7 messages2014-08-25 23:22 UTCthrough 2014-08-28 00:22 UTC
Re: [Cal_Boats] Re: Water Leak at Companionway Door Threshold
rj… [at] juno.com2014-08-25 23:22 UTC
I missed which CAL model this leak was on, but the wood "threshold" (what
would the true marine term for that be?) on our old CAL 21 was 2 pieces
of wood, one inside and one outside. The inside one was flush with the
edge of the fiberglass opening and the outside one was about 1/4" below
the top of the edge. The bottom of the companionway panel (or bottom drop
board if we were using our 3-piece drop boards) sat on the outer wood
piece and the top of that piece was beveled slightly down from the top
edge. (I'll see if I have picture, but doubt I have one that would really
clearly show this)
Rod Johnson, "SUNBIRD"
1979 O'DAY DS II
former co-owner of "NODROG"
1970 CAL 21 #285
On 25 Aug 2014 16:08:22 -0700 "za… [at] yahoo.com [Cal_Boats]"
<Ca… [at] yahoogroups.com> writes:
Does anyone have a picture of what this should look like? Was the wooden
threshold glued down or was it just sitting on top of the fiberglass?
rj… [at] juno.com2014-08-26 19:28 UTC
On our old CAL 21 the 2 pieces of wood (Teak) that made up the threshold
were held in place by screws through the inner piece that screwed into
the outer piece with the fiberglass sandwiched between.
1979 O'DAY DS II
former co-owner of "NODROG" (sold 2008)
1970 CAL 21
On 26 Aug 2014 04:38:38 -0700 "za… [at] yahoo.com [Cal_Boats]"
That is very interesting. I wonder why your fiberglass slopes towards
the cockpit and mine slopes towards the cabin? They are the same year
and model of boats unless your's is still from the 2-27 and mine was a
3-27? I will take a better picture next time I am at the boat and see
how I need to fabricate this bottom threshold so it fits nicely and
doesn't need caulking. How do you suggest I secure the threshold to the
fiberglass? I have plenty of Butyl tape from when I rebedded my old
Chrysler 22 but I don't know if I want to screw into the fiberglass when
obviously the factory didn't.
The #1 Worst Carb Ever?
Click to Learn #1 Carb that Kills Your Blood Sugar (Don't Eat This!)
http://thirdpartyoffers.juno.com/TGL3141/53fce032701b60316e28st01duc
Kool Beans2014-08-26 22:24 UTC
z from Huaweiqq Mobilenl
>1979 O'DAY DS II
>1970 CAL 21
>____________________________________________________________
Kool Beans2014-08-26 22:46 UTC
,a
Sent from Hqqquawei Mobile
>1979 O'DAY DS II
>1970 CAL 21
ya… [at] e-rohde.net2014-08-27 01:51 UTC
As it happens, I skipped out of work early and went sailing tonight. What I learned is that I know very little about my boat.
Mine slopes towards the cabin as well, however there is a lip there that prevents water from coming in. The bottom drop board sits fully on the cockpit side of the lip. Links to pictures . . .
https://dl.dropboxusercontent.com/u/4449275/boat/showingSlope.jpg https://dl.dropboxusercontent.com/u/4449275/boat/showingSlope.jpg
https://dl.dropboxusercontent.com/u/4449275/boat/dropBoardInPlace.jpg https://dl.dropboxusercontent.com/u/4449275/boat/dropBoardInPlace.jpg
https://dl.dropboxusercontent.com/u/4449275/boat/outsideLookingIn.jpg https://dl.dropboxusercontent.com/u/4449275/boat/outsideLookingIn.jpg
za… [at] yahoo.com2014-08-27 19:53 UTC
Well lucky you ;) Thanks for the pictures. I am not able to get tot he boat just yet, but I am pretty sure mine does NOT have that lip on it like yours does. Otherwise it shouldn't be leaking.
Re: [Cal_Boats] Los Angeles Harbor has breaking waves
Mark Alan Stahnke (MAS Consulting)2014-08-28 00:22 UTC
This morning I went to Cabrillo beach and discovered and photographed breaking waves inside the Los Angeles light house making the entrance extremely dangerous. Also there were perfect surfing waves not only on the outer beach but inside on the calm side. As the Westerly picked up it created an offshore on the inner beach creating perfect tube shaped waves between 2 and 4 feet. The calm side beach has not had surf since the 60s-early 70s. Additionally, I got a couple pictures of the water crashing on LA light about 1/2 way to the top.
An exciting day!
Mark A. Stahnke
MAS Consulting
(310) 832-5992
Sent: Wednesday, August 27, 2014 12:53 PM
Subject: Re: [Cal_Boats] Re: Water Leak at Companionway Door Threshold
