Re: Cal 29 outboard
Re: Cal 29 outboard
5 messages2015-04-19 20:39 UTCthrough 2015-04-20 16:57 UTC
Re: Cal 29 outboard
Jim Englert2015-04-19 20:39 UTC
My 29 came w an onboard and I cut my transom out and mounted the outboard directly on the transom. My Yamaha 9.9 has the extra long shaft and is the high thrust model. The high thrust is important for backing power. I do right around 6 knots under power. It's a great setup the boat feels very smooth not having the inboard prop in front of the rudder. Jim cal29 sailor
Re: [Cal_Boats] Re: Cal 29 outboard
david dobbs2015-04-20 00:50 UTC
Joe,I'd have someone look at the inboard, it might be repairable.David Dobbs, CAL29 411, A4 powered. On Sunday, April 19, 2015 3:39 PM, "Jim Englert sa… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote: My 29 came w an onboard and I cut my transom out and mounted the outboard directly on the transom. My Yamaha 9.9 has the extra long shaft and is the high thrust model. The high thrust is important for backing power. I do right around 6 knots under power. It's a great setup the boat feels very smooth not having the inboard prop in front of the rudder. Jim cal29 sailor
Joseph Schoepp2015-04-20 01:16 UTC
David, I think that's going to be the plan. I going to have seatow move it to a spot closer to my house where I can get to it daily. I have a friend who repaired a diesel on a sailboat years ago who is going to look at it. If he can't help, I'll get a professional to come out and see. Then depending on cost will decide on the outboard. I want to thank everyone for being so helpful! Joe - Cal 29 From:"david dobbs tm… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com> Date:Sun, Apr 19, 2015 at 8:50 PM Subject:Re: [Cal_Boats] Re: Cal 29 outboard Joe, I'd have someone look at the inboard, it might be repairable. David Dobbs, CAL29 411, A4 powered. On Sunday, April 19, 2015 3:39 PM, "Jim Englert sa… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote: My 29 came w an onboard and I cut my transom out and mounted the outboard directly on the transom. My Yamaha 9.9 has the extra long shaft and is the high thrust model. The high thrust is important for backing power. I do right around 6 knots under power. It's a great setup the boat feels very smooth not having the inboard prop in front of the rudder. Jim cal29 sailor
david dobbs2015-04-20 02:20 UTC
Joe, when you take that boat for a sail you will not regret your decision.David Cal29 411 On Sunday, April 19, 2015 8:16 PM, "Joseph Schoepp jo… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote: | David, I think that's going to be the plan. I going to have seatow move it to a spot closer to my house where I can get to it daily. I have a friend who repaired a diesel on a sailboat years ago who is going to look at it. If he can't help, I'll get a professional to come out and see. Then depending on cost will decide on the outboard. I want to thank everyone for being so helpful! Joe - Cal 29 | From:"david dobbs tm… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com> Date:Sun, Apr 19, 2015 at 8:50 PM Subject:Re: [Cal_Boats] Re: Cal 29 outboard Joe,I'd have someone look at the inboard, it might be repairable.David Dobbs, CAL29 411, A4 powered. On Sunday, April 19, 2015 3:39 PM, "Jim Englert sa… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote: My 29 came w an onboard and I cut my transom out and mounted the outboard directly on the transom. My Yamaha 9.9 has the extra long shaft and is the high thrust model. The high thrust is important for backing power. I do right around 6 knots under power. It's a great setup the boat feels very smooth not having the inboard prop in front of the rudder. Jim cal29 sailor | |
Fred Haas2015-04-20 16:57 UTC
Joe, I’m glad you’ve concluded that the diesel repair is your best option. I’ve seen too many outboard adaptations that ust didn’t work. You have a fine boat there, and to botch it up would be a shame. When it’s all said and done, the repair will ask likely be more cost effective than the outboard option. That and $3 will get you a cup at your local Starbucks. Fred Haas 3-30 Nemesis acoma On Apr 19, 2015, at 7:20 PM, david dobbs tm… [at] yahoo.com [Cal_Boats] <Ca… [at] yahoogroups.com> wrote: > > Joe, when you take that boat for a sail you will not regret your decision. > David Cal29 411 > > > > > On Sunday, April 19, 2015 8:16 PM, "Joseph Schoepp jo… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote: > > > > David, > > I think that's going to be the plan. I going to have seatow move it to a spot closer to my house where I can get to it daily. I have a friend who repaired a diesel on a sailboat years ago who is going to look at it. If he can't help, I'll get a professional to come out and see. Then depending on cost will decide on the outboard. I want to thank everyone for being so helpful! > > Joe - Cal 29 > From:"david dobbs tm… [at] yahoo.com [Cal_Boats]" <Ca… [at] yahoogroups.com> > Date:Sun, Apr 19, 2015 at 8:50 PM > Subject:Re: [Cal_Boats] Re: Cal 29 outboard > > > Joe, > I'd have someone look at the inboard, it might be repairable. > David Dobbs, CAL29 411, A4 powered. > > > > > On Sunday, April 19, 2015 3:39 PM, "Jim Englert sa… [at] gmail.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote: > > > > My 29 came w an onboard and I cut my transom out and mounted the outboard directly on the transom. My Yamaha 9.9 has the extra long shaft and is the high thrust model. The high thrust is important for backing power. I do right around 6 knots under power. > > It's a great setup the boat feels very smooth not having the inboard prop in front of the rudder. > > Jim cal29 sailor > > > > > > >
