15 messages2014-08-03 15:14 UTCthrough 2014-08-05 18:01 UTC
Farymann stuff - Free to a good home
ja… [at] jacaldwellinc.com2014-08-03 15:14 UTC
I recently stumbled across some Farymann manuals and a couple of couplers that I've had laying around. I'll be happy to send them to anyone still running a Farymann for the cost of shipping.
I'm not even sure how hard the vulcanized rubber couplers are to find anymore, but the last time I bought one about 10 years ago it cost about $300. After the last one gave away I had a custom coupler made.
The first generation coupler used a total of 6 bushings between 3 aluminum rings; the second generation upped the bushing count to 8 and slightly reduced the ring diameter.
The first gen piece needs some slight machining to fit properly - we used one of the rings for another coupler and never got around to finishing the replacement ring. You can see the first gen installed here --> https://groups.yahoo.com/neo/groups/Cal_Boats/photos/albums/2056938998/lightbox/423692504?orderBy=ordinal&sortOrder=asc&photoFilter=ALL#zax/423692504 https://groups.yahoo.com/neo/groups/Cal_Boats/photos/albums/2056938998/lightbox/423692504?orderBy=ordinal&sortOrder=asc&photoFilter=ALL#zax/423692504
Everything is FOB SoCal; if you're in the Seal Beach/Long Beach area I'll be happy to meet you in Alamitos Bay.
Ping me off-list if interested.
Re: [Cal_Boats] Farymann stuff - Free to a good home [1 Attachment]
Allen Edwards2014-08-03 15:34 UTC
I would love to scan them and put them online. I don't think I have them.
http://l-36.com/manuals.php
On Sun, Aug 3, 2014 at 8:14 AM, ja… [at] jacaldwellinc.com [Cal_Boats] <
Ca… [at] yahoogroups.com> wrote:
> [Attachment(s) <#1479c7023879fa18_TopText> from
> ja… [at] jacaldwellinc.com [Cal_Boats] included below]
Cabin curtains
Adam2014-08-04 19:01 UTC
A matter of complete frivolity, but wondering what people do for salon curtains when the cabin house walls are only ~3/16" fiberglass with no core or liner and thus don't have enough meat to screw a curtain track into. I made some cheap curtains with velcro and hot-glued velcro strips to the fiberglass, but those have been failing.
I assume the only options are:
(1) epoxy curtain tracks, or strips of hardwood to serve as a base to which tracks will be screwed, to the house walls. I suspect this will eventually fail after enough twisting, bouncing, and solar heating/cooling that is part of a boat's existence
(2) Screw through the outside into track/hardwood track base, ideally countersinking the heads and then puttying, sanding, and painting over. Seems a bit excessive.
Any other ideas? How are your boats curtain-ified?
Adam
Cal 2-27
From: "Allen Edwards al… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
Sent: Sunday, August 3, 2014 8:34 AM
Subject: Re: [Cal_Boats] Farymann stuff - Free to a good home
On Sun, Aug 3, 2014 at 8:14 AM, ja… [at] jacaldwellinc.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote:
>[Attachment(s) from ja… [at] jacaldwellinc.com [Cal_Boats] included below]
Re: [Cal_Boats] Cabin curtains
Allen Edwards2014-08-04 19:21 UTC
Perhaps this is a use for 5200. They won't come off if you use it.
Personally, I hate the stuff because you can't get anything apart after
using it but in this case I think it might be a good fit.
On Mon, Aug 4, 2014 at 12:01 PM, Adam as… [at] yahoo.com [Cal_Boats] <
> Thanks,
> Adam
> Cal 2-27
> *From:* "Allen Edwards al… [at] gmail.com [Cal_Boats]" <
> *Sent:* Sunday, August 3, 2014 8:34 AM
> *Subject:* Re: [Cal_Boats] Farymann stuff - Free to a good home
> them.
> Allen
> [Attachment(s)
> <https://us-mg6.mail.yahoo.com/neo/launch?.rand=cpn09fhpi4sgs#1479c7023879fa18_TopText>
Chris Campbell2014-08-04 19:49 UTC
> into.
I am grinning. Many years ago, when we first had my other boat, my
father and brother and I were planning a great voyage of discovery
around Lake Huron's Saginaw Bay. Dad perceived that we'd have little
privacy at the marinas without curtains, so my mother stitched up some
of suitable size, and Dad (who rarely had time for such things) arranged
curtain rods. He epoxied some house-type rod holders to the un-lined
fiberglass cabin sides. The concept was workable but the execution
wasn't, because the previous owner had painted the interior. The glue
held but the paint didn't, so the rods fell off. That was 45 years ago
and making better arrangements is still on my to-do list.
As you can see, I've had a long time to think about it. My conclusion
is that any curtain holders must be secured to some wood pads or strips,
depending on the actual device chosen, to give a larger gluing surface
and something to run screws into. More importantly, that non-tenacious
paint must be removed in the way of the wood pads or strips. I don't
think that the pads or strips will fail, because they're actually
secured to a relatively small surface area, and any movement in the
substrate isn't likely to stress them very much.
William Symes2014-08-04 20:08 UTC
Sara E's curtain holders are screwed into wood pads epoxied to the house walls, as Chris suggests. They've worked for the 9 years we've owned the boat, and apparently many years before. When one falls off (every couple of years it happens) I just clean up the attachment surfaces and re-epoxy.
Bill Symes
S/V Sara E
Cal Cruising 36
On Aug 4, 2014, at 12:01 PM, "Adam as… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
> Thanks,
> Adam
> Cal 2-27
> Allen
Fin2014-08-04 22:15 UTC
Bill ... Just the same way we did it when we had a Cal-34. Worked fine.
Are you related to Symes Cadillac of Pasadena ? Are you that Bill Symes ?
Fin Beven
Cal-40 No. 24
Radiant
San Pedro, CA
From: William Symes ls… [at] sbcglobal.net [Cal_Boats]<mailto:ls… [at] sbcglobal.net%20[Cal_Boats]>
Sent: Monday, August 04, 2014 1:08 PM
Subject: Re: [Cal_Boats] Cabin curtains
Bill Symes
S/V Sara E
Cal Cruising 36
On Aug 4, 2014, at 12:01 PM, "Adam as… [at] yahoo.com<mailto:as… [at] yahoo.com> [Cal_Boats]" <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>> wrote:
Adam
Cal 2-27
From: "Allen Edwards al… [at] gmail.com<mailto:al… [at] gmail.com> [Cal_Boats]" <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>>
To: "Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>" <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>>
http://l-36.com/manuals.php<http://l-36.com/manuals.php>
On Sun, Aug 3, 2014 at 8:14 AM, ja… [at] jacaldwellinc.com<mailto:ja… [at] jacaldwellinc.com> [Cal_Boats] <Ca… [at] yahoogroups.com<mailto:Ca… [at] yahoogroups.com>> wrote:
[Attachment(s)<https://us-mg6.mail.yahoo.com/neo/launch?.rand=cpn09fhpi4sgs#1479c7023879fa18_TopText> from ja… [at] jacaldwellinc.com<mailto:ja… [at] jacaldwellinc.com> [Cal_Boats] included below]
The first gen piece needs some slight machining to fit properly - we used one of the rings for another coupler and never got around to finishing the replacement ring. You can see the first gen installed here --> https://groups.yahoo.com/neo/groups/Cal_Boats/photos/albums/2056938998/lightbox/423692504?orderBy=ordinal&sortOrder=asc&photoFilter=ALL#zax/423692504<https://groups.yahoo.com/neo/groups/Cal_Boats/photos/albums/2056938998/lightbox/423692504?orderBy=ordinal&sortOrder=asc&photoFilter=ALL#zax/423692504>
Adam2014-08-04 22:33 UTC
Thanks for all the responses! Sounds like epoxying a few bits of wood where needed and screwing rod bases or track to them is the way to go.
From: "'Fin' fi… [at] msn.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
Sent: Monday, August 4, 2014 3:15 PM
fine.
Symes ?
Fin Beven
Cal-40 No. 24
Radiant
San Pedro, CA
>Bill Symes
>S/V Sara E
>Cal Cruising 36
>>Thanks,
>>Adam
>>Cal 2-27
>>________________________________
>>Allen
Al Waschka2014-08-04 22:44 UTC
3M makes an industrial strength double sided tape. Not a marine use, but a solar installer I am aware of uses it to stick mounting brackets for solar panels to trailer roofs. He says he has installed hundreds and has never had one come loose. We are talking 10 or 12 square feet of solar panel on four brackets with bases on the order of 1"x2".
Al
> On Aug 4, 2014, at 3:01 PM, "Adam as… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
> Thanks,
> Adam
> Cal 2-27
> Allen
Allen Edwards2014-08-04 23:00 UTC
At the risk of repeating myself, 3M 5200 would be a better choice than
epoxy. You won't have to re-epoxy it ever. It will never fall off. m Just
make sure you get the paint off under it. But even when you decide you
want to remove it, it isn't coming off. But the epoxy really should not
come off either if done correctly. It is just that the 5200 has a little
give to it.
On Mon, Aug 4, 2014 at 3:44 PM, Al Waschka aw… [at] bellsouth.net
> Al
> Sent from my iPad
> Thanks,
> Adam
> Cal 2-27
> them.
> Allen
> [Attachment(s)
Re: [Cal_Boats] Cabin curtains (Adam)
Duane Knize2014-08-05 01:11 UTC
Adam,
If you have the type of windows with plastic frames that are screwed
together from the inside, that many Cal's have, you can mount curtain
tracks to battens fixed to the top and bottom edges of the window frames
with slightly longer screws.
I replaced the original Cal 39 curtains and the metal tracks and slides
with new curtains using the plastic/snap slides available from WM in
this manner.
Regards,
Duane Knize
S/V Marlyn
1978 Cal2-39 #18
> *From:* "'Fin' fi… [at] msn.com [Cal_Boats]" <Ca… [at] yahoogroups.com>
> *Sent:* Monday, August 4, 2014 3:15 PM
> *Subject:* Re: [Cal_Boats] Cabin curtains
> Symes ?
> Fin Beven
> Cal-40 No. 24
> Radiant
> San Pedro, CA
> *From:* William Symes ls… [at] sbcglobal.net [Cal_Boats]
> *To:* Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>
> *Sent:* Monday, August 04, 2014 1:08 PM
> Bill Symes
> S/V Sara E
> Cal Cruising 36
>> have been failing.
>> existence
>> Thanks,
>> Adam
>> Cal 2-27
>> <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>>
>> have them.
>> Allen
>> <Ca… [at] yahoogroups.com <mailto:Ca… [at] yahoogroups.com>> wrote:
>> [Attachment(s)
>> below]
>> shipping.
Re: Cabin curtains
am… [at] stuffandjunk.net2014-08-05 11:06 UTC
A previous owner of my rig solved the problem by putting in windows with a faux stained glass look to them. Light in but lots of privacy! I'm replacing the now leaky things, but couldn't find a similar design. So I'm planning on picking up decals to accomplish the same thing.
Anne Racel
4 Degrees
http://boatjournal.stuffandjunk.net
Re: Adventure Kwest
Michael D2014-08-05 14:22 UTC
Anyone,
What's the word on Paul's keel-to-hull joint crack?
Tap, tap, tap... Paul, are you out there?
Michael
Re: [Cal_Boats] Re: Cabin curtains
Chris Campbell2014-08-05 15:00 UTC
On the other hand, there are times when you want to be able to see out
from below. Curtains let you choose when there's visibility and when
there's not. I single-hand a lot, so I'm the only crew. It's nice to
be able to view what's happening around you.
Re: [Cal_Boats] Re: Adventure Kwest
pw… [at] aol.com2014-08-05 18:01 UTC
Hey Michael -
Repair is done and we splashed just after the 4th of July. Took way longer to repair than I wanted but that's what happens when you can't work on it everyday. I have to pull all the pics off my phone and post them one of these days.
I ended up adding 4 layers of new glass on the inside and I think it took about 11 layers on the outside. Giant pain in the arse working over your head. Use the fast setting epoxy if you have to do the same thing.
Paul
From: Michael D md… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com>
Sent: Tue, Aug 5, 2014 10:23 am
Subject: [Cal_Boats] Re: Adventure Kwest
Anyone,
Michael
