Compression test
Bruce By gate2015-01-27 13:31 UTC
Need to do a test on a westerbeke 13a. Did a goggle looking for test meter. Does anyone have info about the best compression tester that will work with this engine?
Re: [Cal_Boats] Compression test
Tom Vandiver2015-01-27 14:19 UTC
We use one from Harbor Freight, but had to make adapters for various engines, like Perkins. No problem if you have a lathe, drill press and some scrap pieces of aluminum. I made ours from an old bronze prop shaft.
Tom Vandiver, Cal 46, Pensacola, FL
From: "Bruce By gate b.… [at] verizon.net [Cal_Boats]" <Ca… [at] yahoogroups.com>
Sent: Tuesday, January 27, 2015 7:31 AM
Subject: [Cal_Boats] Compression test
