmates:
this?
Allen Edwards2014-07-28 15:44 UTC
I have rebuilt many carburetors over the years and have never changed the
float height. I think that is something you do when you are installing a
new float. Once it is set, just leave it. If I had to do it, I would use
a caliper or make a cardboard gauge and measure it with a caliper. Not
that it is necessary, but why not?
On Mon, Jul 28, 2014 at 8:13 AM, 'Ted Wrobel' tw… [at] tacticaltech.com
[Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
> I wouldn’t worry at all. Remember that a long as the float closes the
> needle valve before the bowl overflows you won’t have a real problem.
> Ted
> CAL 33 Celebration
> Newport, RI
> *Sent:* Monday, July 28, 2014 10:34 AM
> *Subject:* [Cal_Boats] carburetor advice
> Listmates:
> this?
> Thanks,
> Chris Campbell
Chris Campbell2014-07-28 15:51 UTC
On 7/28/2014 11:44 AM, Allen Edwards al… [at] gmail.com
> the float height. I think that is something you do when you are
> installing a new float.
The inlet valve and seat in the kit are a different design than the
original, so it changes the float height when installed.
Thanks for the replies so far. I think I'll open up the carb one more
time and verify that I've got the float height reasonably close. That
will allow me to stop worrying about it. It's easier to recheck it now,
off the car, than to have a lingering doubt later when I finally try to
start the thing. I don't think I'll worry about whether the 1-37/64"
height is really set at 1-36/64 or 1-38/64.
Leslie Newman2014-07-28 17:48 UTC
I'm 55, so yes I have seen my fair share of carbs and rebuilt plenty.
Regarding adjusting the float....I just went through that this past weekend
during a carb rebuild. I am lucky in that my 1977 Toyota FJ40 Land Cruiser
carb has a sight window on the bowl, with a nice dot in the center, so
after you have adjusted the float and put everything back and the truck is
running (hopefull), you can visually see if you got it right.
But, regarding adjustment, as others said, each time you rebuild, you do
need to adjust the float due to variances in the needle and such. What I do
is measure and cut out a gauge from a nice stiff piece of construction
paper. Something that will go all the way across so as like a straight edge
I can slip under the float. You always take the measurement with the top of
the carb inverted, and no gasket. Slip the gauge between carb face and
bottom of float. Adjust until it just slips under without raising the
float. Done.
On Mon, Jul 28, 2014 at 11:51 AM, Chris Campbell cc… [at] lsnm.org
> new float.
> time and verify that I've got the float height reasonably close. That will
> allow me to stop worrying about it. It's easier to recheck it now, off the
> car, than to have a lingering doubt later when I finally try to start the
> thing. I don't think I'll worry about whether the 1-37/64" height is
> Chris Campbell
Chris Campbell2014-07-28 18:30 UTC
> do need to adjust the float due to variances in the needle and such.
> What I do is measure and cut out a gauge from a nice stiff piece of
> construction paper. Something that will go all the way across so as
> like a straight edge I can slip under the float. You always take the
> measurement with the top of the carb inverted, and no gasket. Slip the
> gauge between carb face and bottom of float. Adjust until it just
> slips under without raising the float. Done.
The Chevy float height measurement is done with the gasket in place,
which makes for an additional complication, and it's to the bottom of
the float.. I'm going to build a little fixture to hold the carb top
plate securely so my hands are all free to fiddle.
Maybe I'll try making my own gauge, trying to be accurate within +/-
1/64" !!! I guess I was just a bit alarmed when the shop manual called
it out to a 64th, suggesting that unusual precision was needed.
Leslie Newman2014-07-29 14:26 UTC
Huh. Thanks for that info. Most carbs I've done typically you do the
measurement without gasket, but of course follow the instructions. You made
me go do some searching and I found a great site with lots of free manuals.
Here is your Carb manual (and a ton other variations).
http://www.newagemetal.com/pages/Chevrolet/32-62Chevy.pdf
http://www.oldcarmanualproject.com/
Leslie
Cal 33-2 Puffin
On Mon, Jul 28, 2014 at 2:30 PM, Chris Campbell cc… [at] lsnm.org
> float. Done.
> The Chevy float height measurement is done with the gasket in place, which
> makes for an additional complication, and it's to the bottom of the
> float.. I'm going to build a little fixture to hold the carb top plate
> 1/64" !!! I guess I was just a bit alarmed when the shop manual called it
> Chris Campbell
Chris Campbell2014-07-29 15:19 UTC
The gasket is used in place because the float assemblies capture the
gasket, I guess. If you were just pulling the top plate off to check
the float height, you could measure with gasket in place. But then the
gasket would be used and compressed, not new like mine, which makes me
wonder about GM's obsession with measurements in 64ths.
The first link you sent does not show the 1961 4GC carb, but does show
the 1956 version--and that one shows float height measured in
8ths--1-5/8" for both sets of floats. By 1961, they were calling for
1-33/64" and 1-37/64", neither of which is really too far from 1-5/8".
That may be a clue. It would be interesting to know what GM's
production toelrances were back then.
I'm going to try to make a gauge to make the setting process easier.
Problem is, the carb is sitting 140 miles from where I am sitting, so
I'll probably make two L-shaped pieces then staple them together into a
U at the right width when the carb is in front of me.
Thanks for sending the links.
Chris Campbell2014-07-29 16:14 UTC
> made me go do some searching and I found a great site with lots of
> free manuals. Here is your Carb manual (and a ton other variations).
> Leslie
Send me your own e-mail, please, so I can send something off-list.
