Exhaust white smoke
Exhaust white smoke
5 messages2014-11-04 00:55 UTCthrough 2014-11-04 16:40 UTC
Exhaust white smoke
Bruce Bygate2014-11-04 00:55 UTC
I have an 88 hunt designed cal 28 with a rebuilt westerbeke 13a diesel. The engine has run fine since the rebuild about 80 hours ago The engine shows no signs
Fwd: Exhaust white smoke
Bruce Bygate2014-11-04 01:33 UTC
Begin forwarded message: > From: Bruce Bygate <b.… [at] verizon.net> > Date: November 3, 2014 at 7:55:39 PM EST > To: "Cal_Boats@yahoogroups. com" <Ca… [at] yahoogroups.com> > Subject: Exhaust white smoke > > I have an 88 hunt designed cal 28 with a rebuilt westerbeke 13a diesel. > > The engine has run fine since the rebuild about 80 hours ago. Then when we were motoring to haul---- > > The engine shows no signs of white smoke until it warms up. Then significant exhaust white smoke. The oil level is fine as well as the antifreeze. Does anyone have an answer?
RE: [Cal_Boats] Fwd: Exhaust white smoke
Timm Lessley2014-11-04 02:23 UTC
Re: [Cal_Boats] Fwd: Exhaust white smoke
Joe DeMers2014-11-04 13:28 UTC
If the engine exhaust is actually emitting steam, this may be due to insufficient exhaust water being discharged through the system. Check the raw water strainer for obstructions. Also, the exhaust elbow may be clogged, restricting raw water flow. *Joe DeMers - owner* Sound Marine Diesel LLC SoundMarineDiesel.com <http://www.soundmarinediesel.com/>*phone & fax (860) 666-2184* On 11/3/2014 8:33 PM, Bruce Bygate b.… [at] verizon.net [Cal_Boats] wrote: > > > > > > Begin forwarded message: > >> *From:* Bruce Bygate <b.… [at] verizon.net <mailto:b.… [at] verizon.net>> >> *Date:* November 3, 2014 at 7:55:39 PM EST >> *To:* "Cal_Boats@yahoogroups. com" <Ca… [at] yahoogroups.com >> <mailto:Ca… [at] yahoogroups.com>> >> *Subject:* *Exhaust white smoke* >> >> I have an 88 hunt designed cal 28 with a rebuilt westerbeke 13a diesel. >> >> The engine has run fine since the rebuild about 80 hours ago. Then >> when we were motoring to haul---- >> >> The engine shows no signs of white smoke until it warms up. Then >> significant exhaust white smoke. The oil level is fine as well as >> the antifreeze. Does anyone have an answer? > > > -- *Joe DeMers - owner* Sound Marine Diesel LLC SoundMarineDiesel.com <http://www.soundmarinediesel.com/>*phone & fax (860) 666-2184*
Bruce Bygate2014-11-04 16:40 UTC
thanks Joe, I've attached a video of the warm engine exhaust with the boat on the hard. On 11/4/2014 8:28 AM, Joe DeMers je… [at] mindspring.com [Cal_Boats] wrote: > > If the engine exhaust is actually emitting steam, this may be due to > insufficient exhaust water being discharged through the system. Check > the raw water strainer for obstructions. Also, the exhaust elbow may > be clogged, restricting raw water flow. > > *Joe DeMers - owner* > > Sound Marine Diesel LLC > > SoundMarineDiesel.com <http://www.soundmarinediesel.com/>*phone & fax > (860) 666-2184* > > > > > > > > > On 11/3/2014 8:33 PM, Bruce Bygate b.… [at] verizon.net [Cal_Boats] wrote: >> >> >> >> Begin forwarded message: >> >>> *From:* Bruce Bygate <b.… [at] verizon.net >>> <mailto:b.… [at] verizon.net>> >>> *Date:* November 3, 2014 at 7:55:39 PM EST >>> *To:* "Cal_Boats@yahoogroups. com" <Ca… [at] yahoogroups.com >>> <mailto:Ca… [at] yahoogroups.com>> >>> *Subject:* *Exhaust white smoke* >>> >>> I have an 88 hunt designed cal 28 with a rebuilt westerbeke 13a diesel. >>> >>> The engine has run fine since the rebuild about 80 hours ago. Then >>> when we were motoring to haul---- >>> >>> The engine shows no signs of white smoke until it warms up. Then >>> significant exhaust white smoke. The oil level is fine as well as >>> the antifreeze. Does anyone have an answer? > > -- > > *Joe DeMers - owner* > > Sound Marine Diesel LLC > > SoundMarineDiesel.com <http://www.soundmarinediesel.com/>*phone & fax > (860) 666-2184* > --- This email has been checked for viruses by Avast antivirus software. http://www.avast.com
