6 messages2014-09-21 22:05 UTCthrough 2014-09-22 14:31 UTC
Cal 25: Cabin Painting
mm… [at] gmail.com2014-09-21 22:05 UTC
Hi All,
Per Charlie H: the inside skin [Cal 25] is thin (a layer of cloth and some
crappy paint that won’t sand) . I scraped the flaking paint off the cabin including v-berth. If it won't sand, what should be the next step to restore the interior? Thank for any advice and tips!
Marv Gross
Cal 25 Banshee
Marina del Rey, CA
Re: Cal 25: Cabin Painting
ca… [at] gmail.com2014-09-21 22:55 UTC
I prepped Nemesis' interior with a wire wheel on an 18v sander, followed by heavy sanding with 80 grit. That took care of the flaking. 2 coats of interior semi-gloss white gave me a finish I can libe with. You might want to fair and use high gloss, but Im not particular.
Fred Haas
3-30 Nemesis
Tacoma
mm… [at] gmail.com2014-09-22 00:07 UTC
Thanks, Fred. Sounds doable.
Marv
Re: [Cal_Boats] Cal 25: Cabin Painting
ccampbell2014-09-22 13:25 UTC
On 9/21/2014 6:05 PM, mm… [at] gmail.com [Cal_Boats] wrote:
> Hi All,
> Per Charlie H: /the inside skin [Cal 25] is thin (a layer of cloth
> and some /
> /crappy paint that won’t sand) . /I scraped the flaking paint off the
My Cal 20 had that mysterious coating that flakes off in some places and
is tenacious as hell in others. To make matters worse, my Cal 20 spends
her off seasons in a storage yard with no electric power nearby, so
sanding or wire-brushing was not an option. So I started with paint
removers. First, the gentle, safe kind. It didn't budge the stuff.
Next, regular, poisonous stuff. Not much better. Finally, the most
powerful version of Zip-Strip. That did the job.
That also uncovered a few areas where the fiberglass wasn't
resin-saturated, so I added some epoxy there.
Then I painted with Pettit's Dura-White, a paint for boat interior use.
It has since been re-named by Pettit. They touted it as sticking to
anything without sanding, even glossy surfaces. It's also supposed to
have anti-mildew properties. It's a semi-gloss finish. I had mine
tinted at the hardware store from a chip of the old paint. Their
computer matched the original beige color exactly. It has been durable
and washable, even for the spider droppings.
David Owen2014-09-22 13:48 UTC
This conversation came up before with similar comments made. I will warn others again. Based on my observations when I stripped my interior - If your stripper removes that "paint" it may also remove some of the resin. I doubt unsaturated cloth was found in places. I believe the cloth was desaturated by the stripper.
Wilkie
> On Sep 22, 2014, at 6:25 AM, "ccampbell cc… [at] lsnm.org [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote:
>> Hi All,
> My Cal 20 had that mysterious coating that flakes off in some places and is tenacious as hell in others. To make matters worse, my Cal 20 spends her off seasons in a storage yard with no electric power nearby, so sanding or wire-brushing was not an option. So I started with paint removers. First, the gentle, safe kind. It didn't budge the stuff. Next, regular, poisonous stuff. Not much better. Finally, the most powerful version of Zip-Strip. That did the job.
> That also uncovered a few areas where the fiberglass wasn't resin-saturated, so I added some epoxy there.
> Then I painted with Pettit's Dura-White, a paint for boat interior use. It has since been re-named by Pettit. They touted it as sticking to anything without sanding, even glossy surfaces. It's also supposed to have anti-mildew properties. It's a semi-gloss finish. I had mine tinted at the hardware store from a chip of the old paint. Their computer matched the original beige color exactly. It has been durable and washable, even for the spider droppings.
> Chris Campbell
ccampbell2014-09-22 14:31 UTC
If that were the case, I would have expected to find it overall.
Instead, it was in a few distinct places. I examined it carefully,
trying figure out whether the stripper were responsible. I concluded
"no," and even if the answer were yes, the problem was so isolated (and
so easily fixed) that it didn't matter. It came nowhere near creating
structural issues. I concluded that Cal likely used that thick
paint-like coating intentionally to cover up resin-saturation problems.
