17 messages2014-07-18 21:20 UTCthrough 2014-08-04 21:11 UTC
Aluminum spar refinishing?
Greg Beron2014-07-18 21:20 UTC
We just pulled the old mainsail off our Cal 29 "Happy Hour" after having it rip from leech to luff a couple of weeks ago. It was ~40 years old and replacement was on the todo list, so no surprise. However in looking at the boom, we decided to clean off any corrosion and refinish it before installing the new main (see pic.)
Does anyone have a recommendation for products to use? Don Casey's book simply says urethane and notes that the primer would probably be acid-based.
Thanks!
Greg Beron, Happy Hour, Cal 29 #41
Re: [Cal_Boats] Aluminum spar refinishing? [1 Attachment]
Allen Edwards2014-07-18 21:45 UTC
As a wood boat owner, I am probably the last person who should be giving
advice but I will offer some things to think about. If you sand the spar
down and there was any anodizing on it, you will sand through it and expose
bare aluminum. Aluminum will oxidize faster than you can sand it and the
paint won't stick to aluminum oxide. You can treat bare aluminum by
alodining it. That is a two part process and leaves the spar coated with
aluminum-chromate instead of aluminum oxide and the paint will stick to
that. But if the underlying anodizing is OK, perhaps you can strip the old
paint off. But it may be that there was never any anodizing.
So there you have it. I just created more questions than I answered. You
are welcome.
On Fri, Jul 18, 2014 at 2:20 PM, Greg Beron gb… [at] yahoo.com [Cal_Boats] <
Ca… [at] yahoogroups.com> wrote:
> [Attachment(s) <#1474b5944d469865_TopText> from Greg Beron included
> below]
> Thanks!
> Sent from my iPhone
Helen Horn2014-07-19 16:09 UTC
Our boom wasn't painted on our 29 when it snapped at a midboom sheet bail, and we discovered internal corrosion, so when we fabricated a replacement boom from a venture McGregor mast identical extrusion, we left rinse/drain holes to be able to flush with fresh water. Those bubbles are corrosion under the paint on the outside. Be sure to inspect the inside possibly with a scope. Helen
Greg Beron2014-07-25 04:47 UTC
Thank you, Helen! Will do!
> On Jul 19, 2014, at 9:09 AM, "Helen Horn he… [at] sbcglobal.net [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
> From: Allen Edwards al… [at] gmail.com [Cal_Boats] <Ca… [at] yahoogroups.com>;
> To: Ca… [at] yahoogroups.com <Ca… [at] yahoogroups.com>;
> Subject: Re: [Cal_Boats] Aluminum spar refinishing?
> Sent: Fri, Jul 18, 2014 9:45:19 PM
> As a wood boat owner, I am probably the last person who should be giving advice but I will offer some things to think about. If you sand the spar down and there was any anodizing on it, you will sand through it and expose bare aluminum. Aluminum will oxidize faster than you can sand it and the paint won't stick to aluminum oxide. You can treat bare aluminum by alodining it. That is a two part process and leaves the spar coated with aluminum-chromate instead of aluminum oxide and the paint will stick to that. But if the underlying anodizing is OK, perhaps you can strip the old paint off. But it may be that there was never any anodizing.
> So there you have it. I just created more questions than I answered. You are welcome.
> Allen
>> On Fri, Jul 18, 2014 at 2:20 PM, Greg Beron gb… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
>> [Attachment(s) from Greg Beron included below]
>> Thanks!
>> Sent from my iPhone
mike2014-07-25 06:02 UTC
Also, as a heads up: My friend snapped her boom in half when she
switched from full foot to loose foot main with her mid-boom mainsheet.
Bent the boom like an archer pulling an arrow and SNAP! It's called
"frankenboom" now as we welded it back together with a huge internal
pipe to beef it up. Ain't pretty, but it will never fail again.
Mike
> Sent from my iPhone
> <mailto:he… [at] sbcglobal.net> [Cal_Boats]"
>> *From: * Allen Edwards al… [at] gmail.com
>> <mailto:al… [at] gmail.com> [Cal_Boats]
>> <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>>;
>> *To: * Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
>> *Subject: * Re: [Cal_Boats] Aluminum spar refinishing?
>> *Sent: * Fri, Jul 18, 2014 9:45:19 PM
>> You are welcome.
>> Allen
>> included below]
>> pic.)
>> Thanks!
>> Sent from my iPhone
Re: [Cal_Boats] Aluminum spar refinishing? [1 Attachment] (Greg)
Michael D2014-07-25 12:24 UTC
Greg,
https://www.flickr.com/photos/stefsail/sets/72157622081060993/ has lots of photos of our spar rebuild project. Take a look and feel free to ask questions.
Michael
s/v Magic, Cal 2-27
Pompano Beach, FL
View on www.flickr.com Preview by Yahoo
From: "Greg Beron gb… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
Sent: Friday, July 18, 2014 5:20 PM
Subject: [Cal_Boats] Aluminum spar refinishing? [1 Attachment]
Thanks!
Allen Edwards2014-07-25 15:14 UTC
What did you use to treat the aluminum before you painted it?
On Fri, Jul 25, 2014 at 5:24 AM, Michael D md… [at] yahoo.com [Cal_Boats] <
> Greg,
> questions.
> Michael
> s/v Magic, Cal 2-27
> Pompano Beach, FL
> [image: image]
> <https://www.flickr.com/photos/stefsail/sets/72157622081060993/>
> Preview by Yahoo
> *From:* "Greg Beron gb… [at] yahoo.com [Cal_Boats]" <
> *Sent:* Friday, July 18, 2014 5:20 PM
> *Subject:* [Cal_Boats] Aluminum spar refinishing? [1 Attachment]
> [Attachment(s)
> <https://us-mg6.mail.yahoo.com/neo/launch?.rand=2agfksintf5oq#TopText>
> Thanks!
> Sent from my iPhone
Re: [Cal_Boats] Aluminum spar refinishing? [1 Attachment] (Allen)
Michael D2014-07-25 16:00 UTC
Allen,
It's been a while, but as I recall I used Awlgrip Alumiprep to chemically etch the aluminium followed by a thorough flushing with water. The "yellow" primer was their zinc chromate primer. We followed that with three coats of Awlgrip (two-part) base coat primer (white) and two coats of Awlgrip (two-part) Topcoat. Except for trim/edges, everything was rolled using foam (disposable) rollers.
Michael
From: "Allen Edwards al… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
Sent: Friday, July 25, 2014 11:14 AM
Subject: Re: [Cal_Boats] Aluminum spar refinishing? [1 Attachment] (Greg)
On Fri, Jul 25, 2014 at 5:24 AM, Michael D md… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
>Greg,
>Michael
>s/v Magic, Cal 2-27
>Pompano Beach, FL
>Thanks!
>Sent from my iPhone
Allen Edwards2014-07-25 17:11 UTC
When I repaired my whisker pole and when I bought material to paint my
aluminum car, I was told to use an Alodine process. This is a two part
process the first of which is the Alumiprep or phosphoric acid which is
followed by water as you said and then the the Chromate Alodine solution of
which there seem to be several with numbers like 501, 1001, and 1201. I am
not an expert on which is which but I see looking online that 1201 seems to
be what they use to treat airplanes. Perhaps that is what you used.
I think the idea is that aluminum chromate is stable where aluminum oxide
is not. The paint then sticks to the aluminum chromate. I assume that
either that is what you did or that the zinc chromate primer was an
alternative process. I know aircraft use the Alodine process partly
because it adds no weight. Not as much of a concern for a sailboat.
On Fri, Jul 25, 2014 at 9:00 AM, Michael D md… [at] yahoo.com [Cal_Boats] <
> Allen,
> Michael
> *From:* "Allen Edwards al… [at] gmail.com [Cal_Boats]" <
> *Sent:* Friday, July 25, 2014 11:14 AM
> *Subject:* Re: [Cal_Boats] Aluminum spar refinishing? [1 Attachment]
> (Greg)
> Greg,
> questions.
> Michael
> s/v Magic, Cal 2-27
> Pompano Beach, FL
> [image: image]
> Preview by Yahoo
> [Attachment(s)
> Thanks!
> Sent from my iPhone
Allen Edwards2014-07-25 17:18 UTC
Just looking at the different product descriptions it looks like 1001 is if
you want to have the treated aluminum look clear and 1201 produces a
superior coating but is gold in color. I think I need to get 1201 next
time I need to make some aluminum parts for Papoose. The stuff I was using
was for clear results and that is what it produced. It works but it could
work better.
On Fri, Jul 25, 2014 at 10:11 AM, Allen Edwards <al… [at] gmail.com>
> Allen
>> Allen,
>> Michael
>> (Greg)
>> Greg,
>> questions.
>> Michael
>> s/v Magic, Cal 2-27
>> Pompano Beach, FL
>> [image: image]
>> Preview by Yahoo
>> [Attachment(s)
>> Thanks!
>> Sent from my iPhone
Michael D2014-07-26 16:35 UTC
Allen,
Somewhere at home I have the receipts. I'll give you the specifics when I find them.
Michael
Cal 20--butyl rubber tape
Chris Campbell2014-07-31 15:56 UTC
Listmates:
I had to do a deck repair on the Cal 20. It had an opening for a
ventilator, apparently, a round hole that some previous owner had scred
a 4-1/2" x 4-1/2" plywood cover over. It was a bit unslightly but not
high on my list of priorities--a "someday" project--until Monday.
That's when I noticed that the plywood was present in spirit only. It
had rotted away to mostly dust. Nothing terrifies my like deck leaks
and water in the core, so the matter advanced on my priority list. I
had some scrap Starboard so I cut a new piece to replace the plywood.
Then I got out my $6.00 roll of white butyl rubber tape from the RV
store and bedded it down. I had bought the roll this spring for bedding
my "chainplates" (padeves for shrouds). The stuff is quite
interesting. It continues to squeeze out for a few days after it's
applied. I just keep trimming the squeeze-out. I can't recall who had
suggested it, but for applications that do not require adhesive
qualities, it seems to be a good product. My RV store had it in white
and black.
Re: [Cal_Boats] Cal 20--butyl rubber tape
Helen Horn2014-07-31 19:26 UTC
we have used it to bed stanchions, cleats, and our new portlights. at the rv store we got ours at, you can buy both colors, and even different widths and thicknesses. of course i bought the widest and thickest, and found myself cutting or tearing it narrower for different apps. when I need more (still havent used it all, I'd probably buy the narrower size to accomodate different apps. a year later, I can still tighten screws on ports....wonder if it ever sets up hard. Helen
On Thursday, July 31, 2014 8:56 AM, "Chris Campbell cc… [at] lsnm.org [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
Listmates:
and black.
Chris Campbell2014-07-31 19:36 UTC
> up hard.
Whoever recommended it said that it did not harden. It stays flexible.
I rebedded a portlight on my other boat this spring. The old goo had
been there since 1961. It still had some give. Not sure what it was.
On that one, I used 3M 101 or 4000 (can't remember). I had some 101
left. I wonder if it will last 50 years but probably won't be here to
find out.
Chris
Duane Knize2014-08-02 00:02 UTC
Greg,
I refinished my 1978 Cal39 mast and boom in 1996.
I stripped the spars of all hardware except the sail tracks, removed
what little remaining paint there was, alodyned (gold), masked the sail
tracks, and Awlgripped them with two coats of 2-part undercoat and two
coats of 2-part topcoat.
You can use a butane torch to free fasteners that are frozen with
corrosion (the aluminum oxide seemed to melt).
I refinished the boom in my garage and was able to use a paint sprayer
and achieved a very good finish.
I refinished the mast sitting horizontally on stands at the boatyard
using a paintbrush and obtained a decent finish.
I bedded the hardware with a combination of Boatlife calk and Lanokote
(on threads).
Some corrosion bubbling developed over the years near hardware
attachments and was/is addressed by spot touch ups.
It's nearing time to do the full job again; this time I may pull off the
sail tracks as well, but it may require enlarging the screws and
re-threading.
Good luck,
Duane Knize
S/V Marlyn
1978 Cal 2-39 #18
On 7/25/2014 9:00 AM, Michael D md… [at] yahoo.com [Cal_Boats] wrote:
> Allen,
> Michael
> (Greg)
> <mailto:md… [at] yahoo.com> [Cal_Boats] <Ca… [at] yahoogroups.com
> Greg,
> Michael
> s/v Magic, Cal 2-27
> Pompano Beach, FL
> image <https://www.flickr.com/photos/stefsail/sets/72157622081060993/>
> Preview by Yahoo
> *From:* "Greg Beron gb… [at] yahoo.com <mailto:gb… [at] yahoo.com>
> <mailto:Ca… [at] yahoogroups.com>" <Ca… [at] yahoogroups.com
> [Attachment(s)
> be acid-based.
> Thanks!
> Sent from my iPhone
Greg Beron2014-08-02 00:11 UTC
Thanks! There have been a lot of helpful product/technique tips and I appreciate all of them.
Greg
> On Aug 1, 2014, at 5:02 PM, "Duane Knize kn… [at] san.rr.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
> Greg,
> I stripped the spars of all hardware except the sail tracks, removed what little remaining paint there was, alodyned (gold), masked the sail tracks, and Awlgripped them with two coats of 2-part undercoat and two coats of 2-part topcoat.
> You can use a butane torch to free fasteners that are frozen with corrosion (the aluminum oxide seemed to melt).
> I refinished the boom in my garage and was able to use a paint sprayer and achieved a very good finish.
> I refinished the mast sitting horizontally on stands at the boatyard using a paintbrush and obtained a decent finish.
> I bedded the hardware with a combination of Boatlife calk and Lanokote (on threads).
> Some corrosion bubbling developed over the years near hardware attachments and was/is addressed by spot touch ups.
> It's nearing time to do the full job again; this time I may pull off the sail tracks as well, but it may require enlarging the screws and re-threading.
> Good luck,
> Duane Knize
> S/V Marlyn
> 1978 Cal 2-39 #18
>> Allen,
>> Michael
>> Greg,
>> Michael
>> s/v Magic, Cal 2-27
>> Pompano Beach, FL
>> Preview by Yahoo
>> Thanks!
>> Sent from my iPhone
Don Trepanier2014-08-04 21:11 UTC
I used the same to re-bed the cabin lites on my CAL2-29. Absolutely no
leaks, and it is tacky enough that it held them in place till I got
inside to secure them with the bezel.
Don
CAL2-29
Cayuga Lake, NY
On 07/31/2014 11:56 AM, Chris Campbell cc… [at] lsnm.org [Cal_Boats] wrote:
> Listmates:
> and black.
> Chris Campbell
