Locating A New Four Battery Bank on Cal 30
3 messages2015-04-20 13:11 UTCthrough 2015-04-20 21:02 UTC
sa… [at] mascom.com2015-04-20 13:11 UTC
I'm installing a 2000W inverter, Engel refrigerator and solar installation on my Cal 30 and needed to find a suitable location for my new 4 6V golf cart batteries being installed in series/parallel. Wanting to do this right, I purchased the huge battery boxes from West Marine that would hold two of the Interstate 6V batteries and allow them to be bolted down rigidly. These boxes also have suitable cable outlets for the 4/0 cables I'm using for the installation. I had hoped to put all four below the V-berths but sadly found that not only wouldn't all four fit in that location with the boxes, I couldn't even get one of the boxes in place without removling 3 of the 4 cover supports. Once these were out, I could get a box in there and (with amazing agilty and contortions) managed to lower those two 65# monsters in place and hook them up in series. I even managed to get the cover on after marking all of the (temporary) connections. I decided the the area below wide area of the V-berths would make a suitable location for the invertor and the second battery box. While I don't have the other two batteries out to the boat yet, I'm convinced that this will make a good location for this weight (right on the centerline) and plan on countering the 150# weight of this installation with an auxiliary fuel tank that will be mounted just aft of the cockpit. Before I finish the install, I will need to glass in a couple of plywood platforms in both locations that will level the battery box and allow a firm bolt down.
Re: [Cal_Boats] Locating A New Four Battery Bank on Cal 30 [2 Attachments]
Joe DeMers2015-04-20 20:18 UTC
On 4/20/2015 9:11 AM, sa… [at] mascom.com [Cal_Boats] wrote: > [Attachment(s) <#TopText> from sa… [at] mascom.com [Cal_Boats] > included below] > > I'm installing a 2000W inverter, Engel refrigerator and solar > installation on my Cal 30 and needed to find a suitable location for > my new 4 6V golf cart batteries being installed in series/parallel. > > Wanting to do this right, I purchased the huge battery boxes from West > Marine that would hold two of the Interstate 6V batteries and allow > them to be bolted down rigidly. These boxes also have suitable cable > outlets for the 4/0 cables I'm using for the installation. > ********** 4/0 cables? WAY overkill for powering an inverter and refer. ******** How are you recharging this huge battery bank? Joe DeMers > > > I had hoped to put all four below the V-berths but sadly found that > not only wouldn't all four fit in that location with the boxes, I > couldn't even get one of the boxes in place without removling 3 of the > 4 cover supports. Once these were out, I could get a box in there and > (with amazing agilty and contortions) managed to lower those two 65# > monsters in place and hook them up in series. I even managed to get > the cover on after marking all of the (temporary) connections. > > I decided the the area below wide area of the V-berths would make a > suitable location for the invertor and the second battery box. While I > don't have the other two batteries out to the boat yet, I'm convinced > that this will make a good location for this weight (right on the > centerline) and plan on countering the 150# weight of this > installation with an auxiliary fuel tank that will be mounted just aft > of the cockpit. > > Before I finish the install, I will need to glass in a couple of > plywood platforms in both locations that will level the battery box > and allow a firm bolt down. > > > > > -- *Joe DeMers - owner* Sound Marine Diesel LLC SoundMarineDiesel.com <http://www.soundmarinediesel.com/>*phone & fax (860) 666-2184*
Helen Horn2015-04-20 21:02 UTC
how about on top of the keel .....on "Nemesis" their was a battery bank under the starboard bench group 27...the nice thing about V-berth it is close to windless this saves voltage drop I really do not like 2 or4 6 Volts too many terminals ...and it seems that the water level on 6 volt s have to be topped off more often than 8D s ...on smaller boats i like group 27s for banksthey are DEEP Cycle and quickly "come back" to full charge ...plus if you need 12 volts ...you only have to carry one battery to where it is needed ...edward On Monday, April 20, 2015 1:18 PM, "Joe DeMers je… [at] mindspring.com [Cal_Boats]" <Ca… [at] yahoogroups.com> wrote: On 4/20/2015 9:11 AM, sa… [at] mascom.com [Cal_Boats] wrote: I'm installing a 2000W inverter, Engel refrigerator and solar installation on my Cal 30 and needed to find a suitable location for my new 4 6V golf cart batteries being installed in series/parallel. Wanting to do this right, I purchased the huge battery boxes from West Marine that would hold two of the Interstate 6V batteries and allow them to be bolted down rigidly. These boxes also have suitable cable outlets for the 4/0 cables I'm using for the installation. ********** 4/0 cables? WAY overkill for powering an inverter and refer. ******** How are you recharging this huge battery bank? Joe DeMers I had hoped to put all four below the V-berths but sadly found that not only wouldn't all four fit in that location with the boxes, I couldn't even get one of the boxes in place without removling 3 of the 4 cover supports. Once these were out, I could get a box in there and (with amazing agilty and contortions) managed to lower those two 65# monsters in place and hook them up in series. I even managed to get the cover on after marking all of the (temporary) connections. I decided the the area below wide area of the V-berths would make a suitable location for the invertor and the second battery box. While I don't have the other two batteries out to the boat yet, I'm convinced that this will make a good location for this weight (right on the centerline) and plan on countering the 150# weight of this installation with an auxiliary fuel tank that will be mounted just aft of the cockpit. Before I finish the install, I will need to glass in a couple of plywood platforms in both locations that will level the battery box and allow a firm bolt down. -- Joe DeMers - owner Sound Marine Diesel LLC SoundMarineDiesel.comphone & fax (860) 666-2184 -- {border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;} hr {border:1px solid #d8d8d8;} {color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} {margin-bottom:10px;} .yiv2080942155ad {padding:0 0;} .yiv2080942155ad p {margin:0;} .yiv2080942155ad a {color:#0000ff;text-decoration:none;} {font-family:Arial;} {margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} .yiv2080942155ad {margin-bottom:10px;padding:0 0;} {font-family:Verdana;font-size:11px;padding:10px 0;} {background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;} span {font-weight:700;} span:first-child {text-transform:uppercase;} span a {color:#5085b6;text-decoration:none;} span span {color:#ff7900;} span .yiv2080942155underline {text-decoration:underline;} .yiv2080942155attach {clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;} .yiv2080942155attach div a {text-decoration:none;} .yiv2080942155attach img {border:none;padding-right:5px;} .yiv2080942155attach label {display:block;margin-bottom:5px;} .yiv2080942155attach label a {text-decoration:none;} blockquote {margin:0 0 0 4px;} .yiv2080942155bold {font-family:Arial;font-size:13px;font-weight:700;} .yiv2080942155bold a {text-decoration:none;} dd.yiv2080942155last p a {font-family:Verdana;font-weight:700;} dd.yiv2080942155last p span {margin-right:10px;font-family:Verdana;font-weight:700;} dd.yiv2080942155last p span.yiv2080942155yshortcuts {margin-right:0;} div.yiv2080942155attach-table div div a {text-decoration:none;} div.yiv2080942155attach-table {width:400px;} div.yiv2080942155file-title a, div.yiv2080942155file-title a:active, div.yiv2080942155file-title a:hover, div.yiv2080942155file-title a:visited {text-decoration:none;} div.yiv2080942155photo-title a, div.yiv2080942155photo-title a:active, div.yiv2080942155photo-title a:hover, div.yiv2080942155photo-title a:visited {text-decoration:none;} div p a span.yiv2080942155yshortcuts {font-family:Verdana;font-size:10px;font-weight:normal;} .yiv2080942155green {color:#628c2a;} .yiv2080942155MsoNormal {margin:0 0 0 0;} o {font-size:0;} div {float:left;width:72px;} div div {border:1px solid #666666;height:62px;overflow:hidden;width:62px;} div label {color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} {font-size:77%;} {font-size:77%;} .yiv2080942155replbq {margin:4px;} div a:first-child {margin-right:2px;padding-right:5px;} {font-size:13px;font-family:Arial, helvetica, clean, sans-serif;} table {font-size:inherit;font:100%;} select, input, textarea {font:99% Arial, Helvetica, clean, sans-serif;} pre, code {font:115% monospace;} * {line-height:1.22em;} {padding-bottom:10px;} p a {font-family:Verdana;} p span {color:#1E66AE;font-weight:700;} {color:#ff7900;font-weight:700;} {margin-bottom:20px;padding:0px;} li a {font-size:130%;text-decoration:none;} li {font-size:77%;list-style-type:square;padding:6px 0;} ul {margin:0;padding:0 0 0 8px;} {font-family:Georgia;} p {margin:0 0 1em 0;} tt {font-size:120%;} ul li:last-child {border-right:none !important;}
